    拓展3:FishBot 树莓派配置建图导航
    fishbot 建图导航
    16
    58
    80.1k
    • D
      Dutton_Ranch @小鱼
      @小鱼 好的谢谢
      • D
        Dutton_Ranch @小鱼
        @小鱼 你好,我想问一下为什么我在将建立好的地图导入后并且修改了launch文件,开始导航后出现的图片为9eb2eda0-ff3a-4f61-96c7-ff916249d2f4-image.png ,我修改后的launch文件为
          小鱼 技术大佬 @Dutton_Ranch
          D 1 条回复 最后回复 回复 引用 0
          • D
            Dutton_Ranch @小鱼
            @小鱼 谢谢提醒,我在基础教程里找到问题了,我的.yaml文件中image名称没有修改过来。
            • 一
              一百个苹果
              最后由 一百个苹果 编辑
              使用ros2 launch slam_toolbox online_async_launch.py尝试建图时,rviz2不出来,一直刷屏以下信息,但是雷达驱动显示运行正常:
              zhangyiyang@zyyvm:~ros2 launch slam_toolbox online_async_launch.py y
              [INFO] [launch]: All log files can be found below /home/zhangyiyang/.ros/log/2025-03-14-19-33-49-929416-zyyvm-5974
              [INFO] [async_slam_toolbox_node-1]: process started with pid [5975]
              [async_slam_toolbox_node-1] [INFO] [1741952030.006095281] [slam_toolbox]: Node using stack size 40000000
              [async_slam_toolbox_node-1] [INFO] [1741952030.033581923] [slam_toolbox]: Using solver plugin solver_plugins::CeresSolver
              [async_slam_toolbox_node-1] [INFO] [1741952030.033781755] [slam_toolbox]: CeresSolver: Using SCHUR_JACOBI preconditioner.
              [async_slam_toolbox_node-1] [INFO] [1741952034.689733552] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.579 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952035.814472898] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.704 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952035.868816359] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.829 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952035.869818823] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952033.954 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952035.869963191] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.079 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.072087724] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.204 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.072303465] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.329 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.136468640] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.454 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.136650859] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.579 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.560468729] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.704 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.579410923] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952034.954 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.671219241] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.079 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.671433579] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.204 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952036.671550686] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.329 for reason 'discarding message because the queue is full'
              [async_slam_toolbox_node-1] [INFO] [1741952037.107363519] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.454 for reason 'discarding message because the queue is full'
                小鱼 技术大佬 @一百个苹果
                @一百个苹果 看一下rqt tf tree
                一 1 条回复 最后回复 回复 引用 0
                • 一
                  一百个苹果 @小鱼
                  使用物理机运行ros2 launch slam_toolbox online_async_launch.py前,rqt_tf_tree是这样的:
                  但是运行此命令时,报错[async_slam_toolbox_node-1] [INFO] [1741952037.107363519] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1741952035.454 for reason 'discarding message because the queue is full',再次查看rqt_tf_tree,显示:
                  在关闭“ros2 launch slam_toolbox online_async_launch.py“窗口后,再次查看rqt_tf_tree,显示:
                  此时,使用ros2 topic echo /tf,发现部分信息有错误:
                  transforms:
                  • header:
                    stamp:
                    sec: 1742209731
                    nanosec: 339710976
                    frame_id: odom
                    transform:
                    translation:
                    x: 0.00010399995517218485
                    y: 9.391605715336482e-08
                    z: 0.0
                    rotation:
                    x: 0.0
                    y: 0.0
                    z: 0.0006020260043442249
                    w: 0.9999998211860657
                  transforms:
                  • header:
                    stamp:
                    sec: 1742209731
                    nanosec: 340761088
                    frame_id: odom
                    transform:
                    translation:
                    z: 0.0
                    rotation:
                    x: 0.0
                    y: 0.0
                  A message was lost!!!
