一键安装+Docker 安装ros melodic失败
版本:VMware 虚拟机 Ubuntu18.04
源:国内阿里云根据小鱼的视频教程步骤《一键安装+Docker》操作,提示已成功创建melodic1 容器:
请输入指令控制melodic1: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
t
/home/qlm/.fishros/bin/melodic1: line 10: docker: command not found提示错误:docker: command not found,同时也没有成功安装上VScode。
尝试操作1:重新再来一次“一键安装”,并且也提示成功创建melodic2容器,但是依旧出现了上面的错误。
尝试操作2:原本以为是因为没有配置环境变量,系统识别不了docker命令,所以会报错,但是根据CSDN的修改方案去走,还是没能解决问题。
希望大家给点解决方案,谢谢!
@Dawn丶 是Docker没装上的原因,你的虚拟机是什么架构,amd64/arm/i386?
@小鱼 Linux ubuntu 5.4.0-84-generic #94~18.04.1-Ubuntu SMP Thu Aug 26 23:17:46 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
qlm@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
--2022-07-04 03:38:27-- http://fishros.com/install
--2022-07-04 03:38:27-- http://fishros.com/install/
Length: 543 [application/octet-stream]
Saving to: ‘fishros’fishros 100%[===================>] 543 --.-KB/s in 0s
2022-07-04 03:38:27 (88.2 MB/s) - ‘fishros’ saved [543/543]
[sudo] password for qlm:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:The following packages have unmet dependencies:
gsettings-desktop-schemas : Breaks: mutter (< 3.31.4) but 3.28.4+git20200505-0ubuntu18.04.2 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
--2022-07-04 03:38:32-- http://fishros.com/install/install1s/tools/base.py
Length: 39925 (39K) [application/octet-stream]
Saving to: ‘/tmp/fishinstall/tools/base.py’/tmp/fishinstall/to 100%[===================>] 38.99K --.-KB/s in 0.05s
2022-07-04 03:38:32 (752 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [39925/39925]
[-]Result:success基础检查通过...
======一键安装已开源,请放心使用:https://github.com/fishros/install=======.-~~~~~~~~~-._ _.-~~~~~~~~~-. __.' ~. .~ `.__ .'// 开卷有益 \./ 书山有路 \ `. .'// 可以多看看小鱼的文章 | 关注公众号鱼香ROS \ `. .'// .-~"~~~~-._ | _,-~~~~"~-. \`. .'//.-" `-. | .-' "-.\`. .'//______.============-.. \ | / ..-============.______\`. .'______________________________\|/______________________________` ----------------------------------------------------------------------RUN Choose Task:[请输入括号内的数字]
---众多工具,等君来用---
[6]:一键安装:nodejs
[7]:一键安装:VsCode开发工具
[8]:一键安装:Docker
[10]:一键安装:微信(可以在Linux上使用的微信)
[77]:测试模式:运行自定义工具测试
[0]:quit
请输入[]内的数字以选择:11
--2022-07-04 03:38:40-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
Length: 11266 (11K) [application/octet-stream]
Saving to: ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’/tmp/fishinstall/to 100%[===================>] 11.00K --.-KB/s in 0s
2022-07-04 03:38:40 (56.5 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’ saved [11266/11266]
--2022-07-04 03:38:40-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
Length: 1264 (1.2K) [application/octet-stream]
Saving to: ‘/tmp/fishinstall/tools/tool_install_vscode.py’/tmp/fishinstall/to 100%[===================>] 1.23K --.-KB/s in 0s
2022-07-04 03:38:40 (131 MB/s) - ‘/tmp/fishinstall/tools/tool_install_vscode.py’ saved [1264/1264]
--2022-07-04 03:38:40-- http://fishros.com/install/install1s/tools/tool_install_docker.py
Length: 2401 (2.3K) [application/octet-stream]
Saving to: ‘/tmp/fishinstall/tools/tool_install_docker.py’/tmp/fishinstall/to 100%[===================>] 2.34K --.-KB/s in 0s
2022-07-04 03:38:40 (217 MB/s) - ‘/tmp/fishinstall/tools/tool_install_docker.py’ saved [2401/2401]
欢迎使用一键安装ROS-Docker版,支持所有版本ROS,本工具由作者小鱼提供
================================1.版本选择======================================
[1]:noetic
[2]:humble
[3]:foxy
[4]:galactic
[5]:melodic
[6]:rolling
[7]:kinetic
[8]:eloquent
[9]:dashing
[10]:crystal
