    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    802.7k
      小鱼 技术大佬 @1281857896
      @1281857896 这个参数是哪里来的
      • 12818578961
        1281857896 @小鱼
        @小鱼 第17章建图与导航实践 fishbot导航实现 fishbot导航实现那块安装了nav2功能包,然后从功能包里复制出来的参数就这么多,我刚打开功能包确实是这些参数
        复制的时候用的下面这个命令
        cp /opt/ros/$ROS_DISTRO/share/nav2_bringup/params/nav2_params.yaml src/fishbot_navigation2/config
          小鱼 技术大佬 @1281857896
          @1281857896 你从快速上手教程里拷贝试试,或者直接用快速上手教程里的导航配置跑跑,看看能不能跑起来
            小鱼 技术大佬 @小鱼
            @小鱼 有些参数不一样
              小鱼 技术大佬 @小鱼
              amcl:
                ros__parameters:
                  use_sim_time: False
                  alpha1: 0.2
                  alpha2: 0.2
                  alpha3: 0.2
                  alpha4: 0.2
                  alpha5: 0.2
                  beam_skip_distance: 0.5
                  beam_skip_threshold: 0.3
                  do_beamskip: false
                  global_frame_id: "map"
                  lambda_short: 0.1
                  laser_max_range: 100.0
                  laser_min_range: -1.0
                  max_beams: 60
                  max_particles: 2000
                  min_particles: 500
                  odom_frame_id: "odom"
                  pf_err: 0.05
                  pf_z: 0.99
                  recovery_alpha_fast: 0.0
                  recovery_alpha_slow: 0.0
                  resample_interval: 1
                  robot_model_type: "differential"
                  save_pose_rate: 0.5
                  sigma_hit: 0.2
                  tf_broadcast: true
                  transform_tolerance: 1.0
                  update_min_a: 0.2
                  update_min_d: 0.25
                  z_hit: 0.5
                  z_max: 0.05
                  z_rand: 0.5
                  z_short: 0.05
              amcl_map_client:
                ros__parameters:
                  use_sim_time: False
              amcl_rclcpp_node:
                ros__parameters:
                  use_sim_time: False
              bt_navigator:
                ros__parameters:
                  use_sim_time: False
                  global_frame: map
                  robot_base_frame: base_link
                  odom_topic: /odom
                  default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
                  plugin_lib_names:
                  - nav2_back_up_action_bt_node
                  - nav2_spin_action_bt_node
                  - nav2_wait_action_bt_node
                  - nav2_recovery_node_bt_node
              bt_navigator_rclcpp_node:
                ros__parameters:
                  use_sim_time: False
              controller_server:
                ros__parameters:
                  use_sim_time: False
                  controller_frequency: 10.0
                  min_y_velocity_threshold: 0.5
                  # DWB parameters
                  FollowPath:
                    min_vel_x: 0.0
                    min_vel_y: 0.0
                    max_vel_x: 0.22
                    max_vel_y: 0.0
                    max_vel_theta: 0.8
                    min_speed_xy: 0.0
                    max_speed_xy: 0.44
                    min_speed_theta: 0.0
                    acc_lim_x: 2.5
                    acc_lim_y: 0.0
                    acc_lim_theta: 0.2
                    decel_lim_x: -0.5
                    decel_lim_y: 0.0
                    decel_lim_theta: -0.5
                    vx_samples: 20
                    vy_samples: 0
                    vtheta_samples: 40
                    sim_time: 1.5
                    linear_granularity: 0.05
                    angular_granularity: 0.025
                    transform_tolerance: 0.2
                    xy_goal_tolerance: 0.05
                    trans_stopped_velocity: 0.25
                    stateful: True
                    BaseObstacle.scale: 0.02
                    PathAlign.scale: 32.0
                    GoalAlign.scale: 24.0
                    PathDist.scale: 32.0
                    GoalDist.scale: 24.0
                    RotateToGoal.scale: 32.0
                ros__parameters:
                  use_sim_time: False
              local_costmap:
                local_costmap:
                  ros__parameters:
                    update_frequency: 5.0
                    publish_frequency: 2.0
                    global_frame: odom
                    use_sim_time: False
                    rolling_window: true
                    width: 3
                    height: 3
                    resolution: 0.05
                    robot_radius: 0.1
                    plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
                    inflation_layer:
                      inflation_radius: 0.2
                      cost_scaling_factor: 3.0
                    obstacle_layer:
                      enabled: True
                      observation_sources: scan
                      scan:
                        topic: /scan
                        max_obstacle_height: 2.0
                        clearing: True
                        marking: True
                        data_type: "LaserScan"
                    voxel_layer:
                      enabled: True
                      publish_voxel_map: True
                      origin_z: 0.0
                      z_resolution: 0.05
                      z_voxels: 16
                      mark_threshold: 0
                      observation_sources: pointcloud
                      pointcloud:
