    fishbot 导航
    67
    239
    985.5k
    • 4290162674
      h1
      无法下载cartographer和navigation源码,自己手动下载后,又无法编译cartographer源码
      使用git clone --recursive https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
      cd fishbot
      colcon build下载源码,无法下载cartographer和navigation源码,(我得环境是vm虚拟机+ubuntu22.04+ros2 humble版本)
      报错 重定向:http://ww3.91chi.fun/?sub1=90563160-ae8f-11ee-b3d1-c2900044a4dd
      fatal: 无法克隆 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' 到子模组路径 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer'
      正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer_ros'...
      warning: 您似乎克隆了一个空仓库。
      正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/navigation'...
      正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer'...
      error: inflate: data stream error (incorrect header check)
      error: File 2ce33a65bd4e41e3bf5af92c9275354ce7921c70 (https://github.91chi.fun/https://github.com/ros2/cartographer.git/objects/2c/e33a65bd4e41e3bf5af92c9275354ce7921c70) corrupt
      error: Unable to find 2ce33a65bd4e41e3bf5af92c9275354ce7921c70 under https://github.91chi.fun/https://github.com/ros2/cartographer.git
      Cannot obtain needed object 2ce33a65bd4e41e3bf5af92c9275354ce7921c70
      error: 获取失败。
      fatal: 获取了子模组路径 'src/cartographer_code/cartographer',但是它没有包含 2ce33a65bd4e41e3bf5af92c9275354ce7921c70。直接获取该提交失败。
      fatal:
      2:后续自己手动下载这里两部分源码,在编译cartographer时候,报错:home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread pool,h:73:63: error:"mutexhas not been declaredvoid NotifyDependenciesCompleted(Task* task) LOCKS EXCLUDED(mutex ) ov73erride;
      home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread pool.h:73:48: error: ISO C++ forbids declaration ofLOCKS EXCLUDED’ with no type [-fpermissive]73void NotifyDependenciesCompleted(Task* task) LOCKS_EXCLUDED(mutex ) override;
      home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread poolh:73:48: error: int cartographer::common::thredPool::LOCKS EXCLUDED(int)’ cannot be overloaded with "int cartographer::common::Threadpool::LOCKS EXCLUDED(int)1704870970161.jpg
        小鱼 技术大佬 @429016267
        @429016267 源码版本有些老了,直接二进制安装吧
        4290162674 1 条回复 最后回复 回复 引用 0
        • 4290162674
          h1 @小鱼
          @小鱼 好吧,目前我就是源码编不过,其他都可以,有没有什么方案能解决下这个问题呢,大佬
            小鱼 技术大佬 @429016267
            @429016267 看d2lros2教程前面的仿真部分,根据提示重新从原来的仓库克隆
            • 19238250151
              Woah damn @小鱼
              在安装依赖时报错,a0bb8f2d-b751-440d-b0b8-f47b8b876181-1704976690257.png 用的ubuntu22.04 humble版本 然后图上的网址打不开。
                小鱼 技术大佬 @1923825015
                @1923825015 https://zhuanlan.zhihu.com/p/398754989
                • 1922248011
                  早点睡觉.
                  10320637471 1 条回复 最后回复 回复 引用 1
                    safereinforcementlab
                    鱼哥,这是什么问题
                    autoliu@autoliu-LEGION-REN7000K-26IRB:~/fishbot$ rosdep install --from-paths src --ignore-src -y -r # 安装依赖
                    autoliu@autoliu-LEGION-REN7000K-26IRB:~/fishbot$ colcon build
                    Starting >>> fishbot_bringup
                    --- stderr: fishbot_cartographer
                    CMake Error at /usr/share/cmake-3.22/Modules/CMakeTestCCompiler.cmake:69 (message):
                    The C compiler
                    "/usr/bin/cc"
                    is not able to compile a simple test program.
