    fishbot 导航
    67
    239
    901.2k
    • 19238250151
      Woah damn @小鱼
      @小鱼 键盘控制正常的,代价地图我不清楚怎样才算正常,反正点击Rviz2工具栏——2D Pose Estimate,然后在地图上点个目标点并选择方向后,全局代价地图以及被地代价地图以及激光在地图上都标记出来了,这样算算正常嘛?
      • G
        guoxiaoqing2350
        1. Configuration : Ubuntu 22.04 humble + ros2
        1. issues 情景 + 尝试解决方案:
          (1) 初始问题 (retry_test_1):
        • 操作:按原教程使用
        cd fishbot
        rosdepc install --from-paths src --ignore-src -y  -r # 安装依赖
        • 结果:all packages 全部编译失败
          (2) retry_test_2:
        • 操作:手动 download “ https://github.com/fishros/fishbot ” 的 humble 源码,后添加依赖,后 colcon build
        • 结果:只有 “fishbot_description” package 编译成功,其它失败
          (3) retry_test_3:
          每个pkg 单独编译,结果 同(2)
          (4) retry_test_4:
          (5) 思考:
        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ ls
        fishbot  fishbot-1.0.0.zip  map
        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ cd fishbot/
        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ ls
        doc  README.md  src
        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ rosdepc install --from-paths src --ignore-src -y  -r
        欢迎使用国内版rosdep之rosdepc,我是作者小鱼!
        小鱼rosdepc正式为您服务
        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ colcon build
        Starting >>> fishbot_bringup
        Finished <<< fishbot_description [3.93s]
          execute_process(/home/ros2/miniconda3/bin/python3
          /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/src/fishbot_navigation2/package.xml
          /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/build/fishbot_navigation2/ament_cmake_core/package.cmake)
          returned error code 1
          CMakeLists.txt:34 (ament_lint_auto_find_test_dependencies)
        Failed   <<< fishbot_navigation2 [4.18s, exited with code 1]
        Aborted  <<< fishbot_cartographer [8.20s]
        Aborted  <<< fishbot_interfaces [7.96s]
        Aborted  <<< fishbot_bringup [13.3s]
        Summary: 1 package finished [15.9s]
          3 packages aborted: fishbot_bringup fishbot_cartographer fishbot_interfaces
          小鱼 技术大佬 @guoxiaoqing2350
          @guoxiaoqing2350 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
          (base)
          请退出conda!!!!
          G 1 条回复 最后回复 回复 引用 0
          • G
            guoxiaoqing2350 @小鱼
            @小鱼 谢谢小鱼,已经解决了
            • 29347754952
              笑BLUE齿 @小鱼
              @小鱼 这个一键安装后的rosdepc还是需要初始化,但是我初始化的时候显示43fb8e43-d1ac-46f0-a6f8-b36b091138c6-1711352709332.png
              29347754952 1 条回复 最后回复 回复 引用 0
              • 29347754952
                笑BLUE齿 @2934775495
                @2934775495这样该怎么解决呢
                • 29347754952
                  笑BLUE齿
                  e39e0d65-715b-4c53-ad66-ebfdf25f1d5e-image.png 鱼哥,我第三步会出现这种问题,是怎么回事啊
                    小鱼 技术大佬 @2934775495
                    @2934775495 sudo apt install ros-humble-joint-state-publisher
                    • 29347754952
                      笑BLUE齿 @小鱼
                      @小鱼 已经解决了,但是后面启动导航出问题了,我改了.py文件的内容出现这个问题,我是在VScode里面打开一个终端进行colcon build的,不知道为什么不可以
                      d28afd0a-a216-4cfd-9721-8ad74f273ea1-image.png b9dca745-2a6f-4050-8f26-cbd3e28855d2-image.png
                      • 29347754952
                        笑BLUE齿 @2934775495
                        @2934775495
                        又试了一遍,现在是这样子
                          明明有文件,为什么找不到包呢?
                          29347754952 小鱼小 2 条回复 最后回复 回复 引用 0
                          • 29347754952
                            笑BLUE齿 @2916186745
                            @2916186745 不知道啊,很奇怪
                              小鱼 技术大佬 @2916186745
                              @2916186745 目录搞错了,你应该在工作空间下构建和source
                              • 5152617255
                                空无之时
                                • 14492629671
                                  秩 @2496480233
                                  @2496480233 看看路径里是不是有中文
                                  • 29347754952
                                    笑BLUE齿
                                    鱼哥,我这边跑导航测试那一步ros2 launch fishbot_navigation2 navigation2.launch.py的时候会出现这个问题,要怎么解决呢?
                                    小鱼小 L 2 条回复 最后回复 回复 引用 0
                                      小鱼 技术大佬 @2934775495
                                      @2934775495 按照要求,单独发帖提问下
                                        liao_03 @2934775495
                                        @2934775495 我也有同样的问题
                                        • 24062910852
                                          小鹿
                                          请问进行导航的时候 地图变成这个样子是怎么回事 怎么解决
                                          ROS 导航
                                            sexysmile @1032063747
                                            @1032063747 什么一键安装?我也卡在这里了,请问可以分享一下处理办法吗?
