    拓展2:FishBot配套雷达驱动教程(源码版)
    fishbot 雷达板驱动
    18
    61
    90.0k
      小鱼 技术大佬 @distinctyz
      @distinctyz 看看驱动占用问题是否解决
        小鱼 技术大佬 @dong5515
        @dong5515 驱动时humble版本导致的,建议更换到humble
        • A
          anoddy1999
          問題: Failed to turn on the lidar,because the lidar is blocked or the lidar hardware is faulty
          設備: jetson orin nano
          Linux: Ubuntu22.04
          詳細: 我跟著教程5用windows燒錄了固件,最後也成功ping到 雷達的地址,接著用拓展教程2 完成了所有設定,可是最後卻反饋failed to turn on the lidar
          anthony@ubuntu:~/ydlidar_ros2$ ros2 launch ydlidar ydlidar_launch.py
          [INFO] [launch]: All log files can be found below /home/anthony/.ros/log/2024-09-14-10-38-52-043155-ubuntu-29717
          [INFO] [ydlidar_node-1]: process started with pid [29729]
          [INFO] [static_transform_publisher-2]: process started with pid [29731]
          [static_transform_publisher-2] [WARN] [1726281532.326946046] []: Old-style arguments are deprecated; see --help for new-style arguments
          [static_transform_publisher-2] [INFO] [1726281532.361383537] [static_tf_pub_laser]: Spinning until stopped - publishing transform
          [static_transform_publisher-2] translation: ('0.020000', '0.000000', '0.000000')
          [ydlidar_node-1] [YDLIDAR]:Lidar running correctly ! The health status: good
          [ydlidar_node-1] timout count: 1
          [ydlidar_node-1] timout count: 2
          [ydlidar_node-1] 281472560785632 thread has been canceled
          [ydlidar_node-1] [CYdLidar] Failed to turn on the Lidar, because the lidar is blocked or the lidar hardware is faulty.
          [INFO] [ydlidar_node-1]: process has finished cleanly [pid 29729]
          [static_transform_publisher-2] [INFO] [1726281607.981043452] [rclcpp]: signal_handler(signum=2)
          [INFO] [static_transform_publisher-2]: process has finished cleanly [pid 29731]
            小鱼 技术大佬 @anoddy1999
            @anoddy1999 在 拓展2:FishBot配套雷达驱动教程(源码版) 中说:
            最後也成功ping到
            是谁ping通的,windows还是jetson,各个的ip地址是什么报一下
            A 1 条回复 最后回复 回复 引用 0
            • A
              anoddy1999 @小鱼
              @小鱼 是jetson ping到的
              fishbot版的ip 是:192.168.1.79
              jetson的ip是:192.168.1.207
              WhatsApp Image 2024-09-14 at 22.52.52.jpeg WhatsApp Image 2024-09-14 at 22.56.33.jpeg
                小鱼 技术大佬 @anoddy1999
                @anoddy1999 雷达板的IP呢,两者要分开配哦,另外最好单独发帖,跟贴容易被吃掉
                Y 1 条回复 最后回复 回复 引用 0
                • 流
                  流浪呆猫 @154453683
                  @154453683 感谢,问题解决
                    yongyong @小鱼
                    @小鱼 这个雷达转接板的源码用什么打开呢,我用plateformio打不开
                      小鱼 技术大佬 @yongyong
                      @yongyong 看README
                        等待修复
                          等待修复 @17171680
                          • Z
                            zbohao7
                            我在运行完代码开启rviz想查看雷达的scan,结果出现以下警告
                            code_text
                            [INFO] [launch]: All log files can be found below /home/shakima/.ros/log/2025-03-12-00-54-55-396599-shakim-vm-7822
                            [INFO] [ydlidar_node-1]: process started with pid [7833]
                            [INFO] [static_transform_publisher-2]: process started with pid [7835]
                            [static_transform_publisher-2] [WARN] [1741712096.499273694] []: Old-style arguments are deprecated; see --help for new-style arguments
                            [static_transform_publisher-2] [INFO] [1741712096.553863666] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                            [ydlidar_node-1] [YDLIDAR] Connection established in [/dev/ttyUSB0][115200]:
                            [ydlidar_node-1] Firmware version: 1.5
                            [ydlidar_node-1] Hardware version: 1
                            [ydlidar_node-1] Model: S4
                            [ydlidar_node-1] Serial: 2022010500000077
                            [ydlidar_node-1] [YDLIDAR]:Fixed Size: 370
                            [ydlidar_node-1] [YDLIDAR]:Sample Rate: 3K
                            [ydlidar_node-1] [YDLIDAR INFO] Current Sampling Rate : 3K
                            [ydlidar_node-1] [YDLIDAR INFO] Now YDLIDAR is scanning ......
                            [ydlidar_node-1] [WARN] [1741712151.422427968] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                            [ydlidar_node-1] [WARN] [1741712174.547511076] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                            [ydlidar_node-1] [WARN] [1741712184.172818572] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                              小鱼 技术大佬 @zbohao7
                              @zbohao7 在 拓展2:FishBot配套雷达驱动教程(源码版) 中说:
                              可以忽略,具体原因参考书籍第十章
                              • 9
                                945717873
                                鱼哥,雷达转接板,是将雷达数据通过串口转WiFi,直接在电脑上通过虚拟的串口将进行把数据转化成scan话题的吗?没有经过mircoros发布到电脑agent上面吗?直接将雷达数据通过主控板驱动板esp32s3的WiFi发出可以吗?
                                  小鱼 技术大佬 @945717873
                                  @945717873 没有经过agent,雷达板自带wifi
                                  • M
                                    mmmkmmm
                                    帮忙看下:oragepi5 ubuntu22.04 环境,用串口直连雷达,启动报以下错,使用cutecom可以一直收到数据。
                                    (rosenv) orangepi@orangepi5:~/microros_ws/ydlidar/ydlidar_ros2$ ros2 launch ydlidar ydlidar_launch.py
                                    [INFO] [launch]: All log files can be found below /home/orangepi/.ros/log/2025-04-21-17-21-20-797657-orangepi5-4156
                                    [INFO] [ydlidar_node-1]: process started with pid [4168]
                                    [INFO] [static_transform_publisher-2]: process started with pid [4170]
                                    [static_transform_publisher-2] [WARN] [1745227281.397851091] []: Old-style arguments are deprecated; see --help for new-style arguments
                                    [static_transform_publisher-2] [INFO] [1745227281.474700624] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                                    [ydlidar_node-1] 547644041440 thread has been canceled
                                    [INFO] [ydlidar_node-1]: process has finished cleanly [pid 4168]
                                      小鱼 技术大佬 @mmmkmmm
                                      @mmmkmmm 雷达板有调整到串口模式吗
                                      M 1 条回复 最后回复 回复 引用 0
                                      • M
                                        mmmkmmm @小鱼
                                        @小鱼 有调到串口,orangepi上面cutecom都可以收到串口的数据。
                                          小鱼 技术大佬 @mmmkmmm
                                          @mmmkmmm 驱动里的串口号改了没,改了后有没有重新构建
                                          • M
                                            mmmkmmm @小鱼
                                            @小鱼 进入到源码,修改串口编号ydlidar_ros2/params/ydlidar.yaml,一般是/dev/ttyUSB0
                                            ydlidar_node:
                                            ros__parameters:
                                            port: /dev/ttyUSB0
                                            frame_id: laser_frame
                                            ignore_array: ""
                                            这里已经有改了。
