    拓展2:FishBot配套雷达驱动教程(源码版)
    fishbot 雷达板驱动
    18
    61
    90.2k
      目前FishBot主要配套雷达型号为EAI-X2,后续可能会引入其他雷达。
      一、EAI-X2 雷达
      针对EAI-X2,采用的驱动为小鱼修改后的ROS2驱动:
      • 代码仓库为:https://github.com/fishros/ydlidar_ros2
      • 代码分支为:v1.0.0/fishbot
      1.1 有线驱动-树莓派工控机直连都可以通过这种方式
      将配套的雷达转接板模式调整到UART模式,拔掉EN跳线帽(可以关闭ESP8266,节省能源), 找一根USB线,将 雷达板接入到你要驱动的电脑或者各种PI上。
      下载源码到任意一个目录:
      git clone http://github.fishros.org/https://github.com/fishros/ydlidar_ros2 -b  v1.0.0/fishbot
      进入到源码,修改串口编号ydlidar_ros2/params/ydlidar.yaml,一般是/dev/ttyUSB0
      ydlidar_node:
        ros__parameters:
          port: /dev/ttyUSB0
          frame_id: laser_frame
          ignore_array: ""
      接着编译 :
      cd ydlidar_ros2
      colcon build
      接着修改串口权限,然后运行驱动
      sudo chmod 666 /dev/ttyUSB0
      source install/setup.bash
      ros2 launch ydlidar ydlidar_launch.py
      [INFO] [launch]: All log files can be found below /home/pi/.ros/log/2023-07-21-23-13-28-893425-raspberrypi-4518
      [INFO] [ydlidar_node-1]: process started with pid [4539]
      [INFO] [static_transform_publisher-2]: process started with pid [4541]
      [static_transform_publisher-2] [WARN] [1689952409.891692804] []: Old-style arguments are deprecated; see --help for new-style arguments
      [static_transform_publisher-2] [INFO] [1689952409.975433434] [static_tf_pub_laser]: Spinning until stopped - publishing transform
      [static_transform_publisher-2] translation: ('0.020000', '0.000000', '0.000000')
      [static_transform_publisher-2] from 'base_link' to 'laser_frame'
      [ydlidar_node-1] [YDLIDAR INFO] Current ROS Driver Version: 1.4.5
      [ydlidar_node-1] [YDLIDAR]:SDK Version: 1.4.5
      [ydlidar_node-1] [YDLIDAR]:Lidar running correctly ! The health status: good
      [ydlidar_node-1] [YDLIDAR] Connection established in [/dev/ttyUSB0][115200]:
      [ydlidar_node-1] Firmware version: 1.5
      [ydlidar_node-1] Hardware version: 1
      [ydlidar_node-1] Model: S4
      [ydlidar_node-1] Serial: 2020112400007024
      [ydlidar_node-1] [YDLIDAR]:Fixed Size: 370
      [ydlidar_node-1] [YDLIDAR]:Sample Rate: 3K
      [ydlidar_node-1] [YDLIDAR INFO] Current Sampling Rate : 3K
      [ydlidar_node-1] [YDLIDAR INFO] Now YDLIDAR is scanning ......
      最后使用ros2 topic list 就可以看到话题list了,scan就是雷达话题
      os2 topic list
      /parameter_events
      /rosout
      /scan
      /tf_static
      /ydlidar_node/transition_event
      1.2 无线驱动-对于台式机很合适
      直接用Docker,最方便:
      • https://www.fishros.org.cn/forum/topic/940/fishbot教程-5-雷达固件烧录及配置/1?lang=zh-CN
      • https://fishros.org.cn/forum/topic/954/fishbot教程-6-雷达驱动及建图测试
      如果想通过源码的方式也可以,雷达板的主要作用是将雷达 数据生成一个虚拟的串口,在电脑上直接运行下面这段Python代码,当连接建立后,就会直接生成 一个虚拟串口,然后按照 1.1 的方式就可以直接驱动了。
      #!/usr/bin/env python3
      import subprocess
      import os
      import pty
      import socket
      import select
      import argparse
      import subprocess
      import time
      class LaserScanRos2():
          def __init__(self) -> None:
              self.laser_pro = None
      class SocketServer():
          def __init__(self,lport=8888,uart_name="/tmp/fishbot_laser") -> None:
              self.lport = lport
              self.uart_name = uart_name
              self.laser_ros2 = LaserScanRos2()
              self.main()
          def main(self):
              s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
              s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
              s.bind(('0.0.0.0', self.lport))
              s.listen(5)
              master, slave = pty.openpty()
              if os.path.exists(self.uart_name):
                  os.remove(self.uart_name)
              os.symlink(os.ttyname(slave), self.uart_name)
              print(f"UART2SOCKET:{self.lport}->{self.uart_name}")
              mypoll = select.poll()
              mypoll.register(master, select.POLLIN)
              try:
                  while True:
                      print("Prepare to Accept connect!")
