    fishbot 导航
    67
    239
    985.9k
    • 9212037249
      天地独鸣
      又有新的问题
        小鱼 技术大佬 @921203724
        @921203724 别一次性运行太多指令,不然都搞不清楚是哪个出错,一步步来
        看你的错误是克隆错误,已经存在fishbot工作空间了
        9212037249 1 条回复 最后回复 回复 引用 0
        • 9212037249
          天地独鸣 @小鱼
          已经下载了rosdepc,结果还是让我跑rosdep
          R 1 条回复 最后回复 回复 引用 0
          • 9212037249
            天地独鸣
            现在报错变了,变成这样了
            • 9212037249
              天地独鸣
              6825c1b7-c95c-4e8d-9dd1-b5cf6b752496-image.png 现在变成这样了
                小鱼 技术大佬 @921203724
                @921203724 仔细看提示,电脑没空间了
                另外
                9212037249 3 条回复 最后回复 回复 引用 0
                • 9212037249
                  天地独鸣 @小鱼
                  @小鱼 可我的E盘有47.3GB可用啊
                  • 9212037249
                    天地独鸣 @小鱼
                    @小鱼 0 upgraded, 82 newly installed, 0 to remove and 177 not upgraded.
                    Need to get 119 MB of archives.
                    After this operation, 323 MB of additional disk space will be used.
                    E: You don't have enough free space in /var/cache/apt/archives/.
                    apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros-pkgs] failed
                    apt: command [sudo -H apt-get install -y gazebo] failed
                    apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros] failed
                    apt: Failed to detect successful installation of [ros-humble-gazebo-ros-pkgs]
                    apt: Failed to detect successful installation of [gazebo]
                    apt: Failed to detect successful installation of [ros-humble-gazebo-ros]
                    colcon: command not found
                    就是这样,显示我地方不够,我腾E盘几个G还是这样
                    • 9212037249
                      天地独鸣 @小鱼
                      @小鱼 0 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
                      现在安装成功了,但是colcon还是不成功
                        小鱼 技术大佬 @921203724
                        @921203724 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                        ros2没装好
                        • 9212037249
                          天地独鸣 @小鱼
                          @小鱼 OSError: [Errno 28] No space left on device: 'log/build_2023-03-11_13-56-33'
                          鱼哥,编译告诉我空间不够了,有什么好用的办法腾出来?
                            小鱼 技术大佬 @921203724
                            @921203724 最好重新装下系统,分配大点空间
                            • 10540602251
                              天马喂狗 @小鱼
                              • 10540602251
                                天马喂狗 @小鱼
                                source install/setup.bash
                                需要添加
                                cd fishbot
                                • blairan121122885B
                                  邱定凱
                                  • 10130060431
                                    1013006043
                                    鱼哥,请问一下第三部启动 bring up 报这个错如何解决?
                                    [ERROR] [launch]: Caught exception in launch (see debug for traceback): "package 'joint_state_publisher' not found, searching: ['/home/tcode9/fishbot/fishbot/install/fishbot_navigation2', '/home/tcode9/fishbot/fishbot/install/fishbot_interfaces', '/home/tcode9/fishbot/fishbot/install/fishbot_description', '/home/tcode9/fishbot/fishbot/install/fishbot_cartographer', '/home/tcode9/fishbot/fishbot/install/fishbot_bringup', '/opt/ros/humble']”
                                      小鱼 技术大佬 @1013006043
                                      @1013006043
                                      这一步,先跑一次一键安装
                                      blairan121122885B 10320637471 29347754952 L 6 条回复 最后回复 回复 引用 0
                                      • blairan121122885B
                                        邱定凱 @小鱼
                                        @小鱼 謝謝,已解決
                                        • 29379248672
                                          NEO @小鱼
                                          cd fishbot
                                          • 12503722621
                                            1250372262
                                            想要换自己的雷达 需要怎么操作
