    [FishBot教程]9.0.7. FishBot-Nav2导航测试
    fishbot 导航
    67
    239
    827.3k
      等待修复
      我这边的配置和鱼哥的一模一样,,ROS2humle,ubuntu22.04,但是我发现我在进行导航的时候啊,就是会小车走到一半就会终止,
      就像这样,请问这是怎么回事呢
        小鱼 技术大佬 @2462331351
        @2462331351 图太乱了,没有空间给小车走
        • H
          yaoyao ROS2开发者 @小鱼
          @小鱼 感谢小鱼,问题已解决
          • R
            ros_freshman 年度VIP @921203724
            @921203724 你这个问题解决了吗,我出现了同样的问题。@小鱼
            • R
              ros_freshman 年度VIP
              出现这个错误了,该怎么解决呢?rosdep已经用一键安装配置好了。
                小鱼 技术大佬 @ros_freshman
                @ros_freshman 可以跳过
                • R
                  rex.chen80
                  我使用的fishros镜像系统。
                  但是colcon编译一直报错。有没有整合好的代码可以运行?
                  ~ » git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                  正克隆到 'fishbot'...
                  remote: Enumerating objects: 84, done.
                  remote: Counting objects: 100% (84/84), done.
                  remote: Compressing objects: 100% (69/69), done.
                  remote: Total 84 (delta 21), reused 46 (delta 7), pack-reused 0 (from 0)
                  接收对象中: 100% (84/84), 332.98 KiB | 1.81 MiB/s, 完成.
                  处理 delta 中: 100% (21/21), 完成.
                  ~ » cd fishbot
                  fishbot (v1.0.0 o) » rosdep install --from-paths src --ignore-src -y -r # 安 装依赖
                  #All required rosdeps installed successfully
                  fishbot (v1.0.0 o) » colcon build
                  Starting >>> fishbot_bringup
                  Starting >>> fishbot_cartographer
                  Starting >>> fishbot_interfaces
                  Starting >>> fishbot_navigation2
                  Finished <<< fishbot_description [0.60s]
                  Finished <<< fishbot_cartographer [0.71s]
                  Finished <<< fishbot_navigation2 [0.84s]
                  --- stderr: fishbot_interfaces
                  CMake Error at /opt/ros/humble/share/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:59 (message):
                  execute_process(/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/l/j/h/bin/python3
                  -m rosidl_adapter --package-name fishbot_interfaces --arguments-file
                  /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter__arguments__fishbot_interfaces.json
                  --output-dir
                  /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter/fishbot_interfaces
                  --output-file
                  /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter/fishbot_interfaces.idls)
                  returned error code 1:
                  AttributeError processing template 'srv.idl.em'
                  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 48, in evaluate_template
                    _interpreter = em.Interpreter(
                  AttributeError: module 'em' has no attribute 'Interpreter'
                  File "/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/tree.linux.x64.0/miniconda/v3.10.0+23.9.0-0/lib/python3.10/runpy.py", line 196, in _run_module_as_main
                    return _run_code(code, main_globals, None,
                  File "/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/tree.linux.x64.0/miniconda/v3.10.0+23.9.0-0/lib/python3.10/runpy.py", line 86, in _run_code
                    exec(code, run_globals)
                  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__main__.py", line 19, in <module>
                    sys.exit(main())
                  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/main.py", line 53, in main
                    abs_idl_file = convert_to_idl(
                  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 24, in convert_to_idl
                    return convert_srv_to_idl(
                  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/srv/__init__.py", line 39, in convert_srv_to_idl
                    expand_template('srv.idl.em', data, output_file, encoding='iso-8859-1')
                  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 23, in expand_template
                    content = evaluate_template(template_name, data)
                  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 69, in evaluate_template
                    _interpreter.shutdown()
                  AttributeError: 'NoneType' object has no attribute 'shutdown'
                  /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:130 (rosidl_adapt_interfaces)
                  CMakeLists.txt:29 (rosidl_generate_interfaces)
                  Failed <<< fishbot_interfaces [0.89s, exited with code 1]
                  Aborted <<< fishbot_bringup [1.08s]
                  Summary: 3 packages finished [1.24s]
                  1 package failed: fishbot_interfaces
                  1 package aborted: fishbot_bringup
                  1 package had stderr output: fishbot_interfaces
                    小鱼 技术大佬 @rex.chen80
                    @rex-chen80 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                    fishbot_interfaces
                    删除下这个功能包试试
                      鱼哥,我在执行这段代码:ros2 launch fishbot_navigation2 navigation2.launch.py
                      发生报错:
                      raise InvalidLaunchFileError(extension, likely_errors=exceptions)
                      launch.invalid_launch_file_error.InvalidLaunchFileError: Caught exception when trying to load file of format [py]: "package 'nav2_bringup' not found, searching: ['/home/jws/fishbot/fishbot/install/fishbot_navigation2', '/home/jws/fishbot/fishbot/install/fishbot_interfaces', '/home/jws/fishbot/fishbot/install/fishbot_description', '/home/jws/fishbot/fishbot/install/fishbot_cartographer', '/home/jws/fishbot/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
                      好像是缺少一个功能包:nav2_bringup
                      后来我搜了GPT,执行了:sudo apt install ros-foxy-nav2-bt-navigator(运行成功了)
                      后来再回来执行:ros2 launch fishbot_navigation2 navigation2.launch.py
                      还是原来的找不到“nav2_bringup”包这个错误。
                      该怎么解决啊😭
                        小鱼 技术大佬 @18296522393
                        @18296522393 建议用humble版本,另外需要单独装一下nav2_bringup,你可以看最新的视频或书,7.2章节有介绍命令。
                        • 16347699901
                          西林街 @1683127550
                          @1683127550 请问解决了吗?
