    fishbot 导航
    67
    239
    985.5k
    • 19238250151
      Woah damn @小鱼
      在安装依赖时报错,a0bb8f2d-b751-440d-b0b8-f47b8b876181-1704976690257.png 用的ubuntu22.04 humble版本 然后图上的网址打不开。
        小鱼 技术大佬 @1923825015
        @1923825015 https://zhuanlan.zhihu.com/p/398754989
        • 1922248011
          早点睡觉.
          10320637471 1 条回复 最后回复 回复 引用 1
            safereinforcementlab
            鱼哥,这是什么问题
            autoliu@autoliu-LEGION-REN7000K-26IRB:~/fishbot$ rosdep install --from-paths src --ignore-src -y -r # 安装依赖
            autoliu@autoliu-LEGION-REN7000K-26IRB:~/fishbot$ colcon build
            Starting >>> fishbot_bringup
            --- stderr: fishbot_cartographer
            CMake Error at /usr/share/cmake-3.22/Modules/CMakeTestCCompiler.cmake:69 (message):
            The C compiler
            "/usr/bin/cc"
            is not able to compile a simple test program.
            It fails with the following output:
            Change Dir: /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp
            Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_0c79a/fast && /usr/bin/gmake  -f CMakeFiles/cmTC_0c79a.dir/build.make CMakeFiles/cmTC_0c79a.dir/build
            gmake[1]: 进入目录“/home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp”
            Building C object CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o
            /usr/bin/cc    -o CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o -c /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp/testCCompiler.c
            /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp/testCCompiler.c:11:1: fatal error: error closing /tmp/cc76K2IV.s: 设备上没有空间
               11 | { (void)argv; return argc-1;}
            compilation terminated.
            gmake[1]: *** [CMakeFiles/cmTC_0c79a.dir/build.make:78:CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o] 错误 1
            gmake[1]: 离开目录“/home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp”
            gmake: *** [Makefile:127:cmTC_0c79a/fast] 错误 2
            CMake will not be able to correctly generate this project.
            CMakeLists.txt:2 (project)
            Failed <<< fishbot_cartographer [0.39s, exited with code 1]
            Aborted <<< fishbot_description [0.38s]
            Aborted <<< fishbot_bringup [0.41s]
            Aborted <<< fishbot_interfaces [0.49s]
            Aborted <<< fishbot_navigation2 [0.48s]
            Summary: 0 packages finished [0.91s]
            1 package failed: fishbot_cartographer
            4 packages aborted: fishbot_bringup fishbot_description fishbot_interfaces fishbot_navigation2
            S 1 条回复 最后回复 回复 引用 0
              鱼哥,如果我要自己写控制算法,应该在哪里改,没找到源码的控制算法在那里
                safereinforcementlab @safereinforcementlab
                @safereinforcementlab 我重新装了ros2,就好了
                  请问在这个程序里面,具体的控制算法程序在哪里,https://github.com/fishros/fishbot,没有看到
                  • 11470227431
                    (解放版)沉迷睡觉
                    • 11470227431
                      (解放版)沉迷睡觉
                      鱼哥 都做完了 最后给了小车目标之后 他只是转了个向 并没有移动 我看雷达这边报了警 是这个原因吗? 还是因为什么?
                      小鱼小 1 条回复 最后回复 回复 引用 -1
                        小鱼 技术大佬 @1147022743
                        @1147022743 这个警告没关系,是Qos 主要是你这膨胀半径太大了吧
                        • 11654208751
                          . @2496480233
                          @小鱼 鱼哥,我安装依赖是成功的,但是在编译的时候我也出现了这个问题,请问该怎么解决
                          • 10320637471
                            大道至简 @blairan121122885
                            @blairan121122885 解决了吗,跑了一次一键安装?
                            • 10320637471
                              大道至简 @192224801
                              @192224801 同样问题解决了吗
                              • 10320637471
                                大道至简 @小鱼
                                @小鱼 鱼哥这一步跑一键安装,输入命令后安装第几项?
                                • 10320637471
                                  大道至简 @小鱼
                                  @小鱼 截图 2024-02-20 20-03-27.png 截图 2024-02-20 20-13-53.png鱼哥,卡在“fishbot_bringup”这里了,没找到如何解决的方法呢,帮我看看怎么个问题,多谢😊
                                  • 5634119395
                                    那年那兔
                                    我下载的NAV2的代码为什么编译阶段会报错
                                    rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
                                    /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:35:3:   required from here
                                    /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:49:15: error: cannot convert ‘rclcpp::SystemDefaultsQoS’ to ‘const rmw_qos_profile_t&’ {aka ‘const rmw_qos_profile_s&’}
                                       49 |       rclcpp::SystemDefaultsQoS(),
                                    In file included from /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1321,
                                                     from /opt/ros/humble/include/rclcpp/rclcpp/executors/single_threaded_executor.hpp:28,
                                                     from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:22,
                                                     from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155,
                                                     from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:20,
                                                     from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
                                                     from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:15:
                                    /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::ChangeState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::ChangeState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
                                      127 |   const rmw_qos_profile_t & qos_profile,
                                    In file included from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
                                    /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp: In instantiation of ‘nav2_util::ServiceClient<ServiceT, NodeT>::ServiceClient(const string&, const NodeT&) [with ServiceT = lifecycle_msgs::srv::GetState; NodeT = std::shared_ptr<rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
                                    /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:36:3:   required from here
                                    /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::GetState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::GetState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
                                      小鱼 技术大佬 @1032063747
                                      @1032063747 第二个命令应该在第一个后面输入,注意终端目录
                                      • 19238250151
                                        Woah damn @小鱼
                                        • 19238250151
                                          Woah damn @1923825015
                                          @1923825015 https://fishros.org.cn/forum/topic/923/fishbot配套资料教程汇总?lang=zh-CN
                                          • 19238250151
                                            Woah damn @小鱼
                                            source install/setup.bash
                                            哥,我前面都弄好了,最后一步点击Rviz2工具栏——2D Pose Estimate没有反应是什么原因?4157af28-15b1-4766-9385-eaf865be402c-1709551263769.png ,是Ubuntu22.04,humble版本,前面的都没问题,知道一下呗,很急!!!重试了很多次都是没反应。
