    [FishBot教程]9.0.7. FishBot-Nav2导航测试
    fishbot 导航
    67
    239
    822.9k
    • 11654208751
      . @2496480233
      @小鱼 鱼哥,我安装依赖是成功的,但是在编译的时候我也出现了这个问题,请问该怎么解决
      • 10320637471
        大道至简 @blairan121122885
        @blairan121122885 解决了吗,跑了一次一键安装?
        S 1 条回复 最后回复 回复 引用 0
        • 10320637471
          大道至简 @192224801
          @192224801 同样问题解决了吗
          • 10320637471
            大道至简 @小鱼
            @小鱼 鱼哥这一步跑一键安装,输入命令后安装第几项?
            • 10320637471
              大道至简 @小鱼
              @小鱼 截图 2024-02-20 20-03-27.png 截图 2024-02-20 20-13-53.png鱼哥,卡在“fishbot_bringup”这里了,没找到如何解决的方法呢,帮我看看怎么个问题,多谢😊
              • 5634119395
                那年那兔
                我下载的NAV2的代码为什么编译阶段会报错
                rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
                /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:35:3:   required from here
                /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:49:15: error: cannot convert ‘rclcpp::SystemDefaultsQoS’ to ‘const rmw_qos_profile_t&’ {aka ‘const rmw_qos_profile_s&’}
                   49 |       rclcpp::SystemDefaultsQoS(),
                In file included from /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1321,
                                 from /opt/ros/humble/include/rclcpp/rclcpp/executors/single_threaded_executor.hpp:28,
                                 from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:22,
                                 from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:20,
                                 from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
                                 from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:15:
                /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::ChangeState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::ChangeState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
                  127 |   const rmw_qos_profile_t & qos_profile,
                In file included from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
                /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp: In instantiation of ‘nav2_util::ServiceClient<ServiceT, NodeT>::ServiceClient(const string&, const NodeT&) [with ServiceT = lifecycle_msgs::srv::GetState; NodeT = std::shared_ptr<rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
                /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:36:3:   required from here
                /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::GetState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::GetState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
                  小鱼 技术大佬 @1032063747
                  @1032063747 第二个命令应该在第一个后面输入,注意终端目录
                  • 19238250151
                    Woah damn @小鱼
                    • 19238250151
                      Woah damn @1923825015
                      @1923825015 https://fishros.org.cn/forum/topic/923/fishbot配套资料教程汇总?lang=zh-CN
                      • 19238250151
                        Woah damn @小鱼
                        @小鱼 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                        source install/setup.bash
                        ros2 launch fishbot_navigation2 navigation2.launch.py
                        哥,我前面都弄好了,最后一步点击Rviz2工具栏——2D Pose Estimate没有反应是什么原因?4157af28-15b1-4766-9385-eaf865be402c-1709551263769.png ,是Ubuntu22.04,humble版本,前面的都没问题,知道一下呗,很急!!!重试了很多次都是没反应。
                          小鱼 技术大佬 @1923825015
                          @1923825015 你提供的信息不足,连个日志都没有
                          19238250151 1 条回复 最后回复 回复 引用 0
                          • 19238250151
                            Woah damn @小鱼
                            @小鱼 鱼哥在构建完地图导航测试时遇到了一点问题,问题如下:
                            平台:Ubuntu22.04 ROS:humble
                            问题:地图成功构建好后,按照教程加载到navigation2.launch.py程序中去,编译成功,然后运行后,按照问档设置起点和目标点,无法使小车导航移动。
                            具体操作步骤和执行状态如下:
                            1、启动micro-ros命令:
                            状态正常,可以接收到话题
                            2、启动雷达驱动:
                            xhost + && sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 fishros2/fishbot_laser
                            在新开的RVIZ中可以看到雷达正常工作。
                            3、修改navigation2.launch.py程序,加载新建的地图
                            4、运行程序,加载地图如下3913b6df-269e-48d1-bb6e-fbc8af74dcd2-1709557682799.png cd0cfc78-dcd9-4bfe-9b00-c4a878c3ec51-1709557670585.png fd271237-1e0a-405e-bfc4-851700638cb1-1709557660299.png 190802ed-f1ae-41ea-a0b0-3da74e614b44-1709557650488.png
                              小鱼 技术大佬 @1923825015
                              @1923825015 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                              这里选的几?
                              这一步你怎么跳过了?
                              三、启动bringup
                              ros2 launch fishbot_bringup fishbot_bringup.launch.py
                              bringup节点目前主要将odom话题转成tf并,并发布机器本体的tf广播
                              19238250151 1 条回复 最后回复 回复 引用 1
                              • 19238250151
                                Woah damn @小鱼
                                @小鱼 好的,已经解决了,再问一下,这小车可以定点巡航嘛?就比如自动走圆形,或者其他图案。
                                  小鱼 技术大佬 @1923825015
                                  @1923825015 这个要自己去开发了,属于应用层的东西了
                                  • 19238250151
                                    Woah damn @小鱼
                                    此时你可以使用rviz2的工具栏中的Nav2 Goal发送一个目标点,然后观察机器人运动即可。 这一步经常无法实现,有什么解决的方法嘛?每次发送目标时,小车就原地转圈。
                                      小鱼 技术大佬 @1923825015
                                      @1923825015 可能你的图有问题,也可能你的线松了,需要进一步排查
                                      • 19238250151
                                        Woah damn @小鱼
                                        @小鱼 哥,具体的排查方法有吗?图我已经建了不低于三个了,然后系统我也重装了两次了,至于接线的话,我平装好之后就没动过线,反正到现在导航就是不行,每次导航,小车就在原地转圈,只有把小车电源关闭了,才能停下来。能帮我解决一下嘛 求求了。
                                        小鱼小 1 2 条回复 最后回复 回复 引用 0
                                          小鱼 技术大佬 @1923825015
                                          @1923825015 手动遥控是否正常,代价地图是否正常
                                          • 19238250151
                                            Woah damn @小鱼
                                            @小鱼 键盘控制正常的,代价地图我不清楚怎样才算正常,反正点击Rviz2工具栏——2D Pose Estimate,然后在地图上点个目标点并选择方向后,全局代价地图以及被地代价地图以及激光在地图上都标记出来了,这样算算正常嘛?
