    fishbot 导航
    67
    239
    903.0k
    • 9212037249
      天地独鸣
      6825c1b7-c95c-4e8d-9dd1-b5cf6b752496-image.png 现在变成这样了
        小鱼 技术大佬 @921203724
        @921203724 仔细看提示,电脑没空间了
        另外
        9212037249 3 条回复 最后回复 回复 引用 0
        • 9212037249
          天地独鸣 @小鱼
          @小鱼 可我的E盘有47.3GB可用啊
          • 9212037249
            天地独鸣 @小鱼
            @小鱼 0 upgraded, 82 newly installed, 0 to remove and 177 not upgraded.
            Need to get 119 MB of archives.
            After this operation, 323 MB of additional disk space will be used.
            E: You don't have enough free space in /var/cache/apt/archives/.
            apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros-pkgs] failed
            apt: command [sudo -H apt-get install -y gazebo] failed
            apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros] failed
            apt: Failed to detect successful installation of [ros-humble-gazebo-ros-pkgs]
            apt: Failed to detect successful installation of [gazebo]
            apt: Failed to detect successful installation of [ros-humble-gazebo-ros]
            colcon: command not found
            就是这样,显示我地方不够,我腾E盘几个G还是这样
            • 9212037249
              天地独鸣 @小鱼
              @小鱼 0 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
              现在安装成功了,但是colcon还是不成功
                小鱼 技术大佬 @921203724
                @921203724 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                ros2没装好
                9212037249 1 条回复 最后回复 回复 引用 0
                • 9212037249
                  天地独鸣 @小鱼
                  @小鱼 OSError: [Errno 28] No space left on device: 'log/build_2023-03-11_13-56-33'
                  鱼哥,编译告诉我空间不够了,有什么好用的办法腾出来?
                    小鱼 技术大佬 @921203724
                    @921203724 最好重新装下系统,分配大点空间
                    • 10540602251
                      天马喂狗 @小鱼
                      • 10540602251
                        天马喂狗 @小鱼
                        source install/setup.bash
                        需要添加
                        cd fishbot
                        • blairan121122885B
                          邱定凱
                          • 10130060431
                            1013006043
                            鱼哥,请问一下第三部启动 bring up 报这个错如何解决?
                            [ERROR] [launch]: Caught exception in launch (see debug for traceback): "package 'joint_state_publisher' not found, searching: ['/home/tcode9/fishbot/fishbot/install/fishbot_navigation2', '/home/tcode9/fishbot/fishbot/install/fishbot_interfaces', '/home/tcode9/fishbot/fishbot/install/fishbot_description', '/home/tcode9/fishbot/fishbot/install/fishbot_cartographer', '/home/tcode9/fishbot/fishbot/install/fishbot_bringup', '/opt/ros/humble']”
                              小鱼 技术大佬 @1013006043
                              @1013006043
                              这一步,先跑一次一键安装
                              blairan121122885B 10320637471 29347754952 L 6 条回复 最后回复 回复 引用 0
                              • blairan121122885B
                                邱定凱 @小鱼
                                @小鱼 謝謝,已解決
                                • 29379248672
                                  NEO @小鱼
                                  cd fishbot
                                  • 12503722621
                                    1250372262
                                    想要换自己的雷达 需要怎么操作
                                      小鱼 技术大佬
                                      @1250372262 重点在雷达转接板,雷达转接板可以实现串口转wifi转串口功能,配合代码:https://www.fishros.org.cn/forum/topic/949/拓展-雷达转接板的无线串口功能驱动代码
                                      • 12503722621
                                        1250372262 @小鱼
                                        @小鱼 我是需要把原来的雷达替换成新雷达 然后把无线串口功能代码烧进板子里面 还是 无线串口功能代码是在电脑使用 直接把雷达换了 这一块不是很理解
                                          小鱼 技术大佬 @1250372262
                                          @1250372262 雷达板原有的固件不用动,配置上面给的代码就可以实现转串口了
                                          • 12503722621
                                            1250372262 @小鱼
                                            @小鱼 这个代码是要放在雷达板还是电脑上 我现在雷达是有驱动的 这个驱动能在ros2正常用,我这个雷达如果插到雷达板了 驱动也是不能正常用,要是插在电脑上 那车上还得放个电脑么