                    It fails with the following output:
                    Change Dir: /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp
                    Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_0c79a/fast && /usr/bin/gmake  -f CMakeFiles/cmTC_0c79a.dir/build.make CMakeFiles/cmTC_0c79a.dir/build
                    gmake[1]: 进入目录“/home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp”
                    Building C object CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o
                    /usr/bin/cc    -o CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o -c /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp/testCCompiler.c
                    /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp/testCCompiler.c:11:1: fatal error: error closing /tmp/cc76K2IV.s: 设备上没有空间
                       11 | { (void)argv; return argc-1;}
                    compilation terminated.
                    gmake[1]: *** [CMakeFiles/cmTC_0c79a.dir/build.make:78:CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o] 错误 1
                    gmake[1]: 离开目录“/home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp”
                    gmake: *** [Makefile:127:cmTC_0c79a/fast] 错误 2
                    CMake will not be able to correctly generate this project.
                    CMakeLists.txt:2 (project)
                    Failed <<< fishbot_cartographer [0.39s, exited with code 1]
                    Aborted <<< fishbot_description [0.38s]
                    Aborted <<< fishbot_bringup [0.41s]
                    Aborted <<< fishbot_interfaces [0.49s]
                    Aborted <<< fishbot_navigation2 [0.48s]
                    Summary: 0 packages finished [0.91s]
                    1 package failed: fishbot_cartographer
                    4 packages aborted: fishbot_bringup fishbot_description fishbot_interfaces fishbot_navigation2
                    S 1 条回复 最后回复 回复 引用 0
                      鱼哥,如果我要自己写控制算法,应该在哪里改,没找到源码的控制算法在那里
                        safereinforcementlab @safereinforcementlab
                        @safereinforcementlab 我重新装了ros2,就好了
                          请问在这个程序里面,具体的控制算法程序在哪里,https://github.com/fishros/fishbot,没有看到
                          • 11470227431
                            (解放版)沉迷睡觉
                            • 11470227431
                              (解放版)沉迷睡觉
                              鱼哥 都做完了 最后给了小车目标之后 他只是转了个向 并没有移动 我看雷达这边报了警 是这个原因吗? 还是因为什么?
                              小鱼小 1 条回复 最后回复 回复 引用 -1
                                小鱼 技术大佬 @1147022743
                                @1147022743 这个警告没关系,是Qos 主要是你这膨胀半径太大了吧
                                • 11654208751
                                  . @2496480233
                                  @小鱼 鱼哥,我安装依赖是成功的,但是在编译的时候我也出现了这个问题,请问该怎么解决
                                  • 10320637471
                                    大道至简 @blairan121122885
                                    @blairan121122885 解决了吗,跑了一次一键安装?
                                    • 10320637471
                                      大道至简 @192224801
                                      @192224801 同样问题解决了吗
                                      • 10320637471
                                        大道至简 @小鱼
                                        @小鱼 鱼哥这一步跑一键安装,输入命令后安装第几项?
                                        • 10320637471
                                          大道至简 @小鱼
                                          @小鱼 截图 2024-02-20 20-03-27.png 截图 2024-02-20 20-13-53.png鱼哥,卡在“fishbot_bringup”这里了,没找到如何解决的方法呢,帮我看看怎么个问题,多谢😊
                                          • 5634119395
                                            那年那兔
                                            我下载的NAV2的代码为什么编译阶段会报错
                                            rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
                                            /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:35:3:   required from here
                                            /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:49:15: error: cannot convert ‘rclcpp::SystemDefaultsQoS’ to ‘const rmw_qos_profile_t&’ {aka ‘const rmw_qos_profile_s&’}
                                               49 |       rclcpp::SystemDefaultsQoS(),
                                            In file included from /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1321,
                                                             from /opt/ros/humble/include/rclcpp/rclcpp/executors/single_threaded_executor.hpp:28,
                                                             from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:22,
                                                             from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155,
                                                             from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:20,
                                                             from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
                                                             from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:15:
                                            /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::ChangeState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::ChangeState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
                                              127 |   const rmw_qos_profile_t & qos_profile,
                                            In file included from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
                                            /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp: In instantiation of ‘nav2_util::ServiceClient<ServiceT, NodeT>::ServiceClient(const string&, const NodeT&) [with ServiceT = lifecycle_msgs::srv::GetState; NodeT = std::shared_ptr<rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
                                            /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:36:3:   required from here
                                            /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::GetState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::GetState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
