    学习资源
    wsl ros2
    37
    54
    85.9k
      小鱼 技术大佬 @nefert
      @nefert 这是20
      N 2 条回复 最后回复 回复 引用 0
      • N
        nefert @小鱼
        @小鱼 我嘞个豆,不好意思,安装的时候以为是22,截屏时也没注意,我一直以为安装的是22.04,不好意思😂
        • N
          nefert @小鱼
          @小鱼 只能用fox了,学到第三章感觉也没啥问题,谢谢大佬
          • 施
            施
            X 1 条回复 最后回复 回复 引用 0
              2979853848 @小鱼
              @小鱼 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
              wget http://fishros.com/install -O fishros && bash fishros
                如果想要卸载怎么办呀?
                • lovedreammsL
                  爱梦 @Zengs
                  情况+1,大家有找到解决方案嘛
                  情况说明
                  使用wsl-22.04运行海龟程序,键盘控制无法生效
                  ros2 node list等指令无法使用
                  J 2 3 条回复 最后回复 回复 引用 0
                  • A
                    abnerayyub
                    [-][2.20s] CMD Result:code:100 >
                    apt更新失败,后续程序可能会继续尝试...,[]
                    [-][1.17s] CMD Result:success
                    [-][0.00s] CMD Result:success
                    [-][2.42s] CMD Result:code:100 >
                    [-][1.16s] CMD Result:success
                    [/][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.45s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.55s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.65s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.75s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.85s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.95s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.05s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.15s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[-][11.80s] CMD Result:success
                    [-][1.06s] CMD Result:success
                    [-][3.08s] CMD Result:code:100 >
                    [-][2.71s] CMD Result:code:100 >
                    四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
                    [-][1.13s] CMD Result:success
                    小鱼哥,四次换源都失败了啊 换了网络还是不行 找不出原因了
                    小鱼小 1 2 条回复 最后回复 回复 引用 0
                      小鱼 技术大佬 @abnerayyub
                      @abnerayyub 再试试,刚更新
                      A 1 条回复 最后回复 回复 引用 0
                      • A
                        abnerayyub @小鱼
                        @小鱼 感谢 小鱼哥 安装成功
                        • 7
                          760344005 @李万宝
                          @李万宝 解决了,需要在这个终端的界面里使用按键,鼠标点一下这个终端,在光标这里按键盘
                          • X
                            xiaolixi123 @施
                            @施 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                            @施 咋解决的?我也突然遇到这个问题了。
                            • J
                              jessie1121 @lovedreamms
                              • J
                                @lovedreamms 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                                情况+1,大家有找到解决方案嘛
                                情况说明
                                同样的问题已解决。
                                修改user下的.wslconfig, 把配置文件里的firewall=true改为firewall=false
                                • P
                                  promisessr
                                  按照括号后面操作了也完全没有用
                                  在另一个窗口输入命令也是一样的结果
                                    为什么我的VScode运行不了ros2呀?明明我下了ros2
                                    • C
                                      cwbzjh @李万宝
                                      @李万宝 wsl2图形的解决办法:
                                      WSLg 是微软官方为 WSL 提供的内置 GUI 支持功能。它在 Windows 11 和较新版本的 Windows 10 中是默认开启的,无需安装第三方软件。
                                      确保 WSLg 已启用
                                      打开 Windows 的 PowerShell 或 CMD (Command Prompt) 终端(不是 WSL 里的),运行以下命令来更新 WSL:
                                      Bash
                                      wsl --update
                                      如果提示需要更新,请等待更新完成,然后重启 WSL:
                                      Bash
                                      wsl --shutdown
                                      关闭所有 WSL 窗口,然后重新打开一个新的 WSL 终端即可。
                                      设置 DISPLAY 环境变量
                                      WSLg 会自动设置一个名为 DISPLAY 的环境变量,告诉所有 GUI 程序应该把窗口画在哪里。正常情况下,它的值应该是 :0。你的报错很可能是因为这个变量没有被正确设置。
                                      在你的 WSL 终端里,运行以下命令来临时设置它:
                                      Bash
                                      export DISPLAY=:0
                                      设置完后,再次尝试运行你的 ROS 2 命令:
                                      Bash
                                      如果这次成功了,说明问题就在 DISPLAY 变量。为了让这个设置永久生效,把它写入你的 shell 配置文件中。如果你用的是默认的 bash,就执行:
                                      Bash
                                      echo "export DISPLAY=:0" >> ~/.bashrc
                                      source ~/.bashrc
                                        [-][0.00s] CMD Result:code:5
                                        这是什么问题?
                                        • K
                                          kha @小鱼
                                          @小鱼 LAPTOP-EH66T608:/mnt/host/c/Users/leo# wget http://fishros.com/install -O fishros && bash fishros
                                          Connecting to fishros.com (47.119.165.169:80)
                                          saving to 'fishros'
                                          fishros 100% |************************************************************************| 960 0:00:00 ETA
                                          'fishros' saved
                                          -sh: bash: not found
                                          K 1 条回复 最后回复 回复 引用 0
                                          • K
                                            kha @kha
                                            @kha 小鱼老师,大佬们,这个报错是什么原因呀
