    [FishBotCamera]3.结合YOLO实现检测
    fishbotcamera yolo 检测
    19
    67
    84.0k
      小鱼 技术大佬 @2652794104
      @2652794104 把右边终端的所有日志复制粘贴出来看看
        2652794104 @小鱼
        @小鱼 mmexport1742557560588.png mmexport1742557572037.png mmexport1742557564295.png mmexport1742557570033.png mmexport1742557567641.png
          小鱼 技术大佬 @2652794104
          @2652794104 感觉你电脑yolo没安装好
            2652794104 @小鱼
            @小鱼 但卸载后重新安装了还是不行,我在Ubuntu终端的情况如下VirtualBox:~/fishbot_ws/src$ cd ~/fishbot_ws/ colcon build source install/setup.bash Starting >>> fishbot_camera Starting >>> yolov5_ros2 /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) [0.584s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'yolov5_ros2' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future) --- stderr: yolov5_ros2 /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) Traceback (most recent call last): File "/home/huan/fishbot_ws/src/yolov5_ros2/setup.py", line 7, in <module> setup( File "/home/huan/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup return distutils.core.setup(**attrs) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup return run_commands(dist) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands dist.run_commands() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_commands self.run_command(cmd) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/dist.py", line 1104, in run_command super().run_command(command) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1021, in run_command cmd_obj.run() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run self.find_sources() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources mm.run
              mmexport1743428498958.png mmexport1743428500801.png 在执行colcon build的这一步时候出现以下报错该如何处理
              小鱼小 2 条回复 最后回复 回复 引用 0
                小鱼 技术大佬 @2652794104
                @2652794104 是不是 setup 的版本有问题
                  小鱼 技术大佬 @2652794104
                  @2652794104 编译其他功能包会这样子吗
                    2652794104 @小鱼
                    @小鱼 编译其他功能包好像没出现类似的
                    小鱼小 2 条回复 最后回复 回复 引用 1
                      小鱼 技术大佬 @2652794104
                      @2652794104 日志看起来很奇怪,换台电脑试试可以不可以编译
                        小鱼 技术大佬 @2652794104
                        @2652794104 https://blog.csdn.net/qq_38196449/article/details/143998597
                        看下这个
                          2652794104 @小鱼
                          @小鱼 谢谢大佬,解决了
                            萌新
                            小鱼,这个用CPU会有点卡,可以用GPU吗,启动时代码改成gpu好像显示只能用cpu或者跳过
                              小鱼 技术大佬 @2431039560
                              @2431039560 这个要看yolo那边的了
                              • J
                                jkr
                                ImportError: cannot import name 'Detect' from 'models.yolo' (/home/jkr/.local/lib/python3.10/site-packages/ultralytics/models/yolo/init.py)
                                ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
                                在输入这段代码后会显示这个错误
                                J 小鱼小 2 条回复 最后回复 回复 引用 0
                                • J
                                  jkr @jkr
                                    小鱼 技术大佬 @jkr
                                    @jkr yolo安装问题吧,重装试试
                                    J 2 条回复 最后回复 回复 引用 0
                                    • J
                                      jkr @小鱼
                                      @小鱼 重装了一边不太行
                                      • J
                                        jkr @小鱼
                                        @小鱼 (1) In PyTorch 2.6, we changed the default value of the weights_only argument in torch.load from False to True. Re-running torch.load with weights_only set to False will likely succeed, but it can result in arbitrary code execution. Do it only if you got the file from a trusted source.
                                        (2) Alternatively, to load with weights_only=True please check the recommended steps in the following error message.
                                        WeightsUnpickler error: Unsupported global: GLOBAL numpy.core.multiarray._reconstruct was not an allowed global by default. Please use torch.serialization.add_safe_globals([numpy.core.multiarray._reconstruct]) or the torch.serialization.safe_globals([numpy.core.multiarray._reconstruct]) context manager to allowlist this global if you trust this class/function.
                                        重运行完报这个错
                                        • zxcpjpZ
                                          zxcpjp
                                          最后由 zxcpjp 编辑
                                          要怎么调节阈值啊@小鱼
                                          zxcpjpZ 1 条回复 最后回复 回复 引用 0
                                          • zxcpjpZ
                                            zxcpjp @zxcpjp
                                            @小鱼 要怎么调节置信度阈值啊 @小鱼
