    fishbot 导航
    67
    239
    985.9k
      小鱼 技术大佬 @lzw
      @lzw 工作空间不对,你的目录在主目录了,应该到工作空间下执行
        等待修复
        我在拉取项目,也就是文中第二个命令时,出现了下面的错误:正克隆到 'fishbot'...
        接收对象中: 100% (84/84), 332.98 KiB | 1.06 MiB/s, 完成.
        处理 delta 中: 100% (21/21), 完成.
        子模组 'src/cartographer_code/cartographer'(https://github.91chi.fun/https://github.com/ros2/cartographer.git)已对路径 'src/cartographer_code/cartographer' 注册
        子模组 'src/cartographer_code/cartographer_ros'(https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git)已对路径 'src/cartographer_code/cartographer_ros' 注册
        子模组 'src/navigation'(https://github.91chi.fun/https://github.com/fishros/navigation2.git)已对路径 'src/navigation' 注册
        正克隆到 '/home/zdd/fishbot/src/cartographer_code/cartographer'...
        fatal: 无法访问 'https://github.91chi.fun/https://github.com/ros2/cartographer.git/':gnutls_handshake() failed: Error in the pull function.
        fatal: 无法克隆 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' 到子模组路径 '/home/zdd/fishbot/src/cartographer_code/cartographer'
        正克隆到 '/home/zdd/fishbot/src/cartographer_code/cartographer_ros'...希望鱼哥解答一下
          小鱼 技术大佬 @2462331351
          @2462331351 换个github代理试试
            等待修复 @小鱼
            @小鱼 换了,发现还是不行,我去我的windows(可以正常Google的)发现还是有错误```
            Failed to clone 'src/cartographer_code/cartographer'. Retry scheduled
            Cloning into 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer_ros'...
            fatal: unable to access 'https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git/': Recv failure: Connection was reset
            fatal: clone of 'https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git' into submodule path 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer_ros' failed
            Failed to clone 'src/cartographer_code/cartographer_ros'. Retry scheduled
            Cloning into 'C:/Users/ZDD/fishbot/src/navigation'...
            fatal: unable to access 'https://github.91chi.fun/https://github.com/fishros/navigation2.git/': Recv failure: Connection was reset
            fatal: clone of 'https://github.91chi.fun/https://github.com/fishros/navigation2.git' into submodule path 'C:/Users/ZDD/fishbot/src/navigation' failed
            Failed to clone 'src/navigation'. Retry scheduled
            Cloning into 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer'...
            fatal: unable to access 'https://github.91chi.fun/https://github.com/ros2/cartographer.git/': Recv failure: Connection was reset
            fatal: clone of 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' into submodule path 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer' failed
            Failed to clone 'src/cartographer_code/cartographer' a second time, aborting
              小鱼 技术大佬 @2462331351
              @2462331351 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
              我说的代理是这里的网址
                等待修复 @小鱼
                @小鱼 我不太明白,请问
                这个代理怎么换呀
                  等待修复
                    等待修复
                    我在运行sudo apt install ros-humble-joint-state-publisher发生下面的错误,我换源了但是还是会从清华源下载,真不知道怎么办了我的小车都连上了
                    code_text
                    正在分析软件包的依赖关系树... 完成
                    下列【新】软件包将被安装:
                    升级了 0 个软件包,新安装了 1 个软件包,要卸载 0 个软件包,有 383 个软件包未被升级。
                    需要下载 16.1 kB 的归档。
                    解压缩后会消耗 68.6 kB 的额外空间。
                    忽略:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 ros-humble-joint-state-publisher amd64 2.4.0-1jammy.20240728.222620
                    错误:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 ros-humble-joint-state-publisher amd64 2.4.0-1jammy.20240728.222620
                      无法发起与 mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2) 的连接 - connect (101: 网络不可达) 无法连接上 mirrors.tuna.tsinghua.edu.cn:80 (101.6.15.130),连接超时
                    E: 无法下载 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/pool/main/r/ros-humble-joint-state-publisher/ros-humble-joint-state-publisher_2.4.0-1jammy.20240728.222620_amd64.deb  无法发起与 mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2) 的连接 - connect (101: 网络不可达) 无法连接上 mirrors.tuna.tsinghua.edu.cn:80 (101.6.15.130),连接超时
                    zdd@zdd-Lenovo-YangTian-S550-14-API:~/fishbot$ ^C
                    zdd@zdd-Lenovo-YangTian-S550-14-API:~/fishbot$ ```
                      等待修复
                      我在运行到最后一步时,雷达镜像出现了下面的问题:```
                      [WARN] [1724764700.139124810] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                        小鱼 技术大佬 @2462331351
                        @2462331351 这个不是错误,可以忽略
                          小鱼 技术大佬 @2462331351
                          sudo apt --fix-missing
                          • H
                            yaoyao ROS2开发者
                            最后由 HermitWJ 编辑
                            一、下载与编译导航代码
                            打开终端,输入下面的指令。
                            cd fishbot
                            执行最后一步colcon build报错
                            以下是报错信息:
                            Starting >>> fishbot_bringup
                            Finished <<< fishbot_cartographer [1.76s]
                            Finished <<< fishbot_navigation2 [1.83s]
