重要提示
[FishBot教程]7. FishBot-Nav2导航测试
- Configuration : Ubuntu 22.04 humble + ros2
- issues 情景 + 尝试解决方案:
(1) 初始问题 (retry_test_1):
- 操作:按原教程使用
git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1 cd fishbot rosdepc install --from-paths src --ignore-src -y -r # 安装依赖 colcon build
结果:all packages 全部编译失败
(2) retry_test_2: -
操作:手动 download “ https://github.com/fishros/fishbot ” 的 humble 源码,后添加依赖,后 colcon build
结果:只有 “fishbot_description” package 编译成功,其它失败
(3) retry_test_3:
每个pkg 单独编译,结果 同(2)
(4) retry_test_4:
(5) 思考:
(base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ ls fishbot fishbot-1.0.0.zip map (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ cd fishbot/ (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ ls doc README.md src (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ rosdepc install --from-paths src --ignore-src -y -r 您已经成功安装rosdepc,下面提示的用法中,请将rosdep替换为rosdepc使用~ 欢迎使用国内版rosdep之rosdepc,我是作者小鱼! 学习机器人,就关注《鱼香ROS》(公众号|B站|CSDN)! 小鱼rosdepc正式为您服务 #All required rosdeps installed successfully --------------------------------------------------------------------------- --------------------------------------------------------------------------- 小鱼科普:rosdep干什么用的?可以跳过吗?https://fishros.org.cn/forum/topic/2124 如果再使用过程中遇到任何问题,欢迎通过fishros.org.cn反馈,或者加入QQ交流群(139707339) (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ colcon build Starting >>> fishbot_bringup Starting >>> fishbot_cartographer Starting >>> fishbot_description Starting >>> fishbot_interfaces Finished <<< fishbot_description [3.93s] Starting >>> fishbot_navigation2 --- stderr: fishbot_navigation2 Traceback (most recent call last): File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 22, in <module> from catkin_pkg.package import parse_package_string ModuleNotFoundError: No module named 'catkin_pkg' CMake Error at /opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:95 (message): execute_process(/home/ros2/miniconda3/bin/python3 /opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/src/fishbot_navigation2/package.xml /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/build/fishbot_navigation2/ament_cmake_core/package.cmake) returned error code 1 Call Stack (most recent call first): /opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:49 (_ament_package_xml) /opt/ros/humble/share/ament_lint_auto/cmake/ament_lint_auto_find_test_dependencies.cmake:31 (ament_package_xml) CMakeLists.txt:34 (ament_lint_auto_find_test_dependencies) --- Failed <<< fishbot_navigation2 [4.18s, exited with code 1] Aborted <<< fishbot_cartographer [8.20s] Aborted <<< fishbot_interfaces [7.96s] Aborted <<< fishbot_bringup [13.3s] Summary: 1 package finished [15.9s] 1 package failed: fishbot_navigation2 3 packages aborted: fishbot_bringup fishbot_cartographer fishbot_interfaces 4 packages had stderr output: fishbot_bringup fishbot_cartographer fishbot_interfaces fishbot_navigation2
@小鱼 谢谢小鱼,已经解决了
@小鱼 这个一键安装后的rosdepc还是需要初始化,但是我初始化的时候显示
@2934775495这样该怎么解决呢
鱼哥,我第三步会出现这种问题,是怎么回事啊
@2934775495 sudo apt install ros-humble-joint-state-publisher
@小鱼 已经解决了,但是后面启动导航出问题了,我改了.py文件的内容出现这个问题,我是在VScode里面打开一个终端进行colcon build的,不知道为什么不可以
@2934775495
又试了一遍,现在是这样子 -
明明有文件,为什么找不到包呢? -
@2916186745 不知道啊,很奇怪
@2916186745 目录搞错了,你应该在工作空间下构建和source
此回复已被删除! -
@2496480233 看看路径里是不是有中文
鱼哥,我这边跑导航测试那一步ros2 launch fishbot_navigation2 navigation2.launch.py的时候会出现这个问题,要怎么解决呢? -
@2934775495 按照要求,单独发帖提问下
@2934775495 我也有同样的问题
