    nav2中amcl没有正常发布map->odom的TF变换
    Nav2
    nav2 amcl map odom mapserver
    9
    10
    7.1k
      liang0706
      您好,以下是我的问题描述,恳请各位看一下,是我配置文件,哪里出了问题? 有些疏忽没有注意到
      环境描述
      实体小车、 ubuntu24.04、 ros2-jazzy
      在使用nav2时amcl没有正常发布map->odom的变换,导致日志中显示:
      [component_container_isolated-1] [INFO] [1722479581.777346684] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      具体细节和上下文:
      1、小车激光雷达,里程计驱动正常
      2、构建的栅格地图信息可正常加载(如图1)
      3、amcl可正常进行生命周期管理(如图2 )
      4、amcl显示可正常订阅map话题(如图3)
      5、amcl生命周期显示正在激活状态(如图4)
      6、静态图层订阅/map话题(如图5)
      7、具体报错信息(INFO级别)(如图6)
      8、TF树(未发布map->odom的变换信息)、部分话题通讯见图7、8
      9、launch和具体params信息如下:
          # 1. 定位到包的地址
          robot_navigation2_dir = get_package_share_directory('robot_nav')
          # 2. 声明参数,获取配置文件路径
          use_sim_time = LaunchConfiguration('use_sim_time', default='false')
          map_yaml_path = LaunchConfiguration('map', default=os.path.join(robot_navigation2_dir, 'maps', 'map.yaml'))
          nav2_param_path = LaunchConfiguration('params_file', default=os.path.join(robot_navigation2_dir, 'param', 'robot_params.yaml'))
          # 3. 声明启动launch文件,传入:地图路径、是否使用仿真时间以及nav2参数文件
          nav2_bringup_launch = IncludeLaunchDescription(
              PythonLaunchDescriptionSource([nav2_bringup_dir, '/launch', '/bringup_launch.py']),
              launch_arguments={
                  'map': map_yaml_path,
                  'use_sim_time': use_sim_time,
                  'params_file': nav2_param_path
              }.items(),
      amcl:
        ros__parameters:
          alpha1: 0.2
          alpha2: 0.2
          alpha3: 0.2
          alpha4: 0.2
          alpha5: 0.2
          base_frame_id: "base_link"
      #    base_frame_id: "odom"
          beam_skip_distance: 0.5
          beam_skip_threshold: 0.3
          do_beamskip: false
          global_frame_id: "map"
          lambda_short: 0.1
          laser_max_range: 100.0
          laser_min_range: -1.0
          max_beams: 60
          max_particles: 2000
          min_particles: 500
          odom_frame_id: "odom"
          pf_err: 0.05
          pf_z: 0.99
          recovery_alpha_fast: 0.0
          recovery_alpha_slow: 0.0
          resample_interval: 1
          robot_model_type: "nav2_amcl::DifferentialMotionModel"
          save_pose_rate: 0.5
          sigma_hit: 0.2
          tf_broadcast: true
          transform_tolerance: 1.0
          update_min_a: 0.2
          update_min_d: 0.25
          z_hit: 0.5
          z_max: 0.05
          z_rand: 0.5
          z_short: 0.05
          scan_topic: scan
      bt_navigator:
        ros__parameters:
          global_frame: map
          robot_base_frame: base_link
          odom_topic: /odom
          bt_loop_duration: 10
          default_server_timeout: 20
          wait_for_service_timeout: 1000
          action_server_result_timeout: 900.0
          navigators: ["navigate_to_pose", "navigate_through_poses"]
          navigate_to_pose:
            plugin: "nav2_bt_navigator::NavigateToPoseNavigator"
          navigate_through_poses:
            plugin: "nav2_bt_navigator::NavigateThroughPosesNavigator"
