    学习资源
    wsl ros2
    37
    54
    85.9k
    • N
      nefert @小鱼
      @小鱼 我嘞个豆,不好意思,安装的时候以为是22,截屏时也没注意,我一直以为安装的是22.04,不好意思😂
      • N
        nefert @小鱼
        @小鱼 只能用fox了,学到第三章感觉也没啥问题,谢谢大佬
        • 施
          施
          X 1 条回复 最后回复 回复 引用 0
            2979853848 @小鱼
            @小鱼 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
            wget http://fishros.com/install -O fishros && bash fishros
              如果想要卸载怎么办呀?
              • lovedreammsL
                爱梦 @Zengs
                情况+1,大家有找到解决方案嘛
                情况说明
                使用wsl-22.04运行海龟程序,键盘控制无法生效
                ros2 node list等指令无法使用
                J 2 3 条回复 最后回复 回复 引用 0
                • A
                  abnerayyub
                  [-][2.20s] CMD Result:code:100 >
                  apt更新失败,后续程序可能会继续尝试...,[]
                  [-][1.17s] CMD Result:success
                  [-][0.00s] CMD Result:success
                  [-][2.42s] CMD Result:code:100 >
                  [-][1.16s] CMD Result:success
                  [/][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.45s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.55s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.65s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.75s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.85s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.95s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.05s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.15s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[-][11.80s] CMD Result:success
                  [-][1.06s] CMD Result:success
                  [-][3.08s] CMD Result:code:100 >
                  [-][2.71s] CMD Result:code:100 >
                  四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
                  [-][1.13s] CMD Result:success
                  小鱼哥,四次换源都失败了啊 换了网络还是不行 找不出原因了
                  小鱼小 1 2 条回复 最后回复 回复 引用 0
                    小鱼 技术大佬 @abnerayyub
                    @abnerayyub 再试试,刚更新
                    A 1 条回复 最后回复 回复 引用 0
                    • A
                      abnerayyub @小鱼
                      @小鱼 感谢 小鱼哥 安装成功
                      • 7
                        760344005 @李万宝
                        @李万宝 解决了,需要在这个终端的界面里使用按键,鼠标点一下这个终端,在光标这里按键盘
                        • X
                          xiaolixi123 @施
                          @施 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                          @施 咋解决的?我也突然遇到这个问题了。
                          • J
                            jessie1121 @lovedreamms
                            • J
                              @lovedreamms 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                              情况+1,大家有找到解决方案嘛
                              情况说明
                              同样的问题已解决。
                              修改user下的.wslconfig, 把配置文件里的firewall=true改为firewall=false
                              • P
                                promisessr
                                按照括号后面操作了也完全没有用
                                在另一个窗口输入命令也是一样的结果
                                  为什么我的VScode运行不了ros2呀?明明我下了ros2
                                  • C
                                    cwbzjh @李万宝
                                    @李万宝 wsl2图形的解决办法:
                                    WSLg 是微软官方为 WSL 提供的内置 GUI 支持功能。它在 Windows 11 和较新版本的 Windows 10 中是默认开启的,无需安装第三方软件。
                                    确保 WSLg 已启用
                                    打开 Windows 的 PowerShell 或 CMD (Command Prompt) 终端(不是 WSL 里的),运行以下命令来更新 WSL:
                                    Bash
                                    wsl --update
                                    如果提示需要更新,请等待更新完成,然后重启 WSL:
                                    Bash
                                    wsl --shutdown
                                    关闭所有 WSL 窗口,然后重新打开一个新的 WSL 终端即可。
                                    设置 DISPLAY 环境变量
                                    WSLg 会自动设置一个名为 DISPLAY 的环境变量,告诉所有 GUI 程序应该把窗口画在哪里。正常情况下,它的值应该是 :0。你的报错很可能是因为这个变量没有被正确设置。
                                    在你的 WSL 终端里,运行以下命令来临时设置它:
                                    Bash
                                    export DISPLAY=:0
                                    设置完后,再次尝试运行你的 ROS 2 命令:
                                    Bash
                                    如果这次成功了,说明问题就在 DISPLAY 变量。为了让这个设置永久生效,把它写入你的 shell 配置文件中。如果你用的是默认的 bash,就执行:
                                    Bash
                                    echo "export DISPLAY=:0" >> ~/.bashrc
                                    source ~/.bashrc
                                      [-][0.00s] CMD Result:code:5
                                      这是什么问题?
                                      • K
                                        kha @小鱼
                                        @小鱼 LAPTOP-EH66T608:/mnt/host/c/Users/leo# wget http://fishros.com/install -O fishros && bash fishros
                                        Connecting to fishros.com (47.119.165.169:80)
                                        saving to 'fishros'
                                        fishros 100% |************************************************************************| 960 0:00:00 ETA
                                        'fishros' saved
                                        -sh: bash: not found
                                        K 1 条回复 最后回复 回复 引用 0
                                        • K
                                          kha @kha
                                          @kha 小鱼老师,大佬们,这个报错是什么原因呀
                                            2930158954 @小鱼
                                            @小鱼 请问出现网络问题的话,还需要重新下载吗,怎么办呀
