    [FishBot教程]9.0.7. FishBot-Nav2导航测试
    fishbot 导航
    61
    226
    94.6k
    • 9212037249
      天地独鸣
      现在报错变了,变成这样了
      • 9212037249
        天地独鸣
        6825c1b7-c95c-4e8d-9dd1-b5cf6b752496-image.png 现在变成这样了
          小鱼 技术大佬 @921203724
          @921203724 仔细看提示,电脑没空间了
          另外
          终端打印一定复制粘贴,方便回答者检索和引用(你可以在linux系统上打开浏览器进社区)
          9212037249 3 条回复 最后回复 回复 引用 0
          • 9212037249
            天地独鸣 @小鱼
            @小鱼 可我的E盘有47.3GB可用啊
            • 9212037249
              天地独鸣 @小鱼
              @小鱼 0 upgraded, 82 newly installed, 0 to remove and 177 not upgraded.
              Need to get 119 MB of archives.
              After this operation, 323 MB of additional disk space will be used.
              E: You don't have enough free space in /var/cache/apt/archives/.
              ERROR: the following rosdeps failed to install
              apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros-pkgs] failed
              apt: command [sudo -H apt-get install -y gazebo] failed
              apt: command [sudo -H apt-get install -y ros-humble-gazebo-ros] failed
              apt: Failed to detect successful installation of [ros-humble-gazebo-ros-pkgs]
              apt: Failed to detect successful installation of [gazebo]
              apt: Failed to detect successful installation of [ros-humble-gazebo-ros]
              colcon: command not found
              就是这样,显示我地方不够,我腾E盘几个G还是这样
              • 9212037249
                天地独鸣 @小鱼
                @小鱼 0 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
                #All required rosdeps installed successfully
                现在安装成功了,但是colcon还是不成功
                  小鱼 技术大佬 @921203724
                  @921203724 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                  ros2没装好
                  9212037249 1 条回复 最后回复 回复 引用 0
                  • 9212037249
                    天地独鸣 @小鱼
                    @小鱼 OSError: [Errno 28] No space left on device: 'log/build_2023-03-11_13-56-33'
                    鱼哥,编译告诉我空间不够了,有什么好用的办法腾出来?
                      小鱼 技术大佬 @921203724
                      @921203724 最好重新装下系统,分配大点空间
                      • 10540602251
                        天马喂狗 @小鱼
                        • 10540602251
                          天马喂狗 @小鱼
                          @小鱼 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                          source install/setup.bash
                          ros2 launch fishbot_bringup fishbot_bringup.launch.py
                          需要添加
                          cd fishbot
                          • blairan121122885B
                            邱定凱
                            • 10130060431
                              1013006043
                              鱼哥,请问一下第三部启动 bring up 报这个错如何解决?
                              [ERROR] [launch]: Caught exception in launch (see debug for traceback): "package 'joint_state_publisher' not found, searching: ['/home/tcode9/fishbot/fishbot/install/fishbot_navigation2', '/home/tcode9/fishbot/fishbot/install/fishbot_interfaces', '/home/tcode9/fishbot/fishbot/install/fishbot_description', '/home/tcode9/fishbot/fishbot/install/fishbot_cartographer', '/home/tcode9/fishbot/fishbot/install/fishbot_bringup', '/opt/ros/humble']”
                                小鱼 技术大佬 @1013006043
                                @1013006043
                                rosdep install --from-paths src --ignore-src -y -r # 安装依赖
                                这一步,先跑一次一键安装
                                blairan121122885B 10320637471 29347754952 L 6 条回复 最后回复 回复 引用 0
                                • blairan121122885B
                                  邱定凱 @小鱼
                                  @小鱼 謝謝,已解決
                                  10320637471 1 条回复 最后回复 回复 引用 0
                                  • 29379248672
                                    NEO @小鱼
                                    git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                                    cd fishbot
                                    colcon build
                                    • 12503722621
                                      1250372262
                                      想要换自己的雷达 需要怎么操作
                                        @1250372262 重点在雷达转接板,雷达转接板可以实现串口转wifi转串口功能,配合代码:https://www.fishros.org.cn/forum/topic/949/拓展-雷达转接板的无线串口功能驱动代码
                                        12503722621 1 条回复 最后回复 回复 引用 0
                                        • 12503722621
                                          1250372262 @小鱼
                                          @小鱼 我是需要把原来的雷达替换成新雷达 然后把无线串口功能代码烧进板子里面 还是 无线串口功能代码是在电脑使用 直接把雷达换了 这一块不是很理解
                                            小鱼 技术大佬 @1250372262
                                            @1250372262 雷达板原有的固件不用动,配置上面给的代码就可以实现转串口了
