    fishbot 导航
    67
    239
    902.9k
    • G
      guoxiaoqing2350
      1. Configuration : Ubuntu 22.04 humble + ros2
      1. issues 情景 + 尝试解决方案:
        (1) 初始问题 (retry_test_1):
      • 操作:按原教程使用
      cd fishbot
      rosdepc install --from-paths src --ignore-src -y  -r # 安装依赖
      • 结果:all packages 全部编译失败
        (2) retry_test_2:
      • 操作:手动 download “ https://github.com/fishros/fishbot ” 的 humble 源码,后添加依赖,后 colcon build
      • 结果:只有 “fishbot_description” package 编译成功,其它失败
        (3) retry_test_3:
        每个pkg 单独编译,结果 同(2)
        (4) retry_test_4:
        (5) 思考:
      (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ ls
      fishbot  fishbot-1.0.0.zip  map
      (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ cd fishbot/
      (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ ls
      doc  README.md  src
      (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ rosdepc install --from-paths src --ignore-src -y  -r
      欢迎使用国内版rosdep之rosdepc,我是作者小鱼!
      小鱼rosdepc正式为您服务
      (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ colcon build
      Starting >>> fishbot_bringup
      Finished <<< fishbot_description [3.93s]
        execute_process(/home/ros2/miniconda3/bin/python3
        /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/src/fishbot_navigation2/package.xml
        /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/build/fishbot_navigation2/ament_cmake_core/package.cmake)
        returned error code 1
        CMakeLists.txt:34 (ament_lint_auto_find_test_dependencies)
      Failed   <<< fishbot_navigation2 [4.18s, exited with code 1]
      Aborted  <<< fishbot_cartographer [8.20s]
      Aborted  <<< fishbot_interfaces [7.96s]
      Aborted  <<< fishbot_bringup [13.3s]
      Summary: 1 package finished [15.9s]
        3 packages aborted: fishbot_bringup fishbot_cartographer fishbot_interfaces
        小鱼 技术大佬 @guoxiaoqing2350
        @guoxiaoqing2350 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
        (base)
        请退出conda!!!!
        G 1 条回复 最后回复 回复 引用 0
        • G
          guoxiaoqing2350 @小鱼
          @小鱼 谢谢小鱼,已经解决了
          • 29347754952
            笑BLUE齿 @小鱼
            @小鱼 这个一键安装后的rosdepc还是需要初始化,但是我初始化的时候显示43fb8e43-d1ac-46f0-a6f8-b36b091138c6-1711352709332.png
            29347754952 1 条回复 最后回复 回复 引用 0
            • 29347754952
              笑BLUE齿 @2934775495
              @2934775495这样该怎么解决呢
              • 29347754952
                笑BLUE齿
                e39e0d65-715b-4c53-ad66-ebfdf25f1d5e-image.png 鱼哥,我第三步会出现这种问题,是怎么回事啊
                  小鱼 技术大佬 @2934775495
                  @2934775495 sudo apt install ros-humble-joint-state-publisher
                  • 29347754952
                    笑BLUE齿 @小鱼
                    @小鱼 已经解决了,但是后面启动导航出问题了,我改了.py文件的内容出现这个问题,我是在VScode里面打开一个终端进行colcon build的,不知道为什么不可以
                    d28afd0a-a216-4cfd-9721-8ad74f273ea1-image.png b9dca745-2a6f-4050-8f26-cbd3e28855d2-image.png
                    • 29347754952
                      笑BLUE齿 @2934775495
                      @2934775495
                      又试了一遍,现在是这样子
                        明明有文件,为什么找不到包呢?
                        29347754952 小鱼小 2 条回复 最后回复 回复 引用 0
                        • 29347754952
                          笑BLUE齿 @2916186745
                          @2916186745 不知道啊,很奇怪
                            小鱼 技术大佬 @2916186745
                            @2916186745 目录搞错了,你应该在工作空间下构建和source
                            • 5152617255
                              空无之时
                              • 14492629671
                                秩 @2496480233
                                @2496480233 看看路径里是不是有中文
                                • 29347754952
                                  笑BLUE齿
                                  鱼哥,我这边跑导航测试那一步ros2 launch fishbot_navigation2 navigation2.launch.py的时候会出现这个问题,要怎么解决呢?
                                  小鱼小 L 2 条回复 最后回复 回复 引用 0
                                    小鱼 技术大佬 @2934775495
                                    @2934775495 按照要求,单独发帖提问下
                                      liao_03 @2934775495
                                      @2934775495 我也有同样的问题
                                      • 24062910852
                                        小鹿
                                        请问进行导航的时候 地图变成这个样子是怎么回事 怎么解决
                                        ROS 导航
                                          sexysmile @1032063747
                                          @1032063747 什么一键安装?我也卡在这里了,请问可以分享一下处理办法吗?
                                            萧十一郎
                                            eepdriving@deepdriving:~/fishbot$ ros2 launch fishbot_bringup fishbot_bringup.launch.py
                                            [INFO] [launch]: All log files can be found below /home/deepdriving/.ros/log/2024-05-11-15-55-53-146433-deepdriving-1888666
                                            future: <Task finished name='Task-2' coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py:226> exception=PackageNotFoundError("package 'joint_state_publisher' not found, searching: ['/home/deepdriving/fishbot/install/fishbot_navigation2', '/home/deepdriving/fishbot/install/fishbot_interfaces', '/home/deepdriving/fishbot/install/fishbot_description', '/home/deepdriving/fishbot/install/fishbot_cartographer', '/home/deepdriving/fishbot/install/fishbot_bringup', '/opt/ros/foxy']")>
                                                raise LookupError(
                                                return self.execute(context)
                                                result = self.find(package)
                                                raise PackageNotFoundError(
                                            ament_index_python.packages.PackageNotFoundError: "package 'joint_state_publisher' not found, searching: ['/home/deepdriving/fishbot/install/fishbot_navigation2', '/home/deepdriving/fishbot/install/fishbot_interfaces', '/home/deepdriving/fishbot/install/fishbot_description', '/home/deepdriving/fishbot/install/fishbot_cartographer', '/home/deepdriving/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
