重要提示
[FishBot教程]7. FishBot-Nav2导航测试
@小鱼 刚才测试了几次,应该是我直接关闭终端的缘故造成的,现在可以了,感谢!
你好,小鱼,我是双系统的22.04在输入:
git clone --recursive https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
fatal: 目标路径 'fishbot' 已经存在,并且不是一个空目录。
请问怎么处理这个问题,谢谢! -
@86181314 换个目录就行了,因为当前目录下已经存在了fishbot这一目录,也可以删掉
第一步出现了如下问题,不知如何解决 -
@小鱼 鱼哥,换个目录是什么意思?
又有新的问题 -
@921203724 别一次性运行太多指令,不然都搞不清楚是哪个出错,一步步来
看你的错误是克隆错误,已经存在fishbot工作空间了
已经下载了rosdepc,结果还是让我跑rosdep -
现在报错变了,变成这样了 -
现在变成这样了
@小鱼 可我的E盘有47.3GB可用啊
@小鱼 0 upgraded, 82 newly installed, 0 to remove and 177 not upgraded.
Need to get 119 MB of archives.
After this operation, 323 MB of additional disk space will be used.
E: You don't have enough free space in /var/cache/apt/archives/.
apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros-pkgs] failed
apt: command [sudo -H apt-get install -y gazebo] failed
apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros] failed
apt: Failed to detect successful installation of [ros-humble-gazebo-ros-pkgs]
apt: Failed to detect successful installation of [gazebo]
apt: Failed to detect successful installation of [ros-humble-gazebo-ros]
colcon: command not found就是这样,显示我地方不够,我腾E盘几个G还是这样
@小鱼 0 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
现在安装成功了,但是colcon还是不成功 -
@小鱼 OSError: [Errno 28] No space left on device: 'log/build_2023-03-11_13-56-33'
鱼哥,编译告诉我空间不够了,有什么好用的办法腾出来?
@921203724 最好重新装下系统,分配大点空间
此回复已被删除! -
source install/setup.bash
ros2 launch fishbot_bringup fishbot_bringup.launch.py需要添加
cd fishbot
source install/setup.bash -