[11]:bouncy
[12]:ardent
[13]:lunar
[14]:indigo
[0]:quit
请输入[]内的数字以选择:5
你选择了melodic(ROS1),该版本目前状态:长期支持
================================2.安装Docker======================================
欢迎使用一键安装Docker,支持amd64和arm64架构系统,本工具由作者alyssa提供
开始根据系统架构,为你下载对应版本的docker~
[|]Get:10 http://mirrors.aliyun.com/ubuntu focal-security/main amd64 Packages [1[-]Get:11 http://mirrors.aliyun.com/ubuntu focal-security/main amd64 DEP-11 Meta[/]Get:12 http://mirrors.aliyun.com/ubuntu focal-security/universe amd64 DEP-11 []Get:13 http://mirrors.aliyun.com/ubuntu focal-security/multiverse amd64 DEP-1[|]Get:14 http://mirrors.aliyun.com/ubuntu focal-updates/main amd64 DEP-11 Metad[-]Get:15 http://mirrors.aliyun.com/ubuntu focal-updates/universe amd64 DEP-11 M[/]Get:16 http://mirrors.aliyun.com/ubuntu focal-updates/multiverse amd64 DEP-11[]Get:17 http://mirrors.aliyun.com/ubuntu focal-proposed/restricted Sources [13[-]Get:19 http://mirrors.aliyun.com/ubuntu focal-proposed/universe Sources [24.3[/]Get:20 http://mirrors.aliyun.com/ubuntu focal-proposed/main i386 Packages [74[]Get:21 http://mirrors.aliyun.com/ubuntu focal-proposed/main amd64 Packages [3[|]Get:22 http://mirrors.aliyun.com/ubuntu focal-proposed/main Translation-en [6[-]Get:23 http://mirrors.aliyun.com/ubuntu focal-proposed/main amd64 DEP-11 Meta[/]Get:24 http://mirrors.aliyun.com/ubuntu focal-proposed/restricted amd64 Packa[]Get:25 http://mirrors.aliyun.com/ubuntu focal-proposed/restricted Translation[|]Get:26 http://mirrors.aliyun.com/ubuntu focal-proposed/universe amd64 Package[-]Get:27 http://mirrors.aliyun.com/ubuntu focal-proposed/universe i386 Packages[/]Get:28 http://mirrors.aliyun.com/ubuntu focal-proposed/universe Translation-e[]Get:29 http://mirrors.aliyun.com/ubuntu focal-proposed/universe amd64 DEP-11 [|]Get:30 http://mirrors.aliyun.com/ubuntu focal-proposed/multiverse amd64 DEP-1[-]Get:31 http://mirrors.aliyun.com/ubuntu focal-backports/main amd64 DEP-11 Met[/]Get:32 http://mirrors.aliyun.com/ubuntu focal-backports/universe amd64 DEP-11[-]Result:success ist --upgradable' to see them.Run CMD Task:[sudo apt install apt-transport-https ca-certificates curl software-properties-common -y]
[-]Result:success e and 1362 not upgraded.8).Run CMD Task:[curl -fsSL https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu/gpg | sudo apt-key add -]
[-]Result:successRun CMD Task:[sudo apt-key fingerprint 0EBFCD88]
[-]Result:success CE deb) docker@docker.comRun CMD Task:[sudo add-apt-repository "deb [arch=amd64] https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu $(lsb_release -cs) stable" -y]
Hit:1 http://mirrors.aliyun.com/ubuntu focal InRelease
Hit:2 https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu bionic InRelease
Hit:3 http://packages.microsoft.com/repos/code stable InRelease
Hit:4 http://mirrors.aliyun.com/ubuntu focal-security InRelease
Hit:5 http://mirrors.aliyun.com/ubuntu focal-updates InRelease
Hit:6 http://mirrors.aliyun.com/ubuntu focal-proposed InRelease
Hit:7 http://mirrors.aliyun.com/ubuntu focal-backports InRelease
Hit:8 http://mirrors.aliyun.com/ubuntu bionic InRelease
下载完成,接下来升级apt索引~
[-]Result:success ist --upgradable' to see them.se开始安装最新版本docker CE~
Run CMD Task:[sudo apt --fix-broken install -y]
[-]Result:success e and 1362 not upgraded.Run CMD Task:[sudo apt install docker-ce -y]
[-]Result:code:100 r (< 3.31.4) but 3.28.4+git20200505-0ubuntu18.04.2 is to be installedRun CMD Task:[sudo groupadd docker]
[-]Result:code:9Run CMD Task:[users]