          # plugin_lib_names is used to add custom BT plugins to the executor (vector of strings).
          # Built-in plugins are added automatically
          # plugin_lib_names: []
          error_code_names:
            - compute_path_error_code
            - follow_path_error_code
      controller_server:
        ros__parameters:
          controller_frequency: 20.0
          min_x_velocity_threshold: 0.001
          min_y_velocity_threshold: 0.5
          min_theta_velocity_threshold: 0.001
          failure_tolerance: 0.3
          progress_checker_plugins: ["progress_checker"]
          goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
          controller_plugins: ["FollowPath"]
          use_realtime_priority: false
          # Progress checker parameters
          progress_checker:
            plugin: "nav2_controller::SimpleProgressChecker"
            required_movement_radius: 0.5
            movement_time_allowance: 10.0
          # Goal checker parameters
          #precise_goal_checker:
          #  plugin: "nav2_controller::SimpleGoalChecker"
          #  xy_goal_tolerance: 0.25
          #  yaw_goal_tolerance: 0.25
          #  stateful: True
          general_goal_checker:
            stateful: True
          FollowPath:
            plugin: "nav2_mppi_controller::MPPIController"
            time_steps: 56
            model_dt: 0.05
            batch_size: 2000
            ax_max: 3.0
            ax_min: -3.0
            ay_max: 3.0
            az_max: 3.5
            vx_std: 0.2
            vy_std: 0.2
            wz_std: 0.4
            vx_max: 0.5
            vx_min: -0.35
            vy_max: 0.5
            wz_max: 1.9
            iteration_count: 1
            prune_distance: 1.7
            transform_tolerance: 0.1
            temperature: 0.3
            gamma: 0.015
            motion_model: "DiffDrive"
            visualize: true
            regenerate_noises: true
            TrajectoryVisualizer:
              trajectory_step: 5
              time_step: 3
            AckermannConstraints:
              min_turning_r: 0.2
            critics: [
              "ConstraintCritic", "CostCritic", "GoalCritic",
              "GoalAngleCritic", "PathAlignCritic", "PathFollowCritic",
              "PathAngleCritic", "PreferForwardCritic"]
            ConstraintCritic:
              enabled: true
              cost_power: 1
              cost_weight: 4.0
            GoalCritic:
              enabled: true
              cost_power: 1
              cost_weight: 5.0
              threshold_to_consider: 1.4
            GoalAngleCritic:
              enabled: true
              cost_power: 1
              cost_weight: 3.0
              threshold_to_consider: 0.5
            PreferForwardCritic:
              enabled: true
              cost_power: 1
              cost_weight: 5.0
            CostCritic:
              enabled: true
              cost_power: 1
              cost_weight: 3.81
              critical_cost: 300.0
              consider_footprint: true
              collision_cost: 1000000.0
              near_goal_distance: 1.0
              trajectory_point_step: 2
            PathAlignCritic:
              enabled: true
              cost_power: 1
              cost_weight: 14.0
              max_path_occupancy_ratio: 0.05
              trajectory_point_step: 4
              offset_from_furthest: 20
              use_path_orientations: false
            PathFollowCritic:
              enabled: true
              cost_power: 1
              cost_weight: 5.0
              offset_from_furthest: 5
            PathAngleCritic:
              enabled: true
              cost_power: 1
              cost_weight: 2.0
              offset_from_furthest: 4
              max_angle_to_furthest: 1.0
              mode: 0
            # TwirlingCritic:
            #   enabled: true
            #   twirling_cost_power: 1
            #   twirling_cost_weight: 10.0
      local_costmap:
        local_costmap:
          ros__parameters:
            update_frequency: 5.0
            publish_frequency: 2.0
            global_frame: odom
            rolling_window: true
            width: 3
            height: 3
            resolution: 0.05
            robot_radius: 0.22
            plugins: ["voxel_layer", "inflation_layer"]
            inflation_layer:
              cost_scaling_factor: 3.0
              inflation_radius: 0.70
            voxel_layer:
              plugin: "nav2_costmap_2d::VoxelLayer"
              enabled: True
              publish_voxel_map: True
              origin_z: 0.0
              z_resolution: 0.05
              z_voxels: 16
              max_obstacle_height: 2.0
              mark_threshold: 0
              observation_sources: scan
              scan:
                topic: /scan
                clearing: True
                marking: True
                data_type: "LaserScan"
                raytrace_max_range: 3.0
                raytrace_min_range: 0.0
                obstacle_max_range: 2.5
                obstacle_min_range: 0.0
            static_layer:
      global_costmap:
        global_costmap:
          ros__parameters:
            update_frequency: 1.0
            publish_frequency: 1.0
            global_frame: map
            robot_radius: 0.22
            resolution: 0.05
            track_unknown_space: true
            obstacle_layer:
              enabled: True
              scan:
                topic: /scan
                clearing: True
                marking: True
            static_layer:
            inflation_layer:
