    fishbot 导航
    67
    239
    985.9k
    • 19238250151
      Woah damn @小鱼
      @小鱼 哥,具体的排查方法有吗?图我已经建了不低于三个了,然后系统我也重装了两次了,至于接线的话,我平装好之后就没动过线,反正到现在导航就是不行,每次导航,小车就在原地转圈,只有把小车电源关闭了,才能停下来。能帮我解决一下嘛 求求了。
      小鱼小 1 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @1923825015
        @1923825015 手动遥控是否正常,代价地图是否正常
        • 19238250151
          Woah damn @小鱼
          @小鱼 键盘控制正常的,代价地图我不清楚怎样才算正常,反正点击Rviz2工具栏——2D Pose Estimate,然后在地图上点个目标点并选择方向后,全局代价地图以及被地代价地图以及激光在地图上都标记出来了,这样算算正常嘛?
          • G
            guoxiaoqing2350
            1. Configuration : Ubuntu 22.04 humble + ros2
            1. issues 情景 + 尝试解决方案:
              (1) 初始问题 (retry_test_1):
            • 操作:按原教程使用
            cd fishbot
            rosdepc install --from-paths src --ignore-src -y  -r # 安装依赖
            • 结果:all packages 全部编译失败
              (2) retry_test_2:
            • 操作:手动 download “ https://github.com/fishros/fishbot ” 的 humble 源码,后添加依赖,后 colcon build
            • 结果:只有 “fishbot_description” package 编译成功,其它失败
              (3) retry_test_3:
              每个pkg 单独编译,结果 同(2)
              (4) retry_test_4:
              (5) 思考:
            (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ ls
            fishbot  fishbot-1.0.0.zip  map
            (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ cd fishbot/
            (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ ls
            doc  README.md  src
            (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ rosdepc install --from-paths src --ignore-src -y  -r
            欢迎使用国内版rosdep之rosdepc,我是作者小鱼!
            小鱼rosdepc正式为您服务
            (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ colcon build
            Starting >>> fishbot_bringup
            Finished <<< fishbot_description [3.93s]
              execute_process(/home/ros2/miniconda3/bin/python3
              /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/src/fishbot_navigation2/package.xml
              /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/build/fishbot_navigation2/ament_cmake_core/package.cmake)
              returned error code 1
              CMakeLists.txt:34 (ament_lint_auto_find_test_dependencies)
            Failed   <<< fishbot_navigation2 [4.18s, exited with code 1]
            Aborted  <<< fishbot_cartographer [8.20s]
            Aborted  <<< fishbot_interfaces [7.96s]
            Aborted  <<< fishbot_bringup [13.3s]
            Summary: 1 package finished [15.9s]
              3 packages aborted: fishbot_bringup fishbot_cartographer fishbot_interfaces
              小鱼 技术大佬 @guoxiaoqing2350
              @guoxiaoqing2350 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
              (base)
              请退出conda!!!!
              G 1 条回复 最后回复 回复 引用 0
              • G
                guoxiaoqing2350 @小鱼
                @小鱼 谢谢小鱼,已经解决了
                • 29347754952
                  笑BLUE齿 @小鱼
                  @小鱼 这个一键安装后的rosdepc还是需要初始化,但是我初始化的时候显示43fb8e43-d1ac-46f0-a6f8-b36b091138c6-1711352709332.png
                  29347754952 1 条回复 最后回复 回复 引用 0
                  • 29347754952
                    笑BLUE齿 @2934775495
                    @2934775495这样该怎么解决呢
                    • 29347754952
                      笑BLUE齿
                      e39e0d65-715b-4c53-ad66-ebfdf25f1d5e-image.png 鱼哥,我第三步会出现这种问题,是怎么回事啊
                        小鱼 技术大佬 @2934775495
                        @2934775495 sudo apt install ros-humble-joint-state-publisher
                        • 29347754952
                          笑BLUE齿 @小鱼
                          @小鱼 已经解决了,但是后面启动导航出问题了,我改了.py文件的内容出现这个问题,我是在VScode里面打开一个终端进行colcon build的,不知道为什么不可以
                          d28afd0a-a216-4cfd-9721-8ad74f273ea1-image.png b9dca745-2a6f-4050-8f26-cbd3e28855d2-image.png
                          • 29347754952
                            笑BLUE齿 @2934775495
                            @2934775495
                            又试了一遍,现在是这样子
                              明明有文件,为什么找不到包呢?
                              29347754952 小鱼小 2 条回复 最后回复 回复 引用 0
                              • 29347754952
                                笑BLUE齿 @2916186745
                                @2916186745 不知道啊,很奇怪
                                  小鱼 技术大佬 @2916186745
                                  @2916186745 目录搞错了,你应该在工作空间下构建和source
                                  • 5152617255
                                    空无之时
                                    • 14492629671
                                      秩 @2496480233
                                      @2496480233 看看路径里是不是有中文
                                      • 29347754952
                                        笑BLUE齿
                                        鱼哥,我这边跑导航测试那一步ros2 launch fishbot_navigation2 navigation2.launch.py的时候会出现这个问题,要怎么解决呢?
                                        小鱼小 L 2 条回复 最后回复 回复 引用 0
                                          小鱼 技术大佬 @2934775495
                                          @2934775495 按照要求,单独发帖提问下
                                            liao_03 @2934775495
                                            @2934775495 我也有同样的问题