[-]Result:successRun CMD Task:[sudo gpasswd -a qlm docker]
[-]Result:success安装完成,接下来你可以尝试使用docker --version指令测试是有正常回显~
=================3.下载镜像(该步骤因网络原因会慢一些,若失败请重试)==================
Run CMD Task:[sudo docker pull fishros2/ros:melodic-desktop-full ]
sudo: docker: command not found
================================4.生成容器======================================
请为你的melodic容器取个名字吧!melodic3
收到名字melodic3
[-]Result:successRun CMD Task:[sudo docker run -dit --name=melodic3 -v /home/qlm:/home/qlm -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -w /home/qlm fishros2/ros:melodic-desktop-full]
Run CMD Task:[docker exec -it melodic3 /bin/bash -c "echo -e '
source /opt/ros/melodic/setup.bash' >> ~/.bashrc" ]
sh: 1: docker: not found
Run CMD Task:[xhost +local:]
non-network local connections being added to access control list
================================5.生成命令======================================
[-]Result:successRun CMD Task:[sudo chmod 777 /home/qlm/.fishros/bin/melodic3]
================================6.生成使用工具======================================
为方便后续使用容器,请选择使用方式,若不知道怎么选,推荐套餐1,若不需要则可以选退出:
[1]:套餐1:VsCode+插件(本地使用推荐)
[2]:套餐2:SSH-Service(远程使用推荐)
[0]:quit
请输入[]内的数字以选择:1
套餐1包含Vscode及其容器插件,开始安装。。
欢迎使用一键安装Vscode,本工具由作者小鱼提供
开始根据系统架构,为你下载对应版本的vscode~
Run CMD Task:[sudo wget http://vscode.cdn.azure.cn/stable/5554b12acf27056905806867f251c859323ff7e9/code_1.64.0-1643863948_amd64.deb -O /tmp/vscode.deb]
--2022-07-04 03:40:13-- http://vscode.cdn.azure.cn/stable/5554b12acf27056905806867f251c859323ff7e9/code_1.64.0-1643863948_amd64.deb
Resolving vscode.cdn.azure.cn (vscode.cdn.azure.cn)... 39.91.128.35
Connecting to vscode.cdn.azure.cn (vscode.cdn.azure.cn)|39.91.128.35|:80... connected.
Length: 79990376 (76M) [application/octet-stream]
Saving to: ‘/tmp/vscode.deb’/tmp/vscode.deb 100%[==============================================================================================>] 76.28M 2.10MB/s in 34s
2022-07-04 03:40:48 (2.26 MB/s) - ‘/tmp/vscode.deb’ saved [79990376/79990376]
下载完成,接下来为你安装Vscode~
Run CMD Task:[sudo dpkg -i /tmp/vscode.deb]
[-]Result:success (1.9-2) .....tu3.18.04.2) ....)Run CMD Task:[rm -rf /tmp/vscode.deb]
[-]Result:success安装完成~
Run CMD Task:[code --install-extension ms-vscode-remote.remote-containers --user-data-dir]
Installing extensions...
Extension 'ms-vscode-remote.remote-containers' v0.238.3 is already installed. Use '--force' option to update to latest version or provide '@<version>' to install a specific version, for example: 'ms-vscode-remote.remote-containers@1.2.3'.
===========================后续使用指令=================================
后续可在任意终端输入melodic3来启动/停止/测试/删除容器
==============================文件存储位置===============================
你的主目录已经和容器的对应目录做了映射
==============================问题反馈&&更新讨论=============================
请访问社区的一键安装版块:https://fishros.org.cn/forum/topic/112
qlm@ubuntu:~$ docker --versionCommand 'docker' not found, but can be installed with:
sudo snap install docker # version 20.10.14, or
sudo apt install docker.io # version 20.10.12-0ubuntu2~20.04.1See 'snap info docker' for additional versions.
qlm@ubuntu:~$ melodic3
请输入指令控制melodic3: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
t
/home/qlm/.fishros/bin/melodic3: line 10: docker: command not found -
qlm@ubuntu:~$ sudo apt install docker-ce -y
gnome-session-common : Breaks: eog (< 3.36.0) but 3.28.1-1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages. -
@Dawn丶 和我猜想的一样,这个我更新了下代码,你再试一次看看会不会不一样
@小鱼 重新尝试“一键安装”吗?
