    fishbot 导航
    67
    239
    903.2k
      lzw
      跟着文字做到第五步导航测试时输入命令出现以下错误:
      版本为22.04
      [INFO] [launch]: All log files can be found below /home/lzw/.ros/log/2024-08-02-19-20-35-132678-lzw-6309
      [ERROR] [launch]: Caught exception in launch (see debug for traceback): Caught multiple exceptions when trying to load file of format [py]:
      • IndentationError: expected an indented block after function definition on line 20 (navigation2.launch.py, line 21)
      • InvalidFrontendLaunchFileError: The launch file may have a syntax error, or its format is unknown
        小鱼 技术大佬 @lzw
        @lzw 工作空间不对,你的目录在主目录了,应该到工作空间下执行
          等待修复
          我在拉取项目,也就是文中第二个命令时,出现了下面的错误:正克隆到 'fishbot'...
          接收对象中: 100% (84/84), 332.98 KiB | 1.06 MiB/s, 完成.
          处理 delta 中: 100% (21/21), 完成.
          子模组 'src/cartographer_code/cartographer'(https://github.91chi.fun/https://github.com/ros2/cartographer.git)已对路径 'src/cartographer_code/cartographer' 注册
          子模组 'src/cartographer_code/cartographer_ros'(https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git)已对路径 'src/cartographer_code/cartographer_ros' 注册
          子模组 'src/navigation'(https://github.91chi.fun/https://github.com/fishros/navigation2.git)已对路径 'src/navigation' 注册
          正克隆到 '/home/zdd/fishbot/src/cartographer_code/cartographer'...
          fatal: 无法访问 'https://github.91chi.fun/https://github.com/ros2/cartographer.git/':gnutls_handshake() failed: Error in the pull function.
          fatal: 无法克隆 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' 到子模组路径 '/home/zdd/fishbot/src/cartographer_code/cartographer'
          正克隆到 '/home/zdd/fishbot/src/cartographer_code/cartographer_ros'...希望鱼哥解答一下
            小鱼 技术大佬 @2462331351
            @2462331351 换个github代理试试
              等待修复 @小鱼
              @小鱼 换了,发现还是不行,我去我的windows(可以正常Google的)发现还是有错误```
              Failed to clone 'src/cartographer_code/cartographer'. Retry scheduled
              Cloning into 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer_ros'...
              fatal: unable to access 'https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git/': Recv failure: Connection was reset
              fatal: clone of 'https://github.91chi.fun/https://github.com/ros2/cartographer_ros.git' into submodule path 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer_ros' failed
              Failed to clone 'src/cartographer_code/cartographer_ros'. Retry scheduled
              Cloning into 'C:/Users/ZDD/fishbot/src/navigation'...
              fatal: unable to access 'https://github.91chi.fun/https://github.com/fishros/navigation2.git/': Recv failure: Connection was reset
              fatal: clone of 'https://github.91chi.fun/https://github.com/fishros/navigation2.git' into submodule path 'C:/Users/ZDD/fishbot/src/navigation' failed
              Failed to clone 'src/navigation'. Retry scheduled
              Cloning into 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer'...
              fatal: unable to access 'https://github.91chi.fun/https://github.com/ros2/cartographer.git/': Recv failure: Connection was reset
              fatal: clone of 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' into submodule path 'C:/Users/ZDD/fishbot/src/cartographer_code/cartographer' failed
              Failed to clone 'src/cartographer_code/cartographer' a second time, aborting
                小鱼 技术大佬 @2462331351
                @2462331351 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                我说的代理是这里的网址
                  等待修复 @小鱼
                  @小鱼 我不太明白,请问
                  这个代理怎么换呀
                    等待修复
                      等待修复
                      我在运行sudo apt install ros-humble-joint-state-publisher发生下面的错误,我换源了但是还是会从清华源下载,真不知道怎么办了我的小车都连上了
                      code_text
                      正在分析软件包的依赖关系树... 完成
                      下列【新】软件包将被安装:
                      升级了 0 个软件包,新安装了 1 个软件包,要卸载 0 个软件包,有 383 个软件包未被升级。
                      需要下载 16.1 kB 的归档。
                      解压缩后会消耗 68.6 kB 的额外空间。
                      忽略:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 ros-humble-joint-state-publisher amd64 2.4.0-1jammy.20240728.222620
                      错误:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 ros-humble-joint-state-publisher amd64 2.4.0-1jammy.20240728.222620
                        无法发起与 mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2) 的连接 - connect (101: 网络不可达) 无法连接上 mirrors.tuna.tsinghua.edu.cn:80 (101.6.15.130),连接超时
                      E: 无法下载 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/pool/main/r/ros-humble-joint-state-publisher/ros-humble-joint-state-publisher_2.4.0-1jammy.20240728.222620_amd64.deb  无法发起与 mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2) 的连接 - connect (101: 网络不可达) 无法连接上 mirrors.tuna.tsinghua.edu.cn:80 (101.6.15.130),连接超时
                      zdd@zdd-Lenovo-YangTian-S550-14-API:~/fishbot$ ^C
                      zdd@zdd-Lenovo-YangTian-S550-14-API:~/fishbot$ ```
                        等待修复
                        我在运行到最后一步时,雷达镜像出现了下面的问题:```
                        [WARN] [1724764700.139124810] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                          小鱼 技术大佬 @2462331351
                          @2462331351 这个不是错误,可以忽略
                            小鱼 技术大佬 @2462331351
                            sudo apt --fix-missing
                            • H
                              yaoyao ROS2开发者
                              最后由 HermitWJ 编辑
                              一、下载与编译导航代码
                              打开终端,输入下面的指令。
                              cd fishbot
                              执行最后一步colcon build报错
                              以下是报错信息:
                              Starting >>> fishbot_bringup
                              Finished <<< fishbot_cartographer [1.76s]
                              Finished <<< fishbot_navigation2 [1.83s]
                              Target dependency
                              does not exist
                              Failed <<< fishbot_interfaces [4.23s, exited with code 1]
                              Aborted <<< fishbot_description [4.57s]
                              Aborted <<< fishbot_bringup [35.8s]
                              Summary: 2 packages finished [36.8s]
                              2 packages aborted: fishbot_bringup fishbot_description
                                小鱼 技术大佬 @HermitWJ
                                @HermitWJ 问一下你的操作系统版本信息,还有你把代码放到了哪个位置,不要放桌面之类的奇怪位置哦
                                H 1 条回复 最后回复 回复 引用 0
                                  等待修复
                                  我这边的配置和鱼哥的一模一样,,ROS2humle,ubuntu22.04,但是我发现我在进行导航的时候啊,就是会小车走到一半就会终止,
                                  就像这样,请问这是怎么回事呢
                                    小鱼 技术大佬 @2462331351
                                    @2462331351 图太乱了,没有空间给小车走
                                    • H
                                      yaoyao ROS2开发者 @小鱼
                                      @小鱼 感谢小鱼,问题已解决
                                      • R
                                        ros_freshman 年度VIP @921203724
                                        @921203724 你这个问题解决了吗,我出现了同样的问题。@小鱼
                                        • R
                                          ros_freshman 年度VIP
                                          出现这个错误了,该怎么解决呢?rosdep已经用一键安装配置好了。
                                            小鱼 技术大佬 @ros_freshman
                                            @ros_freshman 可以跳过
