    学习资源
    wsl ros2
    37
    54
    78.2k
    • N
      nefert
      求大佬解读一下,为什么我的没有humble版本![替代文字](屏幕截图 2025-02-16 150700.png 图片地址)
      小鱼小 1 条回复 最后回复 回复 引用 2
        小鱼 技术大佬 @nefert
        @nefert 更换操作系统 ubuntu22
        N 2 2 条回复 最后回复 回复 引用 0
        • N
          nefert @小鱼
          • V
            voidx
              小鱼 技术大佬 @nefert
              @nefert 这是20
              N 2 条回复 最后回复 回复 引用 0
              • N
                nefert @小鱼
                @小鱼 我嘞个豆,不好意思,安装的时候以为是22,截屏时也没注意,我一直以为安装的是22.04,不好意思😂
                • N
                  nefert @小鱼
                  @小鱼 只能用fox了,学到第三章感觉也没啥问题,谢谢大佬
                  • 施
                    施
                    X 1 条回复 最后回复 回复 引用 0
                      2979853848 @小鱼
                      @小鱼 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                      wget http://fishros.com/install -O fishros && bash fishros
                        如果想要卸载怎么办呀?
                        • lovedreammsL
                          爱梦 @Zengs
                          情况+1,大家有找到解决方案嘛
                          情况说明
                          使用wsl-22.04运行海龟程序,键盘控制无法生效
                          ros2 node list等指令无法使用
                          J 2 3 条回复 最后回复 回复 引用 0
                          • A
                            abnerayyub
                            [-][2.20s] CMD Result:code:100 >
                            apt更新失败,后续程序可能会继续尝试...,[]
                            [-][1.17s] CMD Result:success
                            [-][0.00s] CMD Result:success
                            [-][2.42s] CMD Result:code:100 >
                            [-][1.16s] CMD Result:success
                            [/][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.45s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.55s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.65s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.75s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.85s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.95s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.05s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.15s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[-][11.80s] CMD Result:success
                            [-][1.06s] CMD Result:success
                            [-][3.08s] CMD Result:code:100 >
                            [-][2.71s] CMD Result:code:100 >
                            四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
                            [-][1.13s] CMD Result:success
                            小鱼哥,四次换源都失败了啊 换了网络还是不行 找不出原因了
                            小鱼小 1 2 条回复 最后回复 回复 引用 0
                              小鱼 技术大佬 @abnerayyub
                              @abnerayyub 再试试,刚更新
                              A 1 条回复 最后回复 回复 引用 0
                              • A
                                abnerayyub @小鱼
                                @小鱼 感谢 小鱼哥 安装成功
                                • 7
                                  760344005 @李万宝
                                  @李万宝 解决了,需要在这个终端的界面里使用按键,鼠标点一下这个终端,在光标这里按键盘
                                  • X
                                    xiaolixi123 @施
                                    @施 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                                    @施 咋解决的?我也突然遇到这个问题了。
                                    • J
                                      jessie1121 @lovedreamms
                                      • J
                                        @lovedreamms 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                                        情况+1,大家有找到解决方案嘛
                                        情况说明
                                        同样的问题已解决。
                                        修改user下的.wslconfig, 把配置文件里的firewall=true改为firewall=false
                                        • P
                                          promisessr
                                          按照括号后面操作了也完全没有用
                                          在另一个窗口输入命令也是一样的结果
                                            为什么我的VScode运行不了ros2呀?明明我下了ros2
