    ros2机器人foxy版用笔记本摄像头跑单目orb_slam3
    移动平台分享
    ros2 foxy orbslam3
    12
    32
    37.0k
    • 11573543821
      大预言家·福尔摩斯·睿
      你好 出现这种错 这是沙玩意儿
      • 毛哥成山轮胎机油保养毛
        毛哥成山轮胎机油保养 活跃VIP @1157354382
        最后由 毛哥成山轮胎机油保养 编辑
        @1157354382 你这是跑的单目的程序,需要启动摄像头的,你的主程序已经启动,正在等你的摄像头数据,如果你的摄像头已经启动了,那要检查摄像头发布的话题和你的主程序接收的话题是否一致
        ros2 topic list 查看话题
        11573543821 2 条回复 最后回复 回复 引用 0
        • 11573543821
          大预言家·福尔摩斯·睿 @毛哥成山轮胎机油保养
          @毛哥成山轮胎机油保养 是的 这些我都修改好了,好奇怪
          • 11573543821
            @毛哥成山轮胎机油保养 我看了一眼里面的代码,好像执行到这一步就没了好像是直接死掉了
            后面哪怕我加了 cout 也不显示,但是我用 ./运行 exalmple,就能正常显示,我不懂啊
            • 毛哥成山轮胎机油保养毛
              @1157354382 m@ubun:~$ ros2 run orbslam3 mono ~/ORB_SLAM3/Vocabulary/ORBvoc.txt ~/ORB_SLAM3/Examples/Monocular/RealSense_D435i.yaml
              ORB-SLAM3 Copyright (C) 2017-2020 Carlos Campos, Richard Elvira, Juan J. Gómez, José M.M. Montiel and Juan D. Tardós, University of Zaragoza.
              ORB-SLAM2 Copyright (C) 2014-2016 Raúl Mur-Artal, José M.M. Montiel and Juan D. Tardós, University of Zaragoza.
              This program comes with ABSOLUTELY NO WARRANTY;
              This is free software, and you are welcome to redistribute it
              under certain conditions. See LICENSE.txt.
              Input sensor was set to: Monocular
              Loading settings from /home/m/ORB_SLAM3/Examples/Monocular/RealSense_D435i.yaml
              Camera1.k3 optional parameter does not exist...
              -Loaded camera 1
              Camera.newHeight optional parameter does not exist...
              Camera.newWidth optional parameter does not exist...
              -Loaded image info
              -Loaded ORB settings
              Viewer.imageViewScale optional parameter does not exist...
              -Loaded viewer settings
              System.LoadAtlasFromFile optional parameter does not exist...
              System.SaveAtlasToFile optional parameter does not exist...
              -Loaded Atlas settings
              System.thFarPoints optional parameter does not exist...
              -Loaded misc parameters
              SLAM settings:
              -Camera 1 parameters (Pinhole): [ 382.613 382.613 320.183 236.455 ]
              -Camera 1 distortion parameters: [ 0 0 0 0 ]
              -Original image size: [ 640 , 480 ]
              -Current image size: [ 640 , 480 ]
              -Sequence FPS: 30
              -Features per image: 1250
              -ORB scale factor: 1.2
              -ORB number of scales: 8
              -Initial FAST threshold: 20
              -Min FAST threshold: 7
              Loading ORB Vocabulary. This could take a while...
              Vocabulary loaded!
              Initialization of Atlas from scratch
              Creation of new map with id: 0
              Creation of new map with last KF id: 0
              Seq. Name:
              There are 1 cameras in the atlas
              Camera 0 is pinhole
              slam changed
              Starting the Viewer
              你的下一步该加载摄像头配置了,看看你的摄像头配置文件路径对吗?