@Dawn丶 是的
@小鱼 好像依旧是同样的错误,我把完整日志贴上来给您看看。
--2022-07-04 04:20:17-- http://fishros.com/install
--2022-07-04 04:20:18-- http://fishros.com/install/
2022-07-04 04:20:18 (55.7 MB/s) - ‘fishros’ saved [543/543]
--2022-07-04 04:20:23-- http://fishros.com/install/install1s/tools/base.py
Length: 41481 (41K) [application/octet-stream]
Saving to: ‘/tmp/fishinstall/tools/base.py’/tmp/fishinstall/to 100%[===================>] 40.51K --.-KB/s in 0.05s
2022-07-04 04:20:23 (787 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [41481/41481]
---众多工具,等君来用---
[6]:一键安装:nodejs
[7]:一键安装:VsCode开发工具
[8]:一键安装:Docker
[77]:测试模式:运行自定义工具测试
[0]:quit
请输入[]内的数字以选择:11
--2022-07-04 04:20:30-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
Saving to: ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’/tmp/fishinstall/to 100%[===================>] 11.00K --.-KB/s in 0.008s
2022-07-04 04:20:30 (1.31 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’ saved [11266/11266]
--2022-07-04 04:20:30-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
2022-07-04 04:20:30 (131 MB/s) - ‘/tmp/fishinstall/tools/tool_install_vscode.py’ saved [1264/1264]
--2022-07-04 04:20:30-- http://fishros.com/install/install1s/tools/tool_install_docker.py
Length: 2455 (2.4K) [application/octet-stream]
Saving to: ‘/tmp/fishinstall/tools/tool_install_docker.py’/tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s in 0s
2022-07-04 04:20:31 (182 MB/s) - ‘/tmp/fishinstall/tools/tool_install_docker.py’ saved [2455/2455]
[1]:noetic
[2]:humble
[3]:foxy
[4]:galactic
[5]:melodic
[6]:rolling
[7]:kinetic
[8]:eloquent
[9]:dashing
[10]:crystal
[11]:bouncy
[12]:ardent
[13]:lunar
[14]:indigo
[0]:quit
请输入[]内的数字以选择:5
[-]Result:success ist --upgradable' to see them.seRun CMD Task:[sudo apt install apt-transport-https ca-certificates curl software-properties-common -y]
Hit:3 http://mirrors.aliyun.com/ubuntu focal-security InRelease
Hit:4 http://mirrors.aliyun.com/ubuntu focal-updates InRelease
Hit:5 http://mirrors.aliyun.com/ubuntu focal-proposed InRelease
Hit:6 http://mirrors.aliyun.com/ubuntu focal-backports InRelease
Hit:7 http://mirrors.aliyun.com/ubuntu bionic InRelease
Hit:8 http://packages.microsoft.com/repos/code stable InRelease
下载完成,接下来升级apt索引~
[-]Result:success e and 1362 not upgraded.Run CMD Task:[sudo apt-cache search docker-ce ]
[-]Result:success cation container enginer engineRun CMD Task:[sudo apt install docker-ce -y]
[-]Result:code:100 r (< 3.31.4) but 3.28.4+git20200505-0ubuntu18.04.2 is to be installedRun CMD Task:[sudo apt-cache search docker-ce ]
[-]Result:success cation container enginer engineRun CMD Task:[sudo aptitude install docker-ce -y]
[-]Result:code:1Run CMD Task:[sudo groupadd docker]
请为你的melodic容器取个名字吧!melodic4
收到名字melodic4
[-]Result:successRun CMD Task:[sudo docker run -dit --name=melodic4 -v /home/qlm:/home/qlm -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -w /home/qlm fishros2/ros:melodic-desktop-full]
Run CMD Task:[docker exec -it melodic4 /bin/bash -c "echo -e '
[-]Result:successRun CMD Task:[sudo chmod 777 /home/qlm/.fishros/bin/melodic4]
[0]:quit
请输入[]内的数字以选择:1
--2022-07-04 04:22:01-- http://vscode.cdn.azure.cn/stable/5554b12acf27056905806867f251c859323ff7e9/code_1.64.0-1643863948_amd64.deb
