    fishbot 导航
    67
    239
    985.9k
      lzw @小鱼
      @1013006043
      这一步,先跑一次一键安装
        lzw @小鱼
        @小鱼 Screenshot from 2024-08-01 17-47-46.png 安装过了,最后还是这样。
          lzw @小鱼
            小鱼 技术大佬 @lzw
            @lzw 下次最好单独提问,不然容易看不到帖子。
            这个问题之前应该出现过,提示缺少的那个包装一下就好(最好复制粘贴错误,我也好复制粘贴给你命令)
            1.请使用ubuntu22.04 系统 2.请安装 joint_state_publisher
            就是这里
            sudo apt install ros-humble-joint-state-publisher
              lzw
              跟着文字做到第五步导航测试时输入命令出现以下错误:
              版本为22.04
              [INFO] [launch]: All log files can be found below /home/lzw/.ros/log/2024-08-02-19-20-35-132678-lzw-6309
              [ERROR] [launch]: Caught exception in launch (see debug for traceback): Caught multiple exceptions when trying to load file of format [py]:
              • IndentationError: expected an indented block after function definition on line 20 (navigation2.launch.py, line 21)
              • InvalidFrontendLaunchFileError: The launch file may have a syntax error, or its format is unknown
                小鱼 技术大佬 @lzw
                @lzw 工作空间不对,你的目录在主目录了,应该到工作空间下执行
                  等待修复
                  我在拉取项目,也就是文中第二个命令时,出现了下面的错误:正克隆到 'fishbot'...
                  接收对象中: 100% (84/84), 332.98 KiB | 1.06 MiB/s, 完成.
                  处理 delta 中: 100% (21/21), 完成.
                  子模组 'src/cartographer_code/cartographer'(https://github.91chi.fun/https://github.com/ros2/cartographer.git)已对路径 'src/cartographer_code/cartographer' 注册
                  子模组 'src/cartographer_code/cartographer_ros'(https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git)已对路径 'src/cartographer_code/cartographer_ros' 注册
                  子模组 'src/navigation'(https://github.91chi.fun/https://github.com/fishros/navigation2.git)已对路径 'src/navigation' 注册
                  正克隆到 '/home/zdd/fishbot/src/cartographer_code/cartographer'...
                  fatal: 无法访问 'https://github.91chi.fun/https://github.com/ros2/cartographer.git/':gnutls_handshake() failed: Error in the pull function.
                  fatal: 无法克隆 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' 到子模组路径 '/home/zdd/fishbot/src/cartographer_code/cartographer'
                  正克隆到 '/home/zdd/fishbot/src/cartographer_code/cartographer_ros'...希望鱼哥解答一下
                    小鱼 技术大佬 @2462331351
                    @2462331351 换个github代理试试
                      等待修复 @小鱼
                      @小鱼 换了,发现还是不行,我去我的windows(可以正常Google的)发现还是有错误```
                      Failed to clone 'src/cartographer_code/cartographer'. Retry scheduled
                      Cloning into 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer_ros'...
                      fatal: unable to access 'https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git/': Recv failure: Connection was reset
                      fatal: clone of 'https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git' into submodule path 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer_ros' failed
                      Failed to clone 'src/cartographer_code/cartographer_ros'. Retry scheduled
                      Cloning into 'C:/Users/ZDD/fishbot/src/navigation'...
                      fatal: unable to access 'https://github.91chi.fun/https://github.com/fishros/navigation2.git/': Recv failure: Connection was reset
                      fatal: clone of 'https://github.91chi.fun/https://github.com/fishros/navigation2.git' into submodule path 'C:/Users/ZDD/fishbot/src/navigation' failed
                      Failed to clone 'src/navigation'. Retry scheduled
                      Cloning into 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer'...
                      fatal: unable to access 'https://github.91chi.fun/https://github.com/ros2/cartographer.git/': Recv failure: Connection was reset
                      fatal: clone of 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' into submodule path 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer' failed
                      Failed to clone 'src/cartographer_code/cartographer' a second time, aborting
                        小鱼 技术大佬 @2462331351
                        @2462331351 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                        我说的代理是这里的网址
                          等待修复 @小鱼
                          @小鱼 我不太明白,请问
                          这个代理怎么换呀
                            等待修复
                              等待修复
                              我在运行sudo apt install ros-humble-joint-state-publisher发生下面的错误,我换源了但是还是会从清华源下载,真不知道怎么办了我的小车都连上了
                              code_text
                              正在分析软件包的依赖关系树... 完成
                              下列【新】软件包将被安装:
                              升级了 0 个软件包,新安装了 1 个软件包,要卸载 0 个软件包,有 383 个软件包未被升级。
                              需要下载 16.1 kB 的归档。
                              解压缩后会消耗 68.6 kB 的额外空间。
                              忽略:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 ros-humble-joint-state-publisher amd64 2.4.0-1jammy.20240728.222620
                              错误:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 ros-humble-joint-state-publisher amd64 2.4.0-1jammy.20240728.222620
                                无法发起与 mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2) 的连接 - connect (101: 网络不可达) 无法连接上 mirrors.tuna.tsinghua.edu.cn:80 (101.6.15.130),连接超时
                              E: 无法下载 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/pool/main/r/ros-humble-joint-state-publisher/ros-humble-joint-state-publisher_2.4.0-1jammy.20240728.222620_amd64.deb  无法发起与 mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2) 的连接 - connect (101: 网络不可达) 无法连接上 mirrors.tuna.tsinghua.edu.cn:80 (101.6.15.130),连接超时
                              zdd@zdd-Lenovo-YangTian-S550-14-API:~/fishbot$ ^C
                              zdd@zdd-Lenovo-YangTian-S550-14-API:~/fishbot$ ```
                                等待修复
                                我在运行到最后一步时,雷达镜像出现了下面的问题:```
                                [WARN] [1724764700.139124810] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                                  小鱼 技术大佬 @2462331351
                                  @2462331351 这个不是错误,可以忽略
                                    小鱼 技术大佬 @2462331351
                                    sudo apt --fix-missing
                                    • H
                                      yaoyao ROS2开发者
                                      最后由 HermitWJ 编辑
                                      一、下载与编译导航代码
                                      打开终端,输入下面的指令。
                                      cd fishbot
                                      执行最后一步colcon build报错
                                      以下是报错信息:
                                      Starting >>> fishbot_bringup
                                      Finished <<< fishbot_cartographer [1.76s]
                                      Finished <<< fishbot_navigation2 [1.83s]
                                      Target dependency
                                      does not exist
                                      Failed <<< fishbot_interfaces [4.23s, exited with code 1]
                                      Aborted <<< fishbot_description [4.57s]
                                      Aborted <<< fishbot_bringup [35.8s]
                                      Summary: 2 packages finished [36.8s]
                                      2 packages aborted: fishbot_bringup fishbot_description
                                        小鱼 技术大佬 @HermitWJ
                                        @HermitWJ 问一下你的操作系统版本信息,还有你把代码放到了哪个位置,不要放桌面之类的奇怪位置哦
                                        H 1 条回复 最后回复 回复 引用 0
                                          等待修复
                                          我这边的配置和鱼哥的一模一样,,ROS2humle,ubuntu22.04,但是我发现我在进行导航的时候啊,就是会小车走到一半就会终止,
                                          就像这样,请问这是怎么回事呢
                                            小鱼 技术大佬 @2462331351
                                            @2462331351 图太乱了,没有空间给小车走