                      client, client_address = s.accept()
                      mypoll.register(client.fileno(), select.POLLIN)
                      print(s.fileno(), client, master)
                      print('PTY: Opened {} for {}:{}'.format(
                          os.ttyname(slave), '0.0.0.0', self.lport))
                      is_connect = True
                      try:
                          while is_connect:
                              fdlist = mypoll.poll(256)
                              for fd, event in fdlist:
                                  data = os.read(fd, 256)
                                  write_fd = client.fileno() if fd == master else master
                                  if len(data) == 0:
                                      is_connect = False
                                      break
                                  os.write(write_fd, data)
                                  # print(fd, event, data)
                      except ConnectionResetError:
                          is_connect = False
                          print("远程被迫断开链接")
                      finally:
                          mypoll.unregister(client.fileno())
              finally:
                  s.close()
                  os.close(master)
                  os.close(slave)
      def main():
          SocketServer()
      if __name__ == "__main__":
      D 1544536831 1 3 条回复 最后回复 回复 引用 0
      • 小鱼小 小鱼 在 中 引用了 这个主题
      • D
        d4nk3n @小鱼
        @小鱼 我感觉这段python代码也许可以修改一下:
        https://fishros.org.cn/forum/topic/1477/fishbot雷达板docker驱动断连后不能自动恢复
          小鱼 技术大佬 @d4nk3n
          @d4nk3n 收到,感谢指正
          • 1544536831
            Bear @小鱼
            最后由 154453683 编辑
            @小鱼 在 拓展2:FishBot配套雷达驱动教程(源码版) 中说:
            fishbot_laser
            无线驱动这段没看懂呢,有线的跑通了
            这个python运行后,是谁来连接它呢?
            我运行后处于 Prepare to Accept connect!状态
            然后我把ydlidar_ros2/params/ydlidar.yaml 改为 port: /tmp/fishbot_laser
            编译后,运行会time out,
            解决:作者这段py的端口号要改为8889,因为雷达板默认配的是8889
            希望可以给后来者
            小鱼小 流 2 条回复 最后回复 回复 引用 0
              小鱼 技术大佬 @154453683
              @154453683 可以先看快速上手教程,搞定链接
              • 25241673162
                今朝
                鱼哥,用树莓派通过串口连接转接板后运行雷达出现雷达停止运行了ab0f84dd-b008-4c6a-bd23-3d663fab0c93-image.png 531fd9f3-009d-47ec-9344-11fd7982be06-5d521c2cec135b84f80db650672d5dd.jpg
                小鱼小 1 2 条回复 最后回复 回复 引用 0
                  小鱼 技术大佬 @2524167316
                  @2524167316 确认下端口号是否正确,串口权限是否正确,可以使用cutecom打开指定端口看看数据。
                  • E eework 在 中 引用了 这个主题
                    小徐要早睡
                    雷达启动后会发布/map话题么,我在nav2启动的时候遇到如下报错
                    需要对雷达驱动进行更改么?
                      小鱼 技术大佬 @1141682555
                      @1141682555 雷达启动只发布sca话题,map需要slam算法发布
                        小徐要早睡 @小鱼
                        @小鱼 我现在建图时候一直发生漂移,/map坐标轴是移动的,/odom坐标轴固定不动
                        <?xml version="1.0"?>
                        <robot name="pigbot">
                        <!-- Robot Footprint -->
                        <link name="base_footprint"/>
                        <child link="base_link"/>
                        <origin xyz="0.0 0.0 0.166" rpy="0 0 0"/>
                        </joint>
                        <!-- base link -->
                        <link name="base_link">
                        <visual>
                        <geometry>
                        <box size="0.57 0.45 0.17"/>
                        </geometry>
                        <material name="blue">
                        </material>
                        </visual>
                        </link>
                        <!-- laser link -->
                        <link name="laser_frame">
                        <visual>
                        <geometry>
                        </geometry>
                        <material name="black">
                        </material>
                        </visual>
                        </link>
                        <!-- laser joint -->
                        <parent link="base_link" />
                        <child link="laser_frame" />
                        <origin xyz="0 0 0.075" />
                        </joint>
                        <!-- wheel link -->
                        <link name="left_front_wheel_link">
                        <visual>
                        <geometry>
                        <cylinder length="0.07" radius="0.166"/>
                        </geometry>
                        </material>
                        </visual>
                        </link>
                        <joint name="left_front_wheel_joint" type="continuous">
                        <child link="left_front_wheel_link" />
                        <origin xyz="0.175 0.225 -0.085" />
                        <axis xyz="0 1 0" />
                        </joint>
                        <link name="left_back_wheel_link">
                        <visual>
                        <geometry>
                        </geometry>
                        </material>
                        </visual>
                        </link>
                        <joint name="left_back_wheel_joint" type="continuous">