Saving to: ‘/tmp/vscode.deb’/tmp/vscode.deb 100%[==============================================================================================>] 76.28M 2.38MB/s in 34s
2022-07-04 04:22:35 (2.26 MB/s) - ‘/tmp/vscode.deb’ saved [79990376/79990376]
下载完成,接下来为你安装Vscode~
后续可在任意终端输入melodic4来启动/停止/测试/删除容器
你的主目录已经和容器的对应目录做了映射
qlm@ubuntu:~$ melodic4
请输入指令控制melodic4: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
t
/home/qlm/.fishros/bin/melodic4: line 10: docker: command not found -
@Dawn丶 是我没写好,感谢反馈,你急不急,我现在在外面,要晚些才能回去,肯定给你解决掉,需要你等一等哈。
@小鱼 没事,您先忙,我现在都非常感谢您可以这么耐心地回复帮助我
。我自己去网上再找找解决方法(虽然大概率是不能顺利解决的
@Dawn丶 修复了下,有时间再试试~
@小鱼 强啊,非常感谢!成功安装了Docker 和 melodic版本的ros,但是vscode不成功。
@Dawn丶 我自己去装个vscode吧,这个应该问题不大
@Dawn丶
贴个解决方法:
把配置文件的root权限去掉就好了cd ~/.config sudo rm -rf ./Code/ -
dd@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
--2022-08-24 15:16:17-- http://fishros.com/install
--2022-08-24 15:16:17-- http://fishros.com/install/
再次使用存在的到 fishros.com:80 的连接。
已发出 HTTP 请求,正在等待回应... 200 OK
正在保存至: “fishros”fishros 100%[===================>] 582 --.-KB/s 用时 0s
2022-08-24 15:16:17 (38.5 MB/s) - 已保存 “fishros” [582/582])
[sudo] dd 的密码:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包是自动安装的并且现在不需要了:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
kde-window-manager kpackagetool5 kwayland-data kwin-common kwin-data
kwin-x11 libdebian-installer4 libkdecorations2-5v5
libkdecorations2private5v5 libkf5activities5 libkf5declarative-data
libkf5declarative5 libkf5globalaccelprivate5 libkf5idletime5
libkf5kcmutils-data libkf5kcmutils5 libkf5package-data libkf5package5
libkf5plasma5 libkf5quickaddons5 libkf5waylandclient5 libkf5waylandserver5
libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5multimedia5
libqt5multimedia5-plugins libqt5multimediaquick-p5 libqt5multimediawidgets5
libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
python3-pyqt5.qtsvg python3-pyqt5.qtwebkit
qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia rdate
升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 0 个软件包未被升级。
--2022-08-24 15:16:22-- http://fishros.com/install/install1s/tools/base.py
长度: 41972 (41K) [application/octet-stream]
正在保存至: “/tmp/fishinstall/tools/base.py”/tmp/fishinstall/to 100%[===================>] 40.99K --.-KB/s 用时 0.1s
2022-08-24 15:16:22 (417 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [41972/41972])
---众多工具,等君来用---
[6]:一键安装:nodejs
[7]:一键安装:VsCode开发工具
[8]:一键安装:Docker
[77]:测试模式:运行自定义工具测试
[0]:quit
请输入[]内的数字以选择:11
--2022-08-24 15:16:30-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
长度: 11449 (11K) [application/octet-stream]
正在保存至: “/tmp/fishinstall/tools/tool_install_ros_with_docker.py”/tmp/fishinstall/to 100%[===================>] 11.18K --.-KB/s 用时 0s
2022-08-24 15:16:30 (89.7 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros_with_docker.py” [11449/11449])
--2022-08-24 15:16:30-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
长度: 1264 (1.2K) [application/octet-stream]
正在保存至: “/tmp/fishinstall/tools/tool_install_vscode.py”/tmp/fishinstall/to 100%[===================>] 1.23K --.-KB/s 用时 0s
2022-08-24 15:16:30 (85.8 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_vscode.py” [1264/1264])
