    学习资源
    wsl ros2
    37
    54
    85.9k
    • lovedreammsL
      爱梦 @Zengs
      情况+1,大家有找到解决方案嘛
      情况说明
      使用wsl-22.04运行海龟程序,键盘控制无法生效
      ros2 node list等指令无法使用
      J 2 3 条回复 最后回复 回复 引用 0
      • A
        abnerayyub
        [-][2.20s] CMD Result:code:100 >
        apt更新失败,后续程序可能会继续尝试...,[]
        [-][1.17s] CMD Result:success
        [-][0.00s] CMD Result:success
        [-][2.42s] CMD Result:code:100 >
        [-][1.16s] CMD Result:success
        [/][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.45s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.55s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.65s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.75s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.85s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.95s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.05s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.15s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[-][11.80s] CMD Result:success
        [-][1.06s] CMD Result:success
        [-][3.08s] CMD Result:code:100 >
        [-][2.71s] CMD Result:code:100 >
        四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
        [-][1.13s] CMD Result:success
        小鱼哥,四次换源都失败了啊 换了网络还是不行 找不出原因了
        小鱼小 1 2 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @abnerayyub
          @abnerayyub 再试试,刚更新
          A 1 条回复 最后回复 回复 引用 0
          • A
            abnerayyub @小鱼
            @小鱼 感谢 小鱼哥 安装成功
            • 7
              760344005 @李万宝
              @李万宝 解决了,需要在这个终端的界面里使用按键,鼠标点一下这个终端,在光标这里按键盘
              • X
                xiaolixi123 @施
                @施 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                @施 咋解决的?我也突然遇到这个问题了。
                • J
                  jessie1121 @lovedreamms
                  • J
                    @lovedreamms 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                    情况+1,大家有找到解决方案嘛
                    情况说明
                    同样的问题已解决。
                    修改user下的.wslconfig, 把配置文件里的firewall=true改为firewall=false
                    • P
                      promisessr
                      按照括号后面操作了也完全没有用
                      在另一个窗口输入命令也是一样的结果
                        为什么我的VScode运行不了ros2呀?明明我下了ros2
                        • C
                          cwbzjh @李万宝
                          @李万宝 wsl2图形的解决办法:
                          WSLg 是微软官方为 WSL 提供的内置 GUI 支持功能。它在 Windows 11 和较新版本的 Windows 10 中是默认开启的,无需安装第三方软件。
                          确保 WSLg 已启用
                          打开 Windows 的 PowerShell 或 CMD (Command Prompt) 终端(不是 WSL 里的),运行以下命令来更新 WSL:
                          Bash
                          wsl --update
                          如果提示需要更新,请等待更新完成,然后重启 WSL:
                          Bash
                          wsl --shutdown
                          关闭所有 WSL 窗口,然后重新打开一个新的 WSL 终端即可。
                          设置 DISPLAY 环境变量
                          WSLg 会自动设置一个名为 DISPLAY 的环境变量,告诉所有 GUI 程序应该把窗口画在哪里。正常情况下,它的值应该是 :0。你的报错很可能是因为这个变量没有被正确设置。
                          在你的 WSL 终端里,运行以下命令来临时设置它:
                          Bash
                          export DISPLAY=:0
                          设置完后,再次尝试运行你的 ROS 2 命令:
                          Bash
                          如果这次成功了,说明问题就在 DISPLAY 变量。为了让这个设置永久生效,把它写入你的 shell 配置文件中。如果你用的是默认的 bash,就执行:
                          Bash
                          echo "export DISPLAY=:0" >> ~/.bashrc
                          source ~/.bashrc
                            [-][0.00s] CMD Result:code:5
                            这是什么问题?
                            • K
                              kha @小鱼
                              @小鱼 LAPTOP-EH66T608:/mnt/host/c/Users/leo# wget http://fishros.com/install -O fishros && bash fishros
                              Connecting to fishros.com (47.119.165.169:80)
                              saving to 'fishros'
                              fishros 100% |************************************************************************| 960 0:00:00 ETA
                              'fishros' saved
                              -sh: bash: not found
                              K 1 条回复 最后回复 回复 引用 0
                              • K
                                kha @kha
                                @kha 小鱼老师,大佬们,这个报错是什么原因呀
                                  2930158954 @小鱼
                                  @小鱼 请问出现网络问题的话,还需要重新下载吗,怎么办呀
                                  • T
                                    taikongnaut
                                    syq@zhan99:/mnt/c/Users/buaas$ ros2 run turtlesim turtlesim_node
                                    qt.qpa.xcb: could not connect to display 10.255.255.254:0
                                    Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
                                    求助,为什么小海龟打不开啊
                                    B 1 条回复 最后回复 回复 引用 0
                                      2891350213 @小鱼
                                      @小鱼 a9846ffd-1221-444f-b114-363131e38c9e-image.png 大佬,我也没有humble版本 是安装的22.04呀26521fc7-3fe6-4508-987b-6e560858c637-image.png
                                      • R
                                        Rainbow.1
                                        b45ef352-8278-45f0-af58-7bd057b2ea0b-image.png 鱼哥请问我这里也没有humble选项是怎么回事82036440-fd2c-424a-aef0-a84a58e449ff-image.png 我的乌班图是22.04的
                                        R 1 条回复 最后回复 回复 引用 0
                                        • R
                                          Rainbow.1 @Rainbow.1
                                          @Rainbow-1 我问ai解决了,原因是默认的不知道为什么设置成的最新版的,然后用终端回调到22.04版本即可,wsl --set-default Ubuntu-22.04。
                                          • B
                                            baobaozhouy5 @taikongnaut
                                            @taikongnaut 试试在 ~/.bashrc 中添加:
                                            export MESA_GL_VERSION_OVERRIDE=4.0
                                            export QT_XCB_GL_INTEGRATION=xcb_egl
                                            export LIBGL_ALWAYS_SOFTWARE=1
