    拓展2:FishBot配套雷达驱动教程(源码版)
    fishbot 雷达板驱动
    18
    61
    90.1k
      小徐要早睡 @小鱼
      @小鱼 我现在建图时候一直发生漂移,/map坐标轴是移动的,/odom坐标轴固定不动
      <?xml version="1.0"?>
      <robot name="pigbot">
      <!-- Robot Footprint -->
      <link name="base_footprint"/>
      <child link="base_link"/>
      <origin xyz="0.0 0.0 0.166" rpy="0 0 0"/>
      </joint>
      <!-- base link -->
      <link name="base_link">
      <visual>
      <geometry>
      <box size="0.57 0.45 0.17"/>
      </geometry>
      <material name="blue">
      </material>
      </visual>
      </link>
      <!-- laser link -->
      <link name="laser_frame">
      <visual>
      <geometry>
      </geometry>
      <material name="black">
      </material>
      </visual>
      </link>
      <!-- laser joint -->
      <parent link="base_link" />
      <child link="laser_frame" />
      <origin xyz="0 0 0.075" />
      </joint>
      <!-- wheel link -->
      <link name="left_front_wheel_link">
      <visual>
      <geometry>
      <cylinder length="0.07" radius="0.166"/>
      </geometry>
      </material>
      </visual>
      </link>
      <joint name="left_front_wheel_joint" type="continuous">
      <child link="left_front_wheel_link" />
      <origin xyz="0.175 0.225 -0.085" />
      <axis xyz="0 1 0" />
      </joint>
      <link name="left_back_wheel_link">
      <visual>
      <geometry>
      </geometry>
      </material>
      </visual>
      </link>
      <joint name="left_back_wheel_joint" type="continuous">
      <child link="left_back_wheel_link" />
      <origin xyz="-0.175 0.225 -0.085" />
      </joint>
      <link name="right_front_wheel_link">
      <visual>
      <geometry>
      </geometry>
      </material>
      </visual>
      </link>
      <joint name="right_front_wheel_joint" type="continuous">
      <child link="right_front_wheel_link" />
      <origin xyz="0.175 -0.225 -0.085" />
      </joint>
      <link name="right_back_wheel_link">
      <visual>
      <geometry>
      </geometry>
      </material>
      </visual>
      </link>
      <joint name="right_back_wheel_joint" type="continuous">
      <child link="right_back_wheel_link" />
      <origin xyz="-0.175 -0.225 -0.085" />
      </joint>
      </robot>
      这是我的URDF,里程计话题发布和教程是一样的,请问中间有什么问题需要更改
      • D
        dong5515
        按照教程编译的时候会报错,我的pi上位机版本是:
        ROS_VERSION=2
        ROS_PYTHON_VERSION=3
        ROS_LOCALHOST_ONLY=0
        ROS_DISTRO=foxy
        • distinctyzD
          yzq15962508857
          你好,usb一连接到虚拟机,就断开是怎么回事啊。615f10d9-af52-4baa-b9eb-fd86e31b0deb-image.png ,谢谢!
            小鱼 技术大佬 @distinctyz
            @distinctyz 看看驱动占用问题是否解决
              小鱼 技术大佬 @dong5515
              @dong5515 驱动时humble版本导致的,建议更换到humble
              • A
                anoddy1999
                問題: Failed to turn on the lidar,because the lidar is blocked or the lidar hardware is faulty
                設備: jetson orin nano
                Linux: Ubuntu22.04
                詳細: 我跟著教程5用windows燒錄了固件,最後也成功ping到 雷達的地址,接著用拓展教程2 完成了所有設定,可是最後卻反饋failed to turn on the lidar
                anthony@ubuntu:~/ydlidar_ros2$ ros2 launch ydlidar ydlidar_launch.py
                [INFO] [launch]: All log files can be found below /home/anthony/.ros/log/2024-09-14-10-38-52-043155-ubuntu-29717
                [INFO] [ydlidar_node-1]: process started with pid [29729]
                [INFO] [static_transform_publisher-2]: process started with pid [29731]
                [static_transform_publisher-2] [WARN] [1726281532.326946046] []: Old-style arguments are deprecated; see --help for new-style arguments
                [static_transform_publisher-2] [INFO] [1726281532.361383537] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                [static_transform_publisher-2] translation: ('0.020000', '0.000000', '0.000000')
                [ydlidar_node-1] [YDLIDAR]:Lidar running correctly ! The health status: good
                [ydlidar_node-1] timout count: 1
                [ydlidar_node-1] timout count: 2
                [ydlidar_node-1] 281472560785632 thread has been canceled
                [ydlidar_node-1] [CYdLidar] Failed to turn on the Lidar, because the lidar is blocked or the lidar hardware is faulty.
