    拓展2:FishBot配套雷达驱动教程(源码版)
    fishbot 雷达板驱动
    18
    61
    80.8k
      等待修复 @17171680
      • Z
        zbohao7
        我在运行完代码开启rviz想查看雷达的scan,结果出现以下警告
        code_text
        ros2 launch ydlidar ydlidar_launch.py
        [INFO] [launch]: All log files can be found below /home/shakima/.ros/log/2025-03-12-00-54-55-396599-shakim-vm-7822
        [INFO] [ydlidar_node-1]: process started with pid [7833]
        [INFO] [static_transform_publisher-2]: process started with pid [7835]
        [static_transform_publisher-2] [WARN] [1741712096.499273694] []: Old-style arguments are deprecated; see --help for new-style arguments
        [static_transform_publisher-2] [INFO] [1741712096.553863666] [static_tf_pub_laser]: Spinning until stopped - publishing transform
        [static_transform_publisher-2] translation: ('0.020000', '0.000000', '0.000000')
        [ydlidar_node-1] [YDLIDAR]:Lidar running correctly ! The health status: good
        [ydlidar_node-1] [YDLIDAR] Connection established in [/dev/ttyUSB0][115200]:
        [ydlidar_node-1] Firmware version: 1.5
        [ydlidar_node-1] Hardware version: 1
        [ydlidar_node-1] Model: S4
        [ydlidar_node-1] Serial: 2022010500000077
        [ydlidar_node-1] [YDLIDAR]:Fixed Size: 370
        [ydlidar_node-1] [YDLIDAR]:Sample Rate: 3K
        [ydlidar_node-1] [YDLIDAR INFO] Current Sampling Rate : 3K
        [ydlidar_node-1] [YDLIDAR INFO] Now YDLIDAR is scanning ......
        [ydlidar_node-1] [WARN] [1741712151.422427968] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
        [ydlidar_node-1] [WARN] [1741712174.547511076] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
        [ydlidar_node-1] [WARN] [1741712184.172818572] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
          小鱼 技术大佬 @zbohao7
          @zbohao7 在 拓展2:FishBot配套雷达驱动教程(源码版) 中说:
          可以忽略,具体原因参考书籍第十章
          • 9
            945717873
            鱼哥,雷达转接板,是将雷达数据通过串口转WiFi,直接在电脑上通过虚拟的串口将进行把数据转化成scan话题的吗?没有经过mircoros发布到电脑agent上面吗?直接将雷达数据通过主控板驱动板esp32s3的WiFi发出可以吗?
              小鱼 技术大佬 @945717873
              @945717873 没有经过agent,雷达板自带wifi
              • M
                mmmkmmm
                帮忙看下:oragepi5 ubuntu22.04 环境,用串口直连雷达,启动报以下错,使用cutecom可以一直收到数据。
                (rosenv) orangepi@orangepi5:~/microros_ws/ydlidar/ydlidar_ros2$ ros2 launch ydlidar ydlidar_launch.py
                [INFO] [launch]: All log files can be found below /home/orangepi/.ros/log/2025-04-21-17-21-20-797657-orangepi5-4156
                [INFO] [ydlidar_node-1]: process started with pid [4168]
                [INFO] [static_transform_publisher-2]: process started with pid [4170]
                [static_transform_publisher-2] [WARN] [1745227281.397851091] []: Old-style arguments are deprecated; see --help for new-style arguments
                [static_transform_publisher-2] [INFO] [1745227281.474700624] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                [ydlidar_node-1] 547644041440 thread has been canceled
                [ydlidar_node-1] [CYdLidar] Failed to turn on the Lidar, because the lidar is blocked or the lidar hardware is faulty.
