    拓展3:FishBot 树莓派配置建图导航
    fishbot 建图导航
    16
    58
    80.1k
      2216200358 @小鱼
      @小鱼 ```
      #include <rclcpp/rclcpp.hpp>
      #include <tf2/utils.h>
      public:
      tf_broadcaster
      private:
      // 声明一个订阅者
      (void)msg;
      public:
      void publish_tf()
      int main(int argc, char argv)
      rclcpp::init(argc, argv);
      /产生一个的节点/
      运行节点,并检测退出信号
      while (rclcpp::ok())
      rclcpp::spin_some(node);
      node->publish_tf();
      loop_rate.sleep();
      rclcpp::shutdown();
      return 0;
        小鱼 技术大佬 @小鱼
        • D
          Dutton_Ranch
          鱼哥,出现这种情况是怎么回事呢?
            小鱼 技术大佬 @Dutton_Ranch
            D 2 条回复 最后回复 回复 引用 0
            • D
              Dutton_Ranch
              • D
                Dutton_Ranch @小鱼
                @小鱼 好的谢谢
                • D
                  Dutton_Ranch @小鱼
                  @小鱼 你好,我想问一下为什么我在将建立好的地图导入后并且修改了launch文件,开始导航后出现的图片为9eb2eda0-ff3a-4f61-96c7-ff916249d2f4-image.png ,我修改后的launch文件为
                    D 1 条回复 最后回复 回复 引用 0
                    • D
                      Dutton_Ranch @小鱼
                      @小鱼 谢谢提醒,我在基础教程里找到问题了,我的.yaml文件中image名称没有修改过来。
                      • 一
                        一百个苹果
                        最后由 一百个苹果 编辑
                        使用ros2 launch slam_toolbox online_async_launch.py尝试建图时,rviz2不出来,一直刷屏以下信息,但是雷达驱动显示运行正常:
                        zhangyiyang@zyyvm:~ros2 launch slam_toolbox online_async_launch.py y
                        [INFO] [launch]: All log files can be found below /home/zhangyiyang/.ros/log/2025-03-14-19-33-49-929416-zyyvm-5974
                        [INFO] [async_slam_toolbox_node-1]: process started with pid [5975]
                        [async_slam_toolbox_node-1] [INFO] [1741952030.006095281] [slam_toolbox]: Node using stack size 40000000
                        [async_slam_toolbox_node-1] [INFO] [1741952030.033581923] [slam_toolbox]: Using solver plugin solver_plugins::CeresSolver
                        [async_slam_toolbox_node-1] [INFO] [1741952030.033781755] [slam_toolbox]: CeresSolver: Using SCHUR_JACOBI preconditioner.
                        [async_slam_toolbox_node-1] [INFO] [1741952034.689733552] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.579 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952035.814472898] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.704 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952035.868816359] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.829 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952035.869818823] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.954 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952035.869963191] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.079 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.072087724] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.204 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.072303465] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.329 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.136468640] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.454 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.136650859] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.579 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.560468729] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.704 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.579410923] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.954 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.671219241] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.079 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.671433579] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.204 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952036.671550686] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.329 for reason 'discarding message because the queue is full'
                        [async_slam_toolbox_node-1] [INFO] [1741952037.107363519] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.454 for reason 'discarding message because the queue is full'
                          小鱼 技术大佬 @一百个苹果
                          @一百个苹果 看一下rqt tf tree
                          一 1 条回复 最后回复 回复 引用 0
                          • 一
                            一百个苹果 @小鱼
                            使用物理机运行ros2 launch slam_toolbox online_async_launch.py前,rqt_tf_tree是这样的:
                            但是运行此命令时,报错[async_slam_toolbox_node-1] [INFO] [1741952037.107363519] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.454 for reason 'discarding message because the queue is full',再次查看rqt_tf_tree,显示:
                            在关闭“ros2 launch slam_toolbox online_async_launch.py“窗口后,再次查看rqt_tf_tree,显示:
                            此时,使用ros2 topic echo /tf,发现部分信息有错误:
                            transforms:
                            • header:
                              stamp:
                              sec: 1742209731
                              nanosec: 339710976
                              frame_id: odom
                              transform:
                              translation:
                              x: 0.00010399995517218485
                              y: 9.391605715336482e-08
                              z: 0.0
                              rotation:
                              x: 0.0
                              y: 0.0
                              z: 0.0006020260043442249
                              w: 0.9999998211860657
                            transforms:
                            • header:
                              stamp:
                              sec: 1742209731
                              nanosec: 340761088
                              frame_id: odom
                              transform:
                              translation:
                              z: 0.0
                              rotation:
                              x: 0.0
                              y: 0.0
                            A message was lost!!!
                            total count change:24
                            total count: 137---
                            total count change:3
                            total count: 140---
                            total count change:1
                            total count: 141---
                            total count change:11
                            total count: 152---
                            total count: 154---
                            total count change:16
                            total count: 170---
                              小鱼 技术大佬 @一百个苹果
                              @一百个苹果 应该是连在一起的才对
                              一 2 条回复 最后回复 回复 引用 0
                              • 一
                                一百个苹果 @小鱼
                                @小鱼 本来是完整的tf_tree,但是一运行slam_toolbox online_async_launch.py后tf_tree就只剩两个节点了,不知道什么原因
                                • 一
                                  一百个苹果 @小鱼
                                  @小鱼 问题解决了,让虚拟机和树莓派之间使用ntp服务同步时间后就正常了
                                    小鱼 技术大佬 @一百个苹果
                                    @一百个苹果 ok
                                    • 苛
                                      苛性钠zzz 年度VIP
                                      鱼哥为啥我的树莓派4b2g建图导航的时候特别卡,用ssh连的时候rviz几乎动不了,小车也是原地转圈
                                        1117 年度VIP @苛性钠zzz
                                        @苛性钠zzz 哈喽,你的那个树莓派和b1f051d2-b9a6-46ac-930e-bee084634fde-image.png 这个板子如何接线的呀
                                          小鱼 技术大佬 @1117
                                          @1117 usb连接就行
                                            最后由 3132495710 编辑
                                            @小鱼 您好,进行导航时点击了Nav2 Goal,机器人没有反应。
                                            LaserScan间断标红报错
                                            等待大概五分钟后rviz画面如图:86e26309-3941-432b-91a8-9aca093bef6b-dfc94c945cd30e91321ad78c9b04f17.jpg
                                            出现轨迹规划但是机器人全程无反应,图像更新基本没有,fps基本为0
                                            Navigation2的Feeback显示中止或者未知
                                            运行导航代码指令ros2 launch fishbot_navigation2 navigation2.launch.py开启rviz后,终端回复基本是:
                                            Message Filter dropping message: frame 'laser_frame' at time 1747379107.151 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
                                            消息过滤器丢弃消息:帧 'laser_frame' 在时间 1747379107.151,原因是“消息上的时间戳早于转换缓存中的所有数据”。
                                            建图时map的resolution我改为0.02(原来是0.05,0.05图像有点粗糙),代价地图这些我没有改动。
                                            使用树莓派4b,雷达板和主控板连接树莓派使用数据线,电脑远程桌面连接,网络是手机热点5G。建图时没有问题。