                [INFO] [ydlidar_node-1]: process has finished cleanly [pid 29729]
                [static_transform_publisher-2] [INFO] [1726281607.981043452] [rclcpp]: signal_handler(signum=2)
                [INFO] [static_transform_publisher-2]: process has finished cleanly [pid 29731]
                  小鱼 技术大佬 @anoddy1999
                  @anoddy1999 在 拓展2:FishBot配套雷达驱动教程(源码版) 中说:
                  最後也成功ping到
                  是谁ping通的,windows还是jetson,各个的ip地址是什么报一下
                  A 1 条回复 最后回复 回复 引用 0
                  • A
                    anoddy1999 @小鱼
                    @小鱼 是jetson ping到的
                    fishbot版的ip 是:192.168.1.79
                    jetson的ip是:192.168.1.207
                    WhatsApp Image 2024-09-14 at 22.52.52.jpeg WhatsApp Image 2024-09-14 at 22.56.33.jpeg
                      小鱼 技术大佬 @anoddy1999
                      @anoddy1999 雷达板的IP呢,两者要分开配哦,另外最好单独发帖,跟贴容易被吃掉
                      Y 1 条回复 最后回复 回复 引用 0
                      • 流
                        流浪呆猫 @154453683
                        @154453683 感谢,问题解决
                          yongyong @小鱼
                          @小鱼 这个雷达转接板的源码用什么打开呢,我用plateformio打不开
                            小鱼 技术大佬 @yongyong
                            @yongyong 看README
                              等待修复
                                等待修复 @17171680
                                • Z
                                  zbohao7
                                  我在运行完代码开启rviz想查看雷达的scan,结果出现以下警告
                                  code_text
                                  [INFO] [launch]: All log files can be found below /home/shakima/.ros/log/2025-03-12-00-54-55-396599-shakim-vm-7822
                                  [INFO] [ydlidar_node-1]: process started with pid [7833]
                                  [INFO] [static_transform_publisher-2]: process started with pid [7835]
                                  [static_transform_publisher-2] [WARN] [1741712096.499273694] []: Old-style arguments are deprecated; see --help for new-style arguments
                                  [static_transform_publisher-2] [INFO] [1741712096.553863666] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                                  [ydlidar_node-1] [YDLIDAR] Connection established in [/dev/ttyUSB0][115200]:
                                  [ydlidar_node-1] Firmware version: 1.5
                                  [ydlidar_node-1] Hardware version: 1
                                  [ydlidar_node-1] Model: S4
                                  [ydlidar_node-1] Serial: 2022010500000077
                                  [ydlidar_node-1] [YDLIDAR]:Fixed Size: 370
                                  [ydlidar_node-1] [YDLIDAR]:Sample Rate: 3K
                                  [ydlidar_node-1] [YDLIDAR INFO] Current Sampling Rate : 3K
                                  [ydlidar_node-1] [YDLIDAR INFO] Now YDLIDAR is scanning ......
                                  [ydlidar_node-1] [WARN] [1741712151.422427968] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                                  [ydlidar_node-1] [WARN] [1741712174.547511076] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                                  [ydlidar_node-1] [WARN] [1741712184.172818572] [ydlidar_node]: New subscription discovered on topic '/scan', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
                                    小鱼 技术大佬 @zbohao7
                                    @zbohao7 在 拓展2:FishBot配套雷达驱动教程(源码版) 中说:
                                    可以忽略,具体原因参考书籍第十章
                                    • 9
                                      945717873
                                      鱼哥,雷达转接板,是将雷达数据通过串口转WiFi,直接在电脑上通过虚拟的串口将进行把数据转化成scan话题的吗?没有经过mircoros发布到电脑agent上面吗?直接将雷达数据通过主控板驱动板esp32s3的WiFi发出可以吗?
                                        小鱼 技术大佬 @945717873
                                        @945717873 没有经过agent,雷达板自带wifi
                                        • M
                                          mmmkmmm
                                          帮忙看下:oragepi5 ubuntu22.04 环境,用串口直连雷达,启动报以下错,使用cutecom可以一直收到数据。
                                          (rosenv) orangepi@orangepi5:~/microros_ws/ydlidar/ydlidar_ros2$ ros2 launch ydlidar ydlidar_launch.py
                                          [INFO] [launch]: All log files can be found below /home/orangepi/.ros/log/2025-04-21-17-21-20-797657-orangepi5-4156
                                          [INFO] [ydlidar_node-1]: process started with pid [4168]
                                          [INFO] [static_transform_publisher-2]: process started with pid [4170]
                                          [static_transform_publisher-2] [WARN] [1745227281.397851091] []: Old-style arguments are deprecated; see --help for new-style arguments
                                          [static_transform_publisher-2] [INFO] [1745227281.474700624] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                                          [ydlidar_node-1] 547644041440 thread has been canceled
                                          [INFO] [ydlidar_node-1]: process has finished cleanly [pid 4168]
                                            小鱼 技术大佬 @mmmkmmm
                                            @mmmkmmm 雷达板有调整到串口模式吗
                                            M 1 条回复 最后回复 回复 引用 0