                [INFO] [ydlidar_node-1]: process has finished cleanly [pid 4168]
                  小鱼 技术大佬 @mmmkmmm
                  @mmmkmmm 雷达板有调整到串口模式吗
                  M 1 条回复 最后回复 回复 引用 0
                  • M
                    mmmkmmm @小鱼
                    @小鱼 有调到串口,orangepi上面cutecom都可以收到串口的数据。
                      小鱼 技术大佬 @mmmkmmm
                      @mmmkmmm 驱动里的串口号改了没,改了后有没有重新构建
                      • M
                        mmmkmmm @小鱼
                        @小鱼 进入到源码,修改串口编号ydlidar_ros2/params/ydlidar.yaml,一般是/dev/ttyUSB0
                        ydlidar_node:
                        ros__parameters:
                        port: /dev/ttyUSB0
                        frame_id: laser_frame
                        ignore_array: ""
                        这里已经有改了。
                          小鱼 技术大佬 @mmmkmmm
                          @mmmkmmm cutecom 看这个口有数据吗,这个口确定是雷达吗,有没有重新构建,接线是怎么接的
                          • M
                            mmmkmmm @小鱼
                              小鱼 技术大佬 @mmmkmmm
                              @mmmkmmm 看起来也是没问题,你到eai官网找找驱动工具测试一下看看
                              M 2 条回复 最后回复 回复 引用 0
                              • M
                                mmmkmmm @小鱼
                                @小鱼 EAI官网那个工具有下来测试了,WIN系统下,工具就死机了。orangepi 上面还没试。现在有没有一种可能,是供电问题?看官网手册上面有提到这点?
                                • M
                                  mmmkmmm @小鱼
                                  @小鱼 使用官网的EAI雷达测试工具,输出以下日志:
                                  [2025-04-22 13:47:58][INFO] Stop test
                                  [2025-04-22 13:47:58][INFO] 停止所有任务
                                  [2025-04-22 13:49:15][INFO] Start test
                                  [2025-04-22 13:49:15][INFO] 启动所有任务
                                  [2025-04-22 13:49:15][INFO] 设置雷达参数...
                                  [2025-04-22 13:49:15][INFO] SDK版本[1.2.6]
                                  [2025-04-22 13:49:15][INFO] 关闭DTR
                                  [2025-04-22 13:49:17][INFO] 关闭DTR
                                  [2025-04-22 13:49:18][WARN] 获取健康信息失败
                                  [2025-04-22 13:49:19][WARN] 获取底板设备信息失败
                                  [2025-04-22 13:49:20][WARN] 获取健康信息失败
                                  [2025-04-22 13:49:21][WARN] 获取底板设备信息失败
                                  [2025-04-22 13:49:21][INFO] 关闭DTR
                                  [2025-04-22 13:49:24][INFO] 关闭DTR
                                  [2025-04-22 13:49:26][INFO] 关闭DTR
                                  [2025-04-22 13:49:27][ERROR] 启动雷达失败
                                  [2025-04-22 13:49:27][ERROR] Failed to start lidar!
                                  • M
                                    mmmkmmm
                                    你好,现在orangepi上面报Failed to get scan 这个是什么原因?
                                    [INFO] [launch]: All log files can be found below /home/orangepi/.ros/log/2025-04-23-14-31-36-257614-orangepi5-7885
                                    [INFO] [ydlidar_node-1]: process started with pid [7896]
                                    [INFO] [static_transform_publisher-2]: process started with pid [7898]
                                    [static_transform_publisher-2] [WARN] [1745389896.446912442] []: Old-style arguments are deprecated; see --help for new-style arguments
                                    [static_transform_publisher-2] [INFO] [1745389896.473410801] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                                    [ydlidar_node-1] [YDLIDAR]:Fixed Size: 2050
                                    [ydlidar_node-1] [ERROR] [1745389915.174494029] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389919.145806575] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389921.941235704] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389923.942431973] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389925.943934945] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389927.945296170] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389929.946426398] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389931.947322422] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745389933.948195696] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745390015.568714267] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745390017.569674748] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745390019.570894808] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745390021.571772458] [ydlidar_node]: Failed to get scan
                                    [ydlidar_node-1] [ERROR] [1745390023.572790688] [ydlidar_node]: Failed to get scan
                                      小鱼 技术大佬 @mmmkmmm
                                      @mmmkmmm windows上的,板子没有设计DTR,后面的检测失败正常
                                        小鱼 技术大佬 @mmmkmmm
                                        @mmmkmmm 有电脑端吗,之前测试过wifi的方案吗
                                        • M
                                          mmmkmmm @小鱼
                                          @小鱼 是不是这个雷达板有问题啊,用官方的工具,启动雷达也不行b7232766-d50c-4ee1-bf95-2f314b0d5ef1-1745722556650.jpg
                                            小鱼 技术大佬 @mmmkmmm
                                            @mmmkmmm 你手里是哪个版本的雷达