              11573543821 1 条回复 最后回复 回复 引用 0
              • 11573543821
                @毛哥成山轮胎机油保养 无论我是对的还是错的,都直接结束程序了,莫名其妙的,用ros2来驱动
                • 35322067913
                  LBZ686
                  9c67e0ac-4e52-4b03-b879-79d6be83701b-Y3`K2GMDN(M}KW)X~1<a class=@WK%2.png" class=" img-fluid img-markdown" />
                  您好,wo'xian我想结合ros2——orbslam3和gazebo仿真,在订阅到图像后,在运行程序后,orbslam3也显示出来有图像接收到了,但是在可视化界面根本没有图像,这是什么原因,困扰很久了,真心想解决这个问题
                  • 毛哥成山轮胎机油保养毛
                    毛哥成山轮胎机油保养 活跃VIP @3532206791
                    最后由 毛哥成山轮胎机油保养 编辑
                    @3532206791 你让仿真的小车移动一下,也许就会出来图像,我没有跑过仿真的,但是用实体的摄像头跑单目跑到你这个地方也卡了我很久,有一次无意中移动了一下摄像头图像就出来了。他计算第一帧和第二帧图像,如果摄像头没动,第一帧和第二帧图像是同一个图像,初始化不了,不知道你碰到的问题和我曾经碰到的问题是否一样。
                    35322067913 2 条回复 最后回复 回复 引用 0
                    • 35322067913
                      LBZ686 @毛哥成山轮胎机油保养
                      @毛哥成山轮胎机油保养 哎,我尝试了,不管怎么动小车都没有图像显示,不知道是不是代码方面还有什么其他的问题,还是说只进行话题的订阅还不够,还需要调整其他参数?不明白
                      • 35322067913
                        LBZ686 @毛哥成山轮胎机油保养
                        @毛哥成山轮胎机油保养 还是说需要用这个文件 RealSense_D435i.yaml
                        • 35322067913
                          LBZ686
                          你好,我解决了无法显示图像的问题,但是新的问题又出现了,我在仿真环境下运行orbslam3很容易终止,不知道您用摄像头卡不卡,会不会很容易中断
                          • 毛哥成山轮胎机油保养毛
                            @3532206791 用笔记本的摄像头和外接的奥比中光摄像头我都试过,挺流畅的,只不过开源程序都是不成熟的程序,会有其他方面的问题,距离应用还有十万八千里。
                            • 25432986002
                              2543298600
                              odom和IMU融合时,机器人在晃动,为什么?
                              • 毛哥成山轮胎机油保养毛
                                毛哥成山轮胎机油保养 活跃VIP @2543298600
                                @2543298600 是用的robot_localization融合的吗?我用实体机器人跑的rviz2里面机器人模型是一直在闪,你试着改一下robot_localization 配置文件:
                                Whether to broadcast the transformation over the /tf topic. Defaults to true if unspecified.
                                    publish_tf: false
                                机器人差速模型发布tf robot_localization 也发布tf 我觉得是同一个topic 2个发布者会有冲突,我把 publish_tf: false 就不闪了,不知道和你遇到的是不是同一个问题
                                • T
                                  tianrunyang19 @毛哥成山轮胎机油保养
                                  • T
                                    tianrunyang19 @SciMaker
                                    @SciMaker 您好,我有遇到跟你相同的問題,想請問您是改寫CMakeLists的哪裡呢?
                                    謝謝您
                                    • T
                                      @毛哥成山轮胎机油保养 您好,我跟SciMaker有相同的問題,也有按照您說的把libORB_SLAM3.so複製到usr/lib底下,依舊有相同的問題。
                                      • 毛哥成山轮胎机油保养毛
                                        毛哥成山轮胎机油保养 活跃VIP @tianrunyang19
                                        @tianrunyang19 如果要想向前走下去,cmake 编译是一道绕不过的坎,花一个多星期百度找教程系统学一下吧,要不然后面没法玩,每个文件都需要编译。其实编译无非就是一个找头文件,找库文件的过程,
                                        要根据提示看看缺什么文件,然后用
                                        sudo find / -name 文件名 //在整个电脑内查找文件
                                        如果有这个文件,头文件放在/usr/include,库文件放在/usr/lib(简单粗暴,只适合新手),如果没有这个文件要想办法得到这个文件。
                                        • 16076984961
                                          张兰鑫
                                          9ab74f3c-d080-40db-9da6-0ff2fbc33b71-image.png 我在运行colcon build --symlink-install --packages-select orbslam3这个命令的时候遇到这个错误/usr/bin/ld: /usr/local/lib/libopencv_calib3d.so.407: error adding symbols: DSO missing from command line
                                          请问这应该怎么解决呢,前面编译orb3的时候是正常的
                                          19075152341 1 条回复 最后回复 回复 引用 0
                                          • 19075152341
                                            Sui Generis @1607698496
                                            @1607698496 兄弟有解决这个问题吗