                          Y 1 条回复 最后回复 回复 引用 0
                          • 小鱼小 小鱼 在 中 引用了 这个主题
                          • Y
                            yongyong @1683127550
                            @1683127550 你这个解决了吗
                            • Y
                              yongyong
                                小鱼 技术大佬 @yongyong
                                @yongyong 把终端日志拿出来看看
                                  2075605318 年度VIP
                                  lwb@Lwb:~/fishbot_nav$ colcon build
                                  Finished <<< fishbot_cartographer [0.09s]
                                  Finished <<< fishbot_navigation2 [0.09s]
                                  Finished <<< fishbot_description [0.11s]
                                  Finished <<< fishbot_bringup [0.13s]
                                  File "/home/lwb/fishbot_nav/build/fishbot_interfaces/ament_cmake_python/fishbot_interfaces/setup.py", line 4, in <module>
                                  setup(
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
                                  return distutils.core.setup(**attrs)
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup
                                  return run_commands(dist)
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
                                  dist.run_commands()
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 983, in run_commands
                                  self.run_command(cmd)
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
                                  super().run_command(command)
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_command
                                  cmd_obj.run()
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
                                  self.find_sources()
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
                                  mm.run()
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 548, in run
                                  self.prune_file_list()
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
                                  super().prune_file_list()
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
                                  base_dir = self.distribution.get_fullname()
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 272, in get_fullname
                                  return _distribution_fullname(self.get_name(), self.get_version())
                                  File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 290, in _distribution_fullname
                                  canonicalize_version(version, strip_trailing_zero=False),
                                  TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero'
                                  gmake[2]: *** [CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg.dir/build.make:70:CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg] 错误 1
                                  gmake[1]: *** [CMakeFiles/Makefile2:447:CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg.dir/all] 错误 2
                                  gmake[1]: *** 正在等待未完成的任务....
                                  Failed <<< fishbot_interfaces [0.39s, exited with code 2]
                                  Summary: 4 packages finished [0.52s]
                                  按照步骤来的这个interface一直编译不过是不是源代码有语法错误
                                  • A atjason 在 中 引用了 这个主题
                                  • Y
                                    yongyong
                                    832e5f7a-31e8-4e32-b361-fd8e7f1c17db-image.png file:///home/lyy/%E5%9B%BE%E7%89%87/%E6%88%AA%E5%9B%BE/%E6%88%AA%E5%9B%BE%202025-03-29%2014-32-11.png
                                    这个出了什么问题啊
                                    • Y
                                      yongyong @1634769990
                                      @1634769990 你解决了吗
                                        可以实现导航功能,但不准确。而且雷达会报error ,不知道有哪位大神可以指点如何解决。
                                        [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x59BC != 0x8FAA
                                        [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x0199 != 0x4A68
                                        [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x45A6 != 0x493D
                                        [ydlidar_node-2] [2025-04-05 01:04:55][error] Check Sum 0x73D6 != 0x5C76
                                        [ydlidar_node-2] [2025-04-05 01:05:30][error] Check Sum 0x0077 != 0x3023
                                        [ydlidar_node-2] [2025-04-05 01:05:51][error] Check Sum 0x6D00 != 0x7940
                                        [ydlidar_node-2] [2025-04-05 01:05:51][error] Check Sum 0x6874 != 0x64AF
                                        [ydlidar_node-2] [2025-04-05 01:05:59][error] Check Sum 0x75C8 != 0x6DCC
                                        [ydlidar_node-2] [2025-04-05 01:06:03][error] Check Sum 0x69BA != 0x6FB2
                                        [ydlidar_node-2] [2025-04-05 01:06:34][error] Check Sum 0x1C86 != 0x0D49
                                        [ydlidar_node-2] [2025-04-05 01:06:39][error] Check Sum 0x60F6 != 0x4492
                                        [ydlidar_node-2] [2025-04-05 01:06:56][error] Check Sum 0x01A6 != 0x2E11
                                        [ydlidar_node-2] [2025-04-05 01:06:56][error] Check Sum 0x6C28 != 0x0F78
                                        [ydlidar_node-2] [2025-04-05 01:07:02][error] Check Sum 0x6450 != 0x6A17
                                        [ydlidar_node-2] [2025-04-05 01:07:03][error] Check Sum 0x7495 != 0x4DBD
                                        [ydlidar_node-2] [2025-04-05 01:07:13][error] Check Sum 0x7516 != 0x71E2
                                        [ydlidar_node-2] [2025-04-05 01:07:22][error] Check Sum 0x1D3E != 0x5AEA
                                          小鱼 技术大佬 @165437424
                                          @165437424 最近会更新下雷达驱动,这个偶尔出现一次没问题
                                            2768003759 @1250372262