              inflation_radius: 0.25
      # The yaml_filename does not need to be specified since it going to be set by defaults in launch.
      # If you'd rather set it in the yaml, remove the default "map" value in the tb3_simulation_launch.py
      # file & provide full path to map below. If CLI map configuration or launch default is provided, that will be used.
      # map_server:
      #   ros__parameters:
      #     yaml_filename: ""
      map_saver:
        ros__parameters:
          save_map_timeout: 5.0
          free_thresh_default: 0.25
          occupied_thresh_default: 0.65
      planner_server:
        ros__parameters:
          expected_planner_frequency: 20.0
          planner_plugins: ["GridBased"]
          GridBased:
            plugin: "nav2_navfn_planner::NavfnPlanner"
            tolerance: 0.5
            use_astar: false
            allow_unknown: true
      smoother_server:
        ros__parameters:
          smoother_plugins: ["simple_smoother"]
          simple_smoother:
            plugin: "nav2_smoother::SimpleSmoother"
            tolerance: 1.0e-10
            max_its: 1000
            do_refinement: True
      behavior_server:
        ros__parameters:
          local_costmap_topic: local_costmap/costmap_raw
          global_costmap_topic: global_costmap/costmap_raw
          local_footprint_topic: local_costmap/published_footprint
          global_footprint_topic: global_costmap/published_footprint
          cycle_frequency: 10.0
          behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
          spin:
            plugin: "nav2_behaviors::Spin"
          backup:
            plugin: "nav2_behaviors::BackUp"
          drive_on_heading:
            plugin: "nav2_behaviors::DriveOnHeading"
          wait:
            plugin: "nav2_behaviors::Wait"
          assisted_teleop:
            plugin: "nav2_behaviors::AssistedTeleop"
          local_frame: odom
          global_frame: map
          simulate_ahead_time: 2.0
          max_rotational_vel: 1.0
          min_rotational_vel: 0.4
          rotational_acc_lim: 3.2
      waypoint_follower:
        ros__parameters:
          loop_rate: 20
          stop_on_failure: false
          waypoint_task_executor_plugin: "wait_at_waypoint"
          wait_at_waypoint:
            plugin: "nav2_waypoint_follower::WaitAtWaypoint"
            enabled: True
            waypoint_pause_duration: 200
      velocity_smoother:
        ros__parameters:
          smoothing_frequency: 20.0
          scale_velocities: False
          feedback: "OPEN_LOOP"
          max_velocity: [0.5, 0.0, 2.0]
          min_velocity: [-0.5, 0.0, -2.0]
          max_accel: [2.5, 0.0, 3.2]
          max_decel: [-2.5, 0.0, -3.2]
          odom_topic: "odom"
          odom_duration: 0.1
          deadband_velocity: [0.0, 0.0, 0.0]
          velocity_timeout: 1.0
      collision_monitor:
        ros__parameters:
          cmd_vel_in_topic: "cmd_vel_smoothed"
          cmd_vel_out_topic: "cmd_vel"
          state_topic: "collision_monitor_state"
          transform_tolerance: 0.2
          source_timeout: 1.0
          base_shift_correction: True
          stop_pub_timeout: 2.0
          # Polygons represent zone around the robot for "stop", "slowdown" and "limit" action types,
          # and robot footprint for "approach" action type.
          polygons: ["FootprintApproach"]
          FootprintApproach:
            type: "polygon"
            action_type: "approach"
            footprint_topic: "/local_costmap/published_footprint"
            time_before_collision: 1.2
            simulation_time_step: 0.1
            min_points: 6
            visualize: False
            enabled: True
          observation_sources: ["scan"]
          scan:
            type: "scan"
            topic: "scan"
            min_height: 0.15
            max_height: 2.0
            enabled: True
      docking_server:
        ros__parameters:
          controller_frequency: 50.0
          initial_perception_timeout: 5.0
          wait_charge_timeout: 5.0
          dock_approach_timeout: 30.0
          undock_linear_tolerance: 0.05
          undock_angular_tolerance: 0.1
          max_retries: 3
          base_frame: "base_link"
          fixed_frame: "odom"
          dock_backwards: false
          dock_prestaging_tolerance: 0.5
          # Types of docks
          dock_plugins: ['simple_charging_dock']
          simple_charging_dock:
            plugin: 'opennav_docking::SimpleChargingDock'