                  total count change:24
                  total count: 137---
                  total count change:3
                  total count: 140---
                  total count change:1
                  total count: 141---
                  total count change:11
                  total count: 152---
                  total count: 154---
                  total count change:16
                  total count: 170---
                    小鱼 技术大佬 @一百个苹果
                    @一百个苹果 应该是连在一起的才对
                    一 2 条回复 最后回复 回复 引用 0
                    • 一
                      一百个苹果 @小鱼
                      @小鱼 本来是完整的tf_tree,但是一运行slam_toolbox online_async_launch.py后tf_tree就只剩两个节点了,不知道什么原因
                      • 一
                        一百个苹果 @小鱼
                        @小鱼 问题解决了,让虚拟机和树莓派之间使用ntp服务同步时间后就正常了
                          小鱼 技术大佬 @一百个苹果
                          @一百个苹果 ok
                          • 苛
                            苛性钠zzz 年度VIP
                            鱼哥为啥我的树莓派4b2g建图导航的时候特别卡,用ssh连的时候rviz几乎动不了,小车也是原地转圈
                              1117 年度VIP @苛性钠zzz
                              @苛性钠zzz 哈喽,你的那个树莓派和b1f051d2-b9a6-46ac-930e-bee084634fde-image.png 这个板子如何接线的呀
                                小鱼 技术大佬 @1117
                                @1117 usb连接就行
                                  最后由 3132495710 编辑
                                  @小鱼 您好,进行导航时点击了Nav2 Goal,机器人没有反应。
                                  LaserScan间断标红报错
                                  等待大概五分钟后rviz画面如图:86e26309-3941-432b-91a8-9aca093bef6b-dfc94c945cd30e91321ad78c9b04f17.jpg
                                  出现轨迹规划但是机器人全程无反应,图像更新基本没有,fps基本为0
                                  Navigation2的Feeback显示中止或者未知
                                  运行导航代码指令ros2 launch fishbot_navigation2 navigation2.launch.py开启rviz后,终端回复基本是:
                                  Message Filter dropping message: frame 'laser_frame' at time 1747379107.151 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
                                  消息过滤器丢弃消息:帧 'laser_frame' 在时间 1747379107.151,原因是“消息上的时间戳早于转换缓存中的所有数据”。
                                  建图时map的resolution我改为0.02(原来是0.05,0.05图像有点粗糙),代价地图这些我没有改动。
                                  使用树莓派4b,雷达板和主控板连接树莓派使用数据线,电脑远程桌面连接,网络是手机热点5G。建图时没有问题。
                                    小鱼 技术大佬 @3132495710
                                    @3132495710 看看有没有发送 /cmd_vel
                                    3 1 条回复 最后回复 回复 引用 0
                                      yunduo_12 @小鱼
                                      @小鱼 9131af9b-ee70-4df9-a9a0-55c1c2a6c73e-image.png ,自主建图为啥总是会出现这种情况?
                                        3132495710 @小鱼
                                        @小鱼 有发送
                                        ros@ubuntu:~$ ros2 topic list
                                        /amcl/transition_event
                                        /amcl_pose
                                        /behavior_server/transition_event
                                        /behavior_tree_log
                                        /bond
                                        /bt_navigator/transition_event
                                        /clicked_point
                                        /cmd_vel
                                        /cmd_vel_nav
                                        /controller_server/transition_event
                                        /cost_cloud
                                        /diagnostics
                                        /downsampled_costmap
                                        /downsampled_costmap_updates
                                        /evaluation
                                        /global_costmap/costmap
                                        /global_costmap/costmap_raw
                                        /global_costmap/costmap_updates
                                        /global_costmap/footprint
                                        /global_costmap/global_costmap/transition_event
                                        /global_costmap/published_footprint
                                        /global_costmap/voxel_marked_cloud
                                        /goal_pose
                                        /imu
                                        /initialpose
                                        /joint_states
                                        /local_costmap/clearing_endpoints
                                        /local_costmap/costmap
                                        /local_costmap/costmap_raw
                                        /local_costmap/costmap_updates
                                        /local_costmap/footprint
                                        /local_costmap/local_costmap/transition_event
                                        /local_costmap/published_footprint
                                        /local_costmap/voxel_grid
                                        /local_costmap/voxel_marked_cloud
                                        /local_plan
                                        /map
                                        /map_server/transition_event
                                        /map_updates
                                        /marker
                                        /mobile_base/sensors/bumper_pointcloud
                                        /odom
                                        /parameter_events
                                        /particle_cloud
                                        /plan
                                        /plan_smoothed
                                        /planner_server/transition_event
                                        /received_global_plan
                                        /robot_description
                                        /rosout
                                        /scan
                                        /smoother_server/transition_event
                                        /speed_limit
                                        /tf
                                        /tf_static
                                        /transformed_global_plan
                                        /velocity_smoother/transition_event
                                        /waypoint_follower/transition_event
                                        /waypoints
                                          小鱼 技术大佬 @3132495710
                                          @3132495710 ros2 topic echo /cmd_vel
                                          3 2 条回复 最后回复 回复 引用 0
                                            3132495710 @小鱼
                                            @小鱼 :有几次是启动了,但是走的很卡顿,数据变化很少基本是
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            linear:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            angular:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            linear:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            angular:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            linear:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            angular:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            linear:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            angular:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            linear:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            angular:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            linear:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0
                                            angular:
                                            x: 0.0
                                            y: 0.0
                                            z: 0.0还有命令终端没有反应
