    fishbot 导航
    67
    239
    797.8k
      小鱼 技术大佬 @921203724
      @921203724 仔细看提示,电脑没空间了
      另外
      9212037249 3 条回复 最后回复 回复 引用 0
      • 9212037249
        天地独鸣 @小鱼
        @小鱼 可我的E盘有47.3GB可用啊
        • 9212037249
          天地独鸣 @小鱼
          @小鱼 0 upgraded, 82 newly installed, 0 to remove and 177 not upgraded.
          Need to get 119 MB of archives.
          After this operation, 323 MB of additional disk space will be used.
          E: You don't have enough free space in /var/cache/apt/archives/.
          apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros-pkgs] failed
          apt: command [sudo -H apt-get install -y gazebo] failed
          apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros] failed
          apt: Failed to detect successful installation of [ros-humble-gazebo-ros-pkgs]
          apt: Failed to detect successful installation of [gazebo]
          apt: Failed to detect successful installation of [ros-humble-gazebo-ros]
          colcon: command not found
          就是这样,显示我地方不够,我腾E盘几个G还是这样
          • 9212037249
            天地独鸣 @小鱼
            @小鱼 0 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
            现在安装成功了,但是colcon还是不成功
              小鱼 技术大佬 @921203724
              @921203724 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
              ros2没装好
              9212037249 1 条回复 最后回复 回复 引用 0
              • 9212037249
                天地独鸣 @小鱼
                @小鱼 OSError: [Errno 28] No space left on device: 'log/build_2023-03-11_13-56-33'
                鱼哥,编译告诉我空间不够了,有什么好用的办法腾出来?
                  小鱼 技术大佬 @921203724
                  @921203724 最好重新装下系统,分配大点空间
                  • 10540602251
                    天马喂狗 @小鱼
                    • 10540602251
                      天马喂狗 @小鱼
                      source install/setup.bash
                      需要添加
                      cd fishbot
                      • blairan121122885B
                        邱定凱
                        • 10130060431
                          1013006043
                          鱼哥,请问一下第三部启动 bring up 报这个错如何解决?
                          [ERROR] [launch]: Caught exception in launch (see debug for traceback): "package 'joint_state_publisher' not found, searching: ['/home/tcode9/fishbot/fishbot/install/fishbot_navigation2', '/home/tcode9/fishbot/fishbot/install/fishbot_interfaces', '/home/tcode9/fishbot/fishbot/install/fishbot_description', '/home/tcode9/fishbot/fishbot/install/fishbot_cartographer', '/home/tcode9/fishbot/fishbot/install/fishbot_bringup', '/opt/ros/humble']”
                            小鱼 技术大佬 @1013006043
                            @1013006043
                            这一步,先跑一次一键安装
                            blairan121122885B 10320637471 29347754952 L 6 条回复 最后回复 回复 引用 0
                            • blairan121122885B
                              邱定凱 @小鱼
                              @小鱼 謝謝,已解決
                              • 29379248672
                                NEO @小鱼
                                cd fishbot
                                • 12503722621
                                  1250372262
                                  想要换自己的雷达 需要怎么操作
                                    小鱼 技术大佬
                                    @1250372262 重点在雷达转接板,雷达转接板可以实现串口转wifi转串口功能,配合代码:https://www.fishros.org.cn/forum/topic/949/拓展-雷达转接板的无线串口功能驱动代码
                                    • 12503722621
                                      1250372262 @小鱼
                                      @小鱼 我是需要把原来的雷达替换成新雷达 然后把无线串口功能代码烧进板子里面 还是 无线串口功能代码是在电脑使用 直接把雷达换了 这一块不是很理解
                                        小鱼 技术大佬 @1250372262
                                        @1250372262 雷达板原有的固件不用动,配置上面给的代码就可以实现转串口了
                                        • 12503722621
                                          1250372262 @小鱼
                                          @小鱼 这个代码是要放在雷达板还是电脑上 我现在雷达是有驱动的 这个驱动能在ros2正常用,我这个雷达如果插到雷达板了 驱动也是不能正常用,要是插在电脑上 那车上还得放个电脑么
                                            小鱼 技术大佬 @1250372262
                                            @1250372262 雷达接雷达板,雷达板有无线功能把数据传输到电脑,电脑上运行我给的代码,会在本地形成一个虚拟的串口号,使用你原来的雷达驱动设置目标串口号为虚拟串口号,这样一个流程