--2022-08-24 15:16:30-- http://fishros.com/install/install1s/tools/tool_install_docker.py
长度: 2455 (2.4K) [application/octet-stream]
正在保存至: “/tmp/fishinstall/tools/tool_install_docker.py”/tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s 用时 0s
2022-08-24 15:16:30 (182 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_docker.py” [2455/2455])
[1]:noetic
[2]:humble
[3]:foxy
[4]:galactic
[5]:melodic
[6]:rolling
[7]:kinetic
[8]:eloquent
[9]:dashing
[10]:crystal
[11]:bouncy
[12]:ardent
[13]:lunar
[14]:indigo
[0]:quit
请输入[]内的数字以选择:5
Run CMD Task:[docker version]
[-]Result:success 12112)=================3.下载镜像(该步骤因网络原因会慢一些,若失败请重试)==================
Run CMD Task:[sudo docker pull ros:melodic ]
melodic: Pulling from library/ros
d2f2687beb6d: Pull complete
c87c7d887e7b: Pull complete
c51fe758bc12: Pull complete
9646eaa84fc5: Pull complete
0e4ce991e1d0: Pull complete
a101d7b97c75: Pull complete
c716f26c3c2a: Pull complete
f0b66bed859b: Pull complete
ee909ec215bc: Pull complete
884a1a0922cf: Pull complete
Digest: sha256:7e36d090a5707554654279da0686cdb6fffe94dfee2240ea7f883420d19e1fdb
Status: Downloaded newer image for ros:melodic
docker.io/library/ros:melodic
Status: Image is up to date for ros:melodic
请为你的melodic容器取个名字吧!m1
收到名字m1
[-]Result:successRun CMD Task:[sudo docker run -dit --name=m1 -v /home/dd:/home/dd -v /tmp/.X11-unix:/tmp/.X11-unix --device=/dev/dri/renderD128 -v /dev/dri:/dev/dri --device /dev/snd -e DISPLAY=unix$DISPLAY -w /home/dd ros:melodic]
72f7bda0051f8d26ea485944fddb697ed5458f2408413b19613c9a7cc1a156fd
docker: Error response from daemon: error gathering device information while adding custom device "/dev/dri/renderD128": no such file or directory.
Run CMD Task:[docker exec -it m1 /bin/bash -c "echo -e '
Error response from daemon: Container 72f7bda0051f8d26ea485944fddb697ed5458f2408413b19613c9a7cc1a156fd is not running
[-]Result:successRun CMD Task:[sudo mkdir -p /home/dd/.fishros/bin/]
[-]Result:successRun CMD Task:[sudo chmod 777 /home/dd/.fishros/bin/m1]
[0]:quit
请输入[]内的数字以选择:1
Run CMD Task:[sudo wget http://vscode.cdn.azure.cn/stable/e4503b30fc78200f846c62cf8091b76ff5547662/code_1.70.2-1660628199_arm64.deb -O /tmp/vscode.deb]
--2022-08-24 15:22:30-- http://vscode.cdn.azure.cn/stable/e4503b30fc78200f846c62cf8091b76ff5547662/code_1.70.2-1660628199_arm64.deb
正在解析主机 vscode.cdn.azure.cn (vscode.cdn.azure.cn)... 120.232.246.35
正在连接 vscode.cdn.azure.cn (vscode.cdn.azure.cn)|120.232.246.35|:80... 已连接。
长度: 78183408 (75M) [application/octet-stream]
正在保存至: “/tmp/vscode.deb”/tmp/vscode.deb 100%[===================>] 74.56M 6.20MB/s 用时 12s
2022-08-24 15:22:42 (6.30 MB/s) - 已保存 “/tmp/vscode.deb” [78183408/78183408])
下载完成,接下来为你安装Vscode~
[-]Result:success 发器 .....ntu1) 的触发器 ...Run CMD Task:[rm -rf /tmp/vscode.deb]
Option 'user-data-dir' requires a non empty value. Ignoring the option.
connect ETIMEDOUT 13.107.42.18:443
后续可在任意终端输入m1来启动/停止/测试/删除容器
你的主目录已经和容器的对应目录做了映射
dd@ubuntu:~$ m1
请输入指令控制m1: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
t
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/m1/json: dial unix /var/run/docker.sock: connect: permission denied
密码:
newgrp: failed to crypt password with previous salt: 无效的参数 -
@sonxze 在 一键安装+Docker 安装ros melodic失败 中说:
重启下电脑就好
