    [FishBotCamera]3.结合YOLO实现检测
    fishbotcamera yolo 检测
    19
    67
    83.9k
      小鱼 技术大佬 @1004461581
      @1004461581 👍
      • P
        pengzhju
        sudo apt update
        sudo apt install python3-pip ros-$ROS_DISTRO-vision-msgs
        pip3 install -i https://pypi.tuna.tsinghua.edu.cn/simple yolov5
        为什么运行上面指令之后,我所有曾经成功编译过的代码现在colcon build 之后都会出错了,以前面FishBotCamera为例,我可以成功运行了,但是按照 “3.结合YOLO实现检测”内容操作之后,再运行前面的FishBotCamera,就会出现colcon build 错误,错误指示如下:
        tarting >>> fishbot_camera
        /home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:261: UserWarning: Unknown distribution option: 'tests_require'
        warnings.warn(msg)
        --- stderr: fishbot_camera
        warnings.warn(msg)
        File "/home/hance/fishbot_ws/src/fishbot_camera/setup.py", line 5, in <module>
        setup(
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
        return distutils.core.setup(**attrs)
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 183, in setup
        return run_commands(dist)
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 199, in run_commands
        dist.run_commands()
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 954, in run_commands
        self.run_command(cmd)
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
        super().run_command(command)
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 973, in run_command
        cmd_obj.run()
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
        self.find_sources()
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
        mm.run()
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 546, in run
        self.prune_file_list()
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
        super().prune_file_list()
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
        base_dir = self.distribution.get_fullname()
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 267, in get_fullname
        return _distribution_fullname(self.get_name(), self.get_version())
        File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 285, in _distribution_fullname
        canonicalize_version(version, strip_trailing_zero=False),
        TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero'
        Failed <<< fishbot_camera [4.58s, exited with code 1]
        Summary: 0 packages finished [5.19s]
        1 package failed: fishbot_camera
        1 package had stderr output: fishbot_camera
        小鱼小 1 2 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @pengzhju
          @pengzhju 在 [FishBotCamera]3.结合YOLO实现检测 中说:
          setuptools
          什么系统版本,是不是操作后不小心更新了 setuptools 版本
          P 2 条回复 最后回复 回复 引用 0
          • P
            pengzhju @小鱼
            @小鱼 对的小鱼,应该问题出在了setuptools上,这个需要怎么解决呀?
              小鱼 技术大佬 @pengzhju
              @pengzhju 搜搜默认版本和怎么回退,我帮你看下我的
              fishros$ pip list| grep setuptools
              setuptools                           59.6.0
              • P
                pengzhju @小鱼
                @小鱼 我的是Ubuntu22.04 humble,是按照图片这个步骤来的,可能我哪里出错了。好的小鱼,我先试一下,谢谢呀
                  2290305520 @1004461581
                  @1004461581 请问一下是怎么解决的
                    @小鱼 请问我运行这段命令后就这样不动了是什么原因?
                    ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
                    /usr/lib/python3/dist-packages/requests/init.py:87: RequestsDependencyWarning: urllib3 (2.2.3) or chardet (4.0.0) doesn't match a supported version!
                    warnings.warn("urllib3 ({}) or chardet ({}) doesn't match a supported "
                    [INFO] [1732460432.020769982] [yolov5_ros2]: Current ROS 2 distribution: humble
                    [INFO] [1732460432.127483045] [yolov5_ros2]: default_camera_info: [476.7030836014194, 0.0, 400.5, 0.0, 476.7030836014194, 400.5, 0.0, 0.0, 1.0]
                    [0.0, 0.0, 0.0, 0.0, 0.0]
                      小鱼 技术大佬 @2290305520
                      @2290305520 是不是没有图像数据
                        2290305520 @小鱼
                        @小鱼 是的,没有图像数据
                          小鱼 技术大佬 @2290305520
                          @2290305520 没有数据检查下驱动
                          R 1 条回复 最后回复 回复 引用 0
                            154253494 @小鱼
                              154253494 @pengzhju
                              • R
                                ros2_fresh @小鱼
                                @小鱼 小鱼老师,我检查了驱动,显示的有帧率,也有视频图像,但就是看不到检测结果,请问是怎么回事?
                                  小鱼 技术大佬 @ros2_fresh
                                  @ros2_fresh 看看是否有报错的地方,node graph 连接是否正常
                                  • R
                                    ros2_fresh @小鱼
                                    @小鱼 换了个文件夹,重新编译就好了。可能是编译的问题,
                                      2280322272 @小鱼
                                      @小鱼 header:
                                      stamp:
                                      sec: 1740455780
                                      nanosec: 215156274
                                      frame_id: camera
                                      detections:
                                      • header:
                                        stamp:
                                        sec: 0
                                        nanosec: 0
                                        frame_id: ''
                                        results:
                                        • hypothesis:
                                          class_id: chair
                                          score: 0.5549157857894897
                                          pose:
                                          pose:
                                          position:
                                          x: -0.15733063741351616
                                          y: -0.26011998719034674
                                          z: 0.0
                                          orientation:
                                          x: 0.0
                                          y: 0.0
                                          z: 0.0
                                          w: 1.0
                                          covariance:
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                          • 0.0
                                            bbox:
                                            center:
                                            x: 325.5
                                            y: 276.5
                                            theta: 0.0
                                            size_x: 95.0
                                            size_y: 53.0
                                      这是我运行得到的结果,我希望可以通过话题中‘position’引导机器人运动,可否解释下这个坐标的具体计算方式?
                                        2075605318 年度VIP
                                        lwb@Lwb:~$ cd ~/fishbot_ws/
                                        colcon build
                                        source install/setup.bash
                                        Starting >>> yolov5_ros2
                                        /home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:270: UserWarning: Unknown distribution option: 'tests_require'
                                        warnings.warn(msg)
                                        [0.351s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'yolov5_ros2' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
                                        --- stderr: yolov5_ros2
                                        warnings.warn(msg)
                                        File "/home/lwb/fishbot_ws/src/yolov5_ros2/setup.py", line 7, in <module>
                                        setup(
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
                                        dist.run_commands()
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 983, in run_commands
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_command
                                        cmd_obj.run()
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
                                        self.find_sources()
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
                                        mm.run()
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 548, in run
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 272, in get_fullname
                                        File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 290, in _distribution_fullname
                                        Failed <<< yolov5_ros2 [0.84s, exited with code 1]
                                        Summary: 0 packages finished [0.96s]
                                        1 package failed: yolov5_ros2
                                        1 package had stderr output: yolov5_ros2
                                        lwb@Lwb:~/fishbot_ws$ ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
                                        Package 'yolov5_ros2' not found
                                        编译时报错,yolov5已安装,前面的步骤没有问题
                                        1 条回复 最后回复 回复 引用 1
                                          2075605318 年度VIP
                                          @小鱼 在 [FishBotCamera]3.结合YOLO实现检测 中说:
                                          pub_result_img:=True
                                          这个代码默认是物体检测,我想用这个yolo5来实现色块识别并控制fishbot跟踪要怎样实现
                                            mmexport1742526264787.png mmexport1742526267321.png 大佬,执行以上步骤的时候出现下图问题怎么办?
