    配置激活map_server报错,Transitioning failed
    Nav2
    mapserver 建图
    7
    32
    22.0k
    • 追逐我的明天追
      追逐我的明天
      最后由 追逐我的明天 编辑
      问题:配置map_server时报错
      日志信息:
      gh@GH:~/d2lros2/fishbot_ws$ ros2 lifecycle set /map_server configure
      Transitioning failed.
      gh@GH:~/d2lros2/fishbot_ws/src/fishbot_cartographer/map$ ros2 run nav2_map_server map_server --ros-args --param yaml_filename:=map/fishbot_map.yaml
      [INFO] [1656741944.979581062] [map_server]:
              map_server lifecycle node launched.
              Waiting on external lifecycle transitions to activate
              See https://design.ros2.org/articles/node_lifecycle.html for more information.
      [INFO] [1656741944.979709069] [map_server]: Creating
      [INFO] [1656741951.041427042] [map_server]: Configuring
      [INFO] [map_io]: Loading yaml file: map/fishbot_map.yaml
      [ERROR] [map_io]: Failed processing YAML file map/fishbot_map.yaml at position (-1:-1) for reason: bad file: map/fishbot_map.yaml
      [ERROR] [1656741951.041649603] []: Caught exception in callback for transition 10
      [ERROR] [1656741951.041680812] []: Original error: Failed to load map yaml file: map/fishbot_map.yaml
      [WARN] [1656741951.041701873] []: Error occurred while doing error handling.
      [FATAL] [1656741951.041728823] [map_server]: Lifecycle node map_server does not have error state implemented
      用TAB补全ros2 lifecycle set /map_server没有configure提示
        小鱼 技术大佬 @追逐我的明天
        @追逐我的明天 在 配置激活map_server报错,Transitioning failed 中说:
        这个错误一般是map文件地址不对
        追逐我的明天追 1 条回复 最后回复 回复 引用 0
          @追逐我的明天 Nav2相关的发在nav2版块,发这个版块是看不到滴
          • 小鱼小 小鱼 从 中的 社区&开源 移动了该主题
          • 追逐我的明天追
            追逐我的明天 @小鱼
            @小鱼 改正地址后 在rviz中看不到地图
            日志信息如下:
            [INFO] [1656772741.967460246] [map_server]: Creating
            [INFO] [1656772760.901393518] [map_server]: Configuring
            [INFO] [map_io]: Loading yaml file: fishbot_map.yaml
            [DEBUG] [map_io]: resolution: 0.05
            [DEBUG] [map_io]: origin[0]: -3.35
            [DEBUG] [map_io]: origin[1]: -2.9
            [DEBUG] [map_io]: origin[2]: 0
            [DEBUG] [map_io]: free_thresh: 0.25
            [DEBUG] [map_io]: occupied_thresh: 0.65
            [DEBUG] [map_io]: mode: trinary
            [DEBUG] [map_io]: negate: 0
            [INFO] [map_io]: Loading image_file: ./fishbot_map.pgm
            [DEBUG] [map_io]: Read map ./fishbot_map.pgm: 134 X 119 map @ 0.05 m/cell
            [INFO] [1656772765.547893749] [map_server]: Activating
            [INFO] [1656772765.548063166] [map_server]: Creating bond (map_server) to lifecycle manager.
            小鱼小 劳动人民最光荣劳 2 条回复 最后回复 回复 引用 0
              小鱼 技术大佬 @追逐我的明天
              @追逐我的明天 下一步activate了吗
              • 追逐我的明天追
                追逐我的明天 @小鱼
                @小鱼 activate了 都成功了
                  小鱼 技术大佬 @追逐我的明天
                  @追逐我的明天 ros2 topic info /map -v
                  用上面指令看一下发布者的qos和订阅者是否相同,不用则改一下rviz里的配置
                  • 追逐我的明天追
                    追逐我的明天 @小鱼
                    最后由 追逐我的明天 编辑
                    gh@GH:~$ ros2 topic info /map -v
                    Type: nav_msgs/msg/OccupancyGrid
                    Publisher count: 1
                    Node name: map_server
                    Node namespace: /
                    Topic type: nav_msgs/msg/OccupancyGrid
                    Endpoint type: PUBLISHER
                    GID: 01.0f.ba.40.f1.19.40.6c.01.00.00.00.00.00.1f.03.00.00.00.00.00.00.00.00
                    QoS profile:
                      Reliability: RELIABLE
                      History (Depth): UNKNOWN
                      Durability: TRANSIENT_LOCAL
                      Lifespan: Infinite
                      Deadline: Infinite
                      Liveliness: AUTOMATIC
                      Liveliness lease duration: Infinite
                    Subscription count: 1
                    Node name: rviz
                    Node namespace: /
                    Endpoint type: SUBSCRIPTION
                    GID: 01.0f.ba.40.2a.1a.2d.5b.01.00.00.00.00.00.2c.04.00.00.00.00.00.00.00.00
                    QoS profile:
                      Durability: VOLATILE
                      Lifespan: Infinite
                      Deadline: Infinite
                    Durability不同,如何修改
                      小鱼 技术大佬 @追逐我的明天
                      @追逐我的明天 在rviz地图插件里面找一下,有这个选项
                      追逐我的明天追 2 条回复 最后回复 回复 引用 0
                      • 追逐我的明天追
                        追逐我的明天 @小鱼
                        @小鱼 修改后还是没有地图显示
                        • 追逐我的明天追
                          追逐我的明天 @小鱼
                          @小鱼 仍无法解决,已经将Qos配置成一样的
                            小鱼 技术大佬 @追逐我的明天
                            @追逐我的明天 你先启动rviz2,之后再来一次配置和激活
                            • 追逐我的明天追
                              追逐我的明天 @小鱼
                              最后由 追逐我的明天 编辑
                              @小鱼 启动rviz后激活又报了两个错
                              2022-07-03 11:53:13.420 [RTPS_TRANSPORT_SHM Error] Failed init_port fastrtps_port7425: open_and_lock_file failed -> Function open_port_internal
                              2022-07-03 11:53:13.420 [RTPS_TRANSPORT_SHM Error] Failed init_port fastrtps_port7427: open_and_lock_file failed -> Function open_port_internal
                              重启后不报错,但仍然无法加载地图
                                小鱼 技术大佬 @追逐我的明天
                                @追逐我的明天 这个重启下机器试试
                                • 追逐我的明天追
                                  追逐我的明天 @小鱼
                                  @小鱼 重启了但还是无法加载地图,后边用Nav2单点导航也无法加载
                                    小鱼 技术大佬 @追逐我的明天
                                    你再试试我的代码,我在humble调通后才上传的
                                    • 追逐我的明天追
                                      追逐我的明天 @小鱼
                                      @小鱼 就是用的你的😂
                                        小鱼 技术大佬 @追逐我的明天
                                        @追逐我的明天 从文档复制粘贴的,还是直接下载的仓库
                                        • 追逐我的明天追
                                          追逐我的明天 @小鱼
                                          @小鱼 粘贴了功能包
                                          小鱼小 2 条回复 最后回复 回复 引用 0
                                            小鱼 技术大佬 @追逐我的明天
                                            @追逐我的明天 从哪个仓库,humble版本的吗
