重要提示
[FishBot教程]7. FishBot-Nav2导航测试
@小鱼 鱼哥,我安装依赖是成功的,但是在编译的时候我也出现了这个问题,请问该怎么解决
@blairan121122885 解决了吗,跑了一次一键安装?
@192224801 同样问题解决了吗
@小鱼 鱼哥这一步跑一键安装,输入命令后安装第几项?
@小鱼 鱼哥,卡在“fishbot_bringup”这里了,没找到如何解决的方法呢,帮我看看怎么个问题,多谢
我下载的NAV2的代码为什么编译阶段会报错
rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’: /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:35:3: required from here /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:49:15: error: cannot convert ‘rclcpp::SystemDefaultsQoS’ to ‘const rmw_qos_profile_t&’ {aka ‘const rmw_qos_profile_s&’} 49 | rclcpp::SystemDefaultsQoS(), | ^~~~~~~~~~~~~~~~~~~ | | | rclcpp::SystemDefaultsQoS In file included from /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1321, from /opt/ros/humble/include/rclcpp/rclcpp/executors/single_threaded_executor.hpp:28, from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:22, from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155, from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:20, from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24, from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:15: /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note: initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::ChangeState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::ChangeState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’ 127 | const rmw_qos_profile_t & qos_profile, | ~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~ In file included from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24, from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:15: /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp: In instantiation of ‘nav2_util::ServiceClient<ServiceT, NodeT>::ServiceClient(const string&, const NodeT&) [with ServiceT = lifecycle_msgs::srv::GetState; NodeT = std::shared_ptr<rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’: /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:36:3: required from here /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:49:15: error: cannot convert ‘rclcpp::SystemDefaultsQoS’ to ‘const rmw_qos_profile_t&’ {aka ‘const rmw_qos_profile_s&’} 49 | rclcpp::SystemDefaultsQoS(), | ^~~~~~~~~~~~~~~~~~~ | | | rclcpp::SystemDefaultsQoS In file included from /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1321, from /opt/ros/humble/include/rclcpp/rclcpp/executors/single_threaded_executor.hpp:28, from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:22, from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155, from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:20, from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24, from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:15: /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note: initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::GetState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::GetState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
@1032063747 第二个命令应该在第一个后面输入,注意终端目录
此回复已被删除! -
source install/setup.bash
ros2 launch fishbot_navigation2 navigation2.launch.py哥,我前面都弄好了,最后一步点击Rviz2工具栏——2D Pose Estimate没有反应是什么原因? ,是Ubuntu22.04,humble版本,前面的都没问题,知道一下呗,很急!!!重试了很多次都是没反应。
@1923825015 你提供的信息不足,连个日志都没有
平台:Ubuntu22.04 ROS:humble
问题:地图成功构建好后,按照教程加载到navigation2.launch.py程序中去,编译成功,然后运行后,按照问档设置起点和目标点,无法使小车导航移动。具体操作步骤和执行状态如下:
1、启动micro-ros命令:
状态正常,可以接收到话题
2、启动雷达驱动:
在新开的RVIZ中可以看到雷达正常工作。
4、运行程序,加载地图如下 -
@1923825015 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
在新开的RVIZ中可以看到雷达正常工作。这里选的几?
这一步你怎么跳过了?
三、启动bringup
ros2 launch fishbot_bringup fishbot_bringup.launch.pybringup节点目前主要将odom话题转成tf并,并发布机器本体的tf广播
@小鱼 好的,已经解决了,再问一下,这小车可以定点巡航嘛?就比如自动走圆形,或者其他图案。
@1923825015 这个要自己去开发了,属于应用层的东西了
此时你可以使用rviz2的工具栏中的Nav2 Goal发送一个目标点,然后观察机器人运动即可。 这一步经常无法实现,有什么解决的方法嘛?每次发送目标时,小车就原地转圈。
@1923825015 可能你的图有问题,也可能你的线松了,需要进一步排查
@小鱼 哥,具体的排查方法有吗?图我已经建了不低于三个了,然后系统我也重装了两次了,至于接线的话,我平装好之后就没动过线,反正到现在导航就是不行,每次导航,小车就在原地转圈,只有把小车电源关闭了,才能停下来。能帮我解决一下嘛 求求了。
@1923825015 手动遥控是否正常,代价地图是否正常
@小鱼 键盘控制正常的,代价地图我不清楚怎样才算正常,反正点击Rviz2工具栏——2D Pose Estimate,然后在地图上点个目标点并选择方向后,全局代价地图以及被地代价地图以及激光在地图上都标记出来了,这样算算正常嘛?