            docking_threshold: 0.05
            staging_x_offset: -0.7
            use_external_detection_pose: true
            use_battery_status: false # true
            use_stall_detection: false # true
            external_detection_timeout: 1.0
            external_detection_translation_x: -0.18
            external_detection_translation_y: 0.0
            external_detection_rotation_roll: -1.57
            external_detection_rotation_pitch: -1.57
            external_detection_rotation_yaw: 0.0
            filter_coef: 0.1
          # Dock instances
          # The following example illustrates configuring dock instances.
          # docks: ['home_dock']  # Input your docks here
          # home_dock:
          #   type: 'simple_charging_dock'
          #   frame: map
          #   pose: [0.0, 0.0, 0.0]
          controller:
            k_phi: 3.0
            k_delta: 2.0
            v_linear_min: 0.15
            v_linear_max: 0.15
      尝试过的解决方法:
      1、采用gmapping替换amcl输出map->odom转换,可正常进行导航,无错误,但是无法展示输入的先验地图。
      2、先启动map_server独立控制先验地图的生命周期管理,仍报无法找到map->odom的错误
      小鱼小 E 2 条回复 最后回复 回复 引用 0
        从你描述的问题和配置文件中,我们可以看到几个可能的原因和解决方案。首先,确保你的系统能够正确地生成和发布 map 到 odom 的变换,这是导航过程中非常重要的一个环节。这里有几个步骤可以帮助你检查和解决问题:
        1. 确认里程计 (Odometry) 的来源
        确保你的小车正在发布有效的里程计数据到 /odom 话题。这通常包括位置(position)和姿态(orientation)信息。你可以使用 rostopic echo /odom 来检查这些数据。
        2. 检查 AMCL 配置
        从你的 AMCL 配置来看,odom_frame_id 已经被设置为 "odom",这是正确的。但重要的是要确保 AMCL 能够接收到这个里程计数据。你可以通过查看 AMCL 的日志或使用调试工具来确认 AMCL 是否正在订阅 /odom 话题。
        3. 确保 TF 树完整
        TF(Transform Trees)是 ROS 中用于处理不同坐标系之间转换的系统。你需要确保 TF 树包含了从 map 到 odom 的转换。你可以使用 ros2 run tf2_ros tf2_echo map odom 来检查这一点。如果没有输出,说明 TF 树中没有这个转换。
        4. 检查其他节点的 TF 发布
        如果有其他节点(如里程计估计器或 SLAM 系统)负责发布 map 到 odom 的变换,请确保这些节点正在运行并正确配置。
        5. 使用 static_transform_publisher
        如果其他方法都不奏效,你可以尝试使用 static_transform_publisher 来临时添加一个从 map 到 odom 的静态变换。这可以通过在你的 launch 文件中添加以下内容来实现:
        # ... 其他 launch 配置 ...
            # ... 其他 launch 逻辑 ...
            # 添加静态变换
            static_transform_publisher = Node(
                package='tf2_ros',
                executable='static_transform_publisher',
                name='static_transform_publisher',
                output='screen',
                arguments=[
                    '0.0', '0.0', '0.0',  # translation
                    '0.0', '0.0', '0.0', '1.0',  # quaternion (w, x, y, z)
                    'map', 'odom',  # source_frame, target_frame
                    '10',  # period (in seconds)
            # ... 其他 launch 逻辑,包括返回所有节点 ...
        请注意,这个静态变换只是一个临时的解决方案,它假设 map 和 odom 之间的变换是固定的,这在许多情况下可能不是真的。
        6. 检查和更新 ROS 2 和 Nav2 的版本
        确保你使用的是 ROS 2 和 Nav2 的最新版本。有时候,一些已知的问题和错误会在新版本中得到修复。
        7. 查阅文档和社区
        查看 Nav2 的官方文档和社区论坛,看看是否有其他人遇到并解决了类似的问题。
        通过这些步骤,你应该能够诊断并解决 AMCL 没有发布 map 到 odom 变换的问题。如果问题仍然存在,可能需要更深入地检查你的系统配置或寻求更专业的帮助。
          小鱼 技术大佬 @liang0706
          @liang0706 看起来像amcl没有正常工作,正常导航过程中是由amcl提供从map到odom的变换的,重点检查这个模块
          • B
            BaiJianchou
            大佬,请问这个问题解决了吗,我也遇到了这个问题
            • E
              E94114049 @liang0706
              @liang0706 大佬,请问这个问题解决了吗,我也遇到了这个问题
              • Y
                yuan_0
                我也,
                我现在可以排查出的问题在amcl没有发布/amcl_pose话题的信息,导致没有map=>odom的问题,
                同时使用slam_toolbox同样无法得到map=>odom的话题。
                Y 1 条回复 最后回复 回复 引用 0
                • Y
                  yuan_0 @yuan_0
                  最新结果:缺少激光雷达到base的tf,同时/scan 的header名称与tf相对应
                  W 1 条回复 最后回复 回复 引用 0
                    whr @yuan_0
                    @yuan_0 大佬最后怎么改的
                    2 P 2 条回复 最后回复 回复 引用 0
                      2010580030 @whr
                      @小鱼 鱼哥,cartographer建图rviz显示 no map server和这个一样的问题嘛?
                      • P
                        p @whr
                        @whr 你好,想问问你解决了吗