                        topic: /intel_realsense_r200_depth/points
                        clearing: True
                        marking: True
                        data_type: "PointCloud2"
                    static_layer:
                local_costmap_client:
                  ros__parameters:
                    use_sim_time: False
                local_costmap_rclcpp_node:
                  ros__parameters:
                    use_sim_time: False
              global_costmap:
                global_costmap:
                  ros__parameters:
                    update_frequency: 1.0
                    publish_frequency: 1.0
                    global_frame: map
                    use_sim_time: False
                    robot_radius: 0.1
                    resolution: 0.05
                    obstacle_layer:
                      enabled: True
                      scan:
                        topic: /scan
                        clearing: True
                        marking: True
                    voxel_layer:
                      enabled: True
                      origin_z: 0.0
                      z_resolution: 0.05
                      z_voxels: 16
                      mark_threshold: 0
                      pointcloud:
                        clearing: True
                        marking: True
                    static_layer:
                    inflation_layer:
                      cost_scaling_factor: 1.0
                      inflation_radius: 0.55
                global_costmap_client:
                  ros__parameters:
                    use_sim_time: False
                global_costmap_rclcpp_node:
                  ros__parameters:
                    use_sim_time: False
              map_server:
                ros__parameters:
                  use_sim_time: False
              map_saver:
                ros__parameters:
                  use_sim_time: False
                  save_map_timeout: 5000
                  free_thresh_default: 0.25
                  occupied_thresh_default: 0.65
              planner_server:
                ros__parameters:
                  use_sim_time: False
                  GridBased:
                    tolerance: 0.5
                    use_astar: false
                    allow_unknown: true
              planner_server_rclcpp_node:
                ros__parameters:
                  use_sim_time: False
              recoveries_server:
                ros__parameters:
                  cycle_frequency: 10.0
                  recovery_plugins: ["spin", "backup", "wait"]
                  spin:
                    plugin: "nav2_recoveries/Spin"
                  backup:
                    plugin: "nav2_recoveries/BackUp"
                  wait:
                    plugin: "nav2_recoveries/Wait"
                  global_frame: odom
                  transform_timeout: 0.1
                  use_sim_time: False
                  simulate_ahead_time: 2.0
                  max_rotational_vel: 1.0
                  min_rotational_vel: 0.4
                  rotational_acc_lim: 3.2
              robot_state_publisher:
                ros__parameters:
                  use_sim_time: False
              • 12818578961
                1281857896 @小鱼
                @小鱼 鱼哥,用最新的底板固件加上快速上手里面的fishbot.yaml可以很好实现导航,用那个fishbot_nav2.yaml就会加载不出地图,跑不了,应该是有缺东西
                • 7754058937
                  775405893
                  第三步,话题里面有scan,但出现警告是怎么回事😲
                    小鱼 技术大佬 @1281857896
                    @1281857896 对比下文件区别,可能哪里不对劲的
                      小鱼 技术大佬 @775405893
                      @775405893 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                      运行雷达的日志和上下文提供下
                      7754058937 1 条回复 最后回复 回复 引用 0
                      • 7754058937
                        775405893 @小鱼
                          小鱼 技术大佬 @775405893
                          @775405893 系统信息提供下:https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                            小鱼 技术大佬 @775405893
                            @775405893 雷达驱动意外挂了,重新运行下试试
                            • 7754058937
                              775405893 @小鱼
                              @小鱼 ubuntu 24 ,ros2是jazzy版,虚拟机桥接,雷达连的电脑热点。重启了一下还是这个问题,雷达地址能ping通。
                                小鱼 技术大佬 @775405893
                                @775405893 估计是版本问题,docker里面是22.04的,最好主机也用22.04,教程也是22.04的,还会有坑等着你。你那里有书吗,书上有源码驱动雷达的方法,只能用这个了,或者你需要等一段时间(半个月左右),我抽空时间来适配下24.04系统。
                                • 7754058937
                                  775405893 @小鱼
                                  @小鱼 好的谢谢,有书,我现在去翻一下😉
                                    小鱼 技术大佬 @775405893
                                    @775405893 第九章,你找找
                                    • 4
                                      466413819
                                      在ARM64架构下,ubuntu humble虚拟机
                                      zhao@zhao-virtual-machine:~$ xhost + && sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 fishros2/fishbot_laser
                                      exec /bin/bash: exec format error
                                      请问小鱼有没有解决办法,有没有类似 miroros agent 的离线解决方案?
                                        小鱼 技术大佬 @466413819
                                        @466413819 arm架构下不支持这个镜像,需要按照
                                        拓展1:FishBot配套雷达驱动教程(源码版)
                                        拓展3:FishBot 树莓派配置建图导航
                                          1664486711 @小鱼