                            Target dependency
                            does not exist
                            Failed <<< fishbot_interfaces [4.23s, exited with code 1]
                            Aborted <<< fishbot_description [4.57s]
                            Aborted <<< fishbot_bringup [35.8s]
                            Summary: 2 packages finished [36.8s]
                            2 packages aborted: fishbot_bringup fishbot_description
                              小鱼 技术大佬 @HermitWJ
                              @HermitWJ 问一下你的操作系统版本信息,还有你把代码放到了哪个位置,不要放桌面之类的奇怪位置哦
                              H 1 条回复 最后回复 回复 引用 0
                                等待修复
                                我这边的配置和鱼哥的一模一样,,ROS2humle,ubuntu22.04,但是我发现我在进行导航的时候啊,就是会小车走到一半就会终止,
                                就像这样,请问这是怎么回事呢
                                  小鱼 技术大佬 @2462331351
                                  @2462331351 图太乱了,没有空间给小车走
                                  • H
                                    yaoyao ROS2开发者 @小鱼
                                    @小鱼 感谢小鱼,问题已解决
                                    • R
                                      ros_freshman 年度VIP @921203724
                                      @921203724 你这个问题解决了吗,我出现了同样的问题。@小鱼
                                      • R
                                        ros_freshman 年度VIP
                                        出现这个错误了,该怎么解决呢?rosdep已经用一键安装配置好了。
                                          小鱼 技术大佬 @ros_freshman
                                          @ros_freshman 可以跳过
                                          • R
                                            rex.chen80
                                            我使用的fishros镜像系统。
                                            但是colcon编译一直报错。有没有整合好的代码可以运行?
                                            ~ » git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                                            正克隆到 'fishbot'...
                                            接收对象中: 100% (84/84), 332.98 KiB | 1.81 MiB/s, 完成.
                                            ~ » cd fishbot
                                            fishbot (v1.0.0 o) » rosdep install --from-paths src --ignore-src -y -r # 安 装依赖
                                            fishbot (v1.0.0 o) » colcon build
                                            Finished <<< fishbot_description [0.60s]
                                            Finished <<< fishbot_cartographer [0.71s]
                                            Finished <<< fishbot_navigation2 [0.84s]
                                            execute_process(/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/l/j/h/bin/python3
                                            -m rosidl_adapter --package-name fishbot_interfaces --arguments-file
                                            /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter__arguments__fishbot_interfaces.json
                                            --output-dir
                                            /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter/fishbot_interfaces
                                            --output-file
                                            /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter/fishbot_interfaces.idls)
                                            returned error code 1:
                                            AttributeError processing template 'srv.idl.em'
                                            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 48, in evaluate_template
                                              _interpreter = em.Interpreter(
                                            AttributeError: module 'em' has no attribute 'Interpreter'
                                            File "/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/tree.linux.x64.0/miniconda/v3.10.0+23.9.0-0/lib/python3.10/runpy.py", line 196, in _run_module_as_main
                                            File "/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/tree.linux.x64.0/miniconda/v3.10.0+23.9.0-0/lib/python3.10/runpy.py", line 86, in _run_code
                                              exec(code, run_globals)
                                              sys.exit(main())
                                            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 24, in convert_to_idl
                                              return convert_srv_to_idl(
                                            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/srv/__init__.py", line 39, in convert_srv_to_idl
                                              expand_template('srv.idl.em', data, output_file, encoding='iso-8859-1')
                                              _interpreter.shutdown()
                                            Failed <<< fishbot_interfaces [0.89s, exited with code 1]
                                            Aborted <<< fishbot_bringup [1.08s]
                                            Summary: 3 packages finished [1.24s]
                                            1 package aborted: fishbot_bringup
