    学习资源
    wsl ros2
    37
    54
    85.9k
    • N
      nefert @小鱼
      @小鱼 只能用fox了,学到第三章感觉也没啥问题,谢谢大佬
      • 施
        施
        X 1 条回复 最后回复 回复 引用 0
          2979853848 @小鱼
          @小鱼 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
          wget http://fishros.com/install -O fishros && bash fishros
            如果想要卸载怎么办呀?
            • lovedreammsL
              爱梦 @Zengs
              情况+1,大家有找到解决方案嘛
              情况说明
              使用wsl-22.04运行海龟程序,键盘控制无法生效
              ros2 node list等指令无法使用
              J 2 3 条回复 最后回复 回复 引用 0
              • A
                abnerayyub
                [-][2.20s] CMD Result:code:100 >
                apt更新失败,后续程序可能会继续尝试...,[]
                [-][1.17s] CMD Result:success
                [-][0.00s] CMD Result:success
                [-][2.42s] CMD Result:code:100 >
                [-][1.16s] CMD Result:success
                [/][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.45s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.55s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.65s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.75s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.85s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][10.95s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.05s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.15s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.25s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[][11.35s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not matc[-][11.80s] CMD Result:success
                [-][1.06s] CMD Result:success
                [-][3.08s] CMD Result:code:100 >
                [-][2.71s] CMD Result:code:100 >
                四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
                [-][1.13s] CMD Result:success
                小鱼哥,四次换源都失败了啊 换了网络还是不行 找不出原因了
                小鱼小 1 2 条回复 最后回复 回复 引用 0
                  小鱼 技术大佬 @abnerayyub
                  @abnerayyub 再试试,刚更新
                  A 1 条回复 最后回复 回复 引用 0
                  • A
                    abnerayyub @小鱼
                    @小鱼 感谢 小鱼哥 安装成功
                    • 7
                      760344005 @李万宝
                      @李万宝 解决了,需要在这个终端的界面里使用按键,鼠标点一下这个终端,在光标这里按键盘
                      • X
                        xiaolixi123 @施
                        @施 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                        @施 咋解决的?我也突然遇到这个问题了。
                        • J
                          jessie1121 @lovedreamms
                          • J
                            @lovedreamms 在 【教程】使用Windows子系统WSL安装ROS2运行小海龟 中说:
                            情况+1,大家有找到解决方案嘛
                            情况说明
                            同样的问题已解决。
                            修改user下的.wslconfig, 把配置文件里的firewall=true改为firewall=false
                            • P
                              promisessr
                              按照括号后面操作了也完全没有用
                              在另一个窗口输入命令也是一样的结果
                                为什么我的VScode运行不了ros2呀?明明我下了ros2
                                • C
                                  cwbzjh @李万宝
                                  @李万宝 wsl2图形的解决办法:
                                  WSLg 是微软官方为 WSL 提供的内置 GUI 支持功能。它在 Windows 11 和较新版本的 Windows 10 中是默认开启的,无需安装第三方软件。
                                  确保 WSLg 已启用
                                  打开 Windows 的 PowerShell 或 CMD (Command Prompt) 终端(不是 WSL 里的),运行以下命令来更新 WSL:
                                  Bash
                                  wsl --update
                                  如果提示需要更新,请等待更新完成,然后重启 WSL:
                                  Bash
                                  wsl --shutdown
                                  关闭所有 WSL 窗口,然后重新打开一个新的 WSL 终端即可。
                                  设置 DISPLAY 环境变量
                                  WSLg 会自动设置一个名为 DISPLAY 的环境变量,告诉所有 GUI 程序应该把窗口画在哪里。正常情况下,它的值应该是 :0。你的报错很可能是因为这个变量没有被正确设置。
                                  在你的 WSL 终端里,运行以下命令来临时设置它:
                                  Bash
                                  export DISPLAY=:0
                                  设置完后,再次尝试运行你的 ROS 2 命令:
                                  Bash
                                  如果这次成功了,说明问题就在 DISPLAY 变量。为了让这个设置永久生效,把它写入你的 shell 配置文件中。如果你用的是默认的 bash,就执行:
                                  Bash
                                  echo "export DISPLAY=:0" >> ~/.bashrc
                                  source ~/.bashrc
                                    [-][0.00s] CMD Result:code:5
                                    这是什么问题?
                                    • K
                                      kha @小鱼
                                      @小鱼 LAPTOP-EH66T608:/mnt/host/c/Users/leo# wget http://fishros.com/install -O fishros && bash fishros
                                      Connecting to fishros.com (47.119.165.169:80)
                                      saving to 'fishros'
                                      fishros 100% |************************************************************************| 960 0:00:00 ETA
                                      'fishros' saved
                                      -sh: bash: not found
                                      K 1 条回复 最后回复 回复 引用 0
                                      • K
                                        kha @kha
                                        @kha 小鱼老师,大佬们,这个报错是什么原因呀
                                          2930158954 @小鱼
                                          @小鱼 请问出现网络问题的话,还需要重新下载吗,怎么办呀
                                          • T
                                            taikongnaut
                                            syq@zhan99:/mnt/c/Users/buaas$ ros2 run turtlesim turtlesim_node
                                            qt.qpa.xcb: could not connect to display 10.255.255.254:0
                                            Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
                                            求助,为什么小海龟打不开啊
                                            B 1 条回复 最后回复 回复 引用 0