                        <child link="left_back_wheel_link" />
                        <origin xyz="-0.175 0.225 -0.085" />
                        </joint>
                        <link name="right_front_wheel_link">
                        <visual>
                        <geometry>
                        </geometry>
                        </material>
                        </visual>
                        </link>
                        <joint name="right_front_wheel_joint" type="continuous">
                        <child link="right_front_wheel_link" />
                        <origin xyz="0.175 -0.225 -0.085" />
                        </joint>
                        <link name="right_back_wheel_link">
                        <visual>
                        <geometry>
                        </geometry>
                        </material>
                        </visual>
                        </link>
                        <joint name="right_back_wheel_joint" type="continuous">
                        <child link="right_back_wheel_link" />
                        <origin xyz="-0.175 -0.225 -0.085" />
                        </joint>
                        </robot>
                        这是我的URDF,里程计话题发布和教程是一样的,请问中间有什么问题需要更改
                        • D
                          dong5515
                          按照教程编译的时候会报错,我的pi上位机版本是:
                          ROS_VERSION=2
                          ROS_PYTHON_VERSION=3
                          ROS_LOCALHOST_ONLY=0
                          ROS_DISTRO=foxy
                          • distinctyzD
                            yzq15962508857
                            你好,usb一连接到虚拟机,就断开是怎么回事啊。615f10d9-af52-4baa-b9eb-fd86e31b0deb-image.png ,谢谢!
                              小鱼 技术大佬 @distinctyz
                              @distinctyz 看看驱动占用问题是否解决
                                小鱼 技术大佬 @dong5515
                                @dong5515 驱动时humble版本导致的,建议更换到humble
                                • A
                                  anoddy1999
                                  問題: Failed to turn on the lidar,because the lidar is blocked or the lidar hardware is faulty
                                  設備: jetson orin nano
                                  Linux: Ubuntu22.04
                                  詳細: 我跟著教程5用windows燒錄了固件,最後也成功ping到 雷達的地址,接著用拓展教程2 完成了所有設定,可是最後卻反饋failed to turn on the lidar
                                  anthony@ubuntu:~/ydlidar_ros2$ ros2 launch ydlidar ydlidar_launch.py
                                  [INFO] [launch]: All log files can be found below /home/anthony/.ros/log/2024-09-14-10-38-52-043155-ubuntu-29717
                                  [INFO] [ydlidar_node-1]: process started with pid [29729]
                                  [INFO] [static_transform_publisher-2]: process started with pid [29731]
                                  [static_transform_publisher-2] [WARN] [1726281532.326946046] []: Old-style arguments are deprecated; see --help for new-style arguments
                                  [static_transform_publisher-2] [INFO] [1726281532.361383537] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                                  [ydlidar_node-1] timout count: 1
                                  [ydlidar_node-1] timout count: 2
                                  [ydlidar_node-1] 281472560785632 thread has been canceled
                                  [ydlidar_node-1] [CYdLidar] Failed to turn on the Lidar, because the lidar is blocked or the lidar hardware is faulty.
                                  [ydlidar_node-1] [YDLIDAR INFO] Now YDLIDAR is stopping .......
                                  [INFO] [ydlidar_node-1]: process has finished cleanly [pid 29729]
                                  [static_transform_publisher-2] [INFO] [1726281607.981043452] [rclcpp]: signal_handler(signum=2)
                                  [INFO] [static_transform_publisher-2]: process has finished cleanly [pid 29731]
                                    小鱼 技术大佬 @anoddy1999
                                    @anoddy1999 在 拓展2:FishBot配套雷达驱动教程(源码版) 中说:
                                    最後也成功ping到
                                    是谁ping通的,windows还是jetson,各个的ip地址是什么报一下
                                    A 1 条回复 最后回复 回复 引用 0
                                    • A
                                      anoddy1999 @小鱼
                                      @小鱼 是jetson ping到的
                                      fishbot版的ip 是:192.168.1.79
                                      jetson的ip是:192.168.1.207
                                      WhatsApp Image 2024-09-14 at 22.52.52.jpeg WhatsApp Image 2024-09-14 at 22.56.33.jpeg
                                        小鱼 技术大佬 @anoddy1999
                                        @anoddy1999 雷达板的IP呢,两者要分开配哦,另外最好单独发帖,跟贴容易被吃掉
                                        Y 1 条回复 最后回复 回复 引用 0
                                        • 流
                                          流浪呆猫 @154453683
                                          @154453683 感谢,问题解决
                                          • Y
                                            yongyong @小鱼
                                            @小鱼 这个雷达转接板的源码用什么打开呢,我用plateformio打不开
