wros@wros-VirtualBox:~/chapt2$ make
Consolidate compiler generated dependencies of target ros2_cpp_node
[ 50%] Building CXX object CMakeFiles/ros2_cpp_node.dir/ros2_cpp_node.cpp.o
/home/wros/chapt2/ros2_cpp_node.cpp: In function ‘int main(int, char**)’:
/home/wros/chapt2/ros2_cpp_node.cpp:5:22: error: parse error in template argument list
5 | auto node = std::make_sharedrclcpp:::Node("cpp_node"); //创建节点
/home/wros/chapt2/ros2_cpp_node.cpp:5:48: error: no matching function for call to ‘make_shared<<expression error> >(const char [9])’
In file included from /usr/include/c++/11/memory:77,
from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:153,
from /home/wros/chapt2/ros2_cpp_node.cpp:1:
/usr/include/c++/11/bits/shared_ptr.h:875:5: note: candidate: ‘template<class _Tp, class ... _Args> std::shared_ptr<_Tp> std::make_shared(_Args&& ...)’
875 | make_shared(_Args&&... __args)
/usr/include/c++/11/bits/shared_ptr.h:875:5: note: template argument deduction/substitution failed:
/home/wros/chapt2/ros2_cpp_node.cpp:5:48: error: template argument 1 is invalid
In file included from /opt/ros/humble/include/rclcpp/rclcpp/client.hpp:40,
from /opt/ros/humble/include/rclcpp/rclcpp/callback_group.hpp:24,
from /opt/ros/humble/include/rclcpp/rclcpp/any_executable.hpp:20,
from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategy.hpp:25,
from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategies.hpp:18,
from /opt/ros/humble/include/rclcpp/rclcpp/executor_options.hpp:20,
from /opt/ros/humble/include/rclcpp/rclcpp/executor.hpp:37,
from /opt/ros/humble/include/rclcpp/rclcpp/executors/multi_threaded_executor.hpp:25,
from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:21,
from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155,
/opt/ros/humble/include/rclcpp/rclcpp/logging.hpp:531:81: error: template argument 1 is invalid
531 | ::std::is_same<typename std::remove_cv_t<typename std::remove_reference_t<decltype(logger)>>,
/home/wros/chapt2/ros2_cpp_node.cpp:6:5: note: in expansion of macro ‘RCLCPP_INFO’
6 | RCLCPP_INFO(node->get_logger(),"你好,C++节点!"); //打印日志
/opt/ros/humble/include/rclcpp/rclcpp/logging.hpp:531:97: error: template argument 1 is invalid
/opt/ros/humble/include/rclcpp/rclcpp/logging.hpp:532:32: error: template argument 1 is invalid
532 | typename ::rclcpp::Logger>::value,
make[2]: *** [CMakeFiles/ros2_cpp_node.dir/build.make:76:CMakeFiles/ros2_cpp_node.dir/ros2_cpp_node.cpp.o] 错误 1
make[1]: *** [CMakeFiles/Makefile2:85:CMakeFiles/ros2_cpp_node.dir/all] 错误 2
make: *** [Makefile:101:all] 错误 2
系统:20.04,ros:noetic,使用一键安装指令安装rosdepc。
问题:尝试了所有的pip源,在执行sudo pip3 install -i https://mirrors.aliyun.com/pypi/simple rosdepc --break-system-packages失败
打开终端执行这条指令显示没有--break-system-packages这个参数
检测到程序发生异常退出,请打开:https://fishros.org.cn/forum 携带如下内容进行反馈
标题:使用一键安装过程中遇到程序崩溃
Traceback (most recent call last): File "/tmp/fishinstall/install.py", line 134, in <module> main() File "/tmp/fishinstall/install.py", line 123, in main run_tool_file(tools[code]['tool'].replace("/",".")) File "/tmp/fishinstall/tools/base.py", line 1478, in run_tool_file if tool.run()==False: return False File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 94, in run self.install_rosdepc() File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 85, in install_rosdepc PrintUtils.print_warning("安装失败,尝试使用其他方式安装...") AttributeError: type object 'PrintUtils' has no attribute 'print_warning'本次运行详细日志文件已保存至 /tmp/fishros_install.log
sudo rosdep init
/usr/bin/rosdep:6: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
from pkg_resources import load_entry_point
ERROR: cannot download default sources list from:
https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
Website may be down.
<urlopen error <urlopen error [Errno 111] Connection refused> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list)>
配置ros源时:小鱼:检测当前系统ubuntu22.04:jammy 支持一键安装ROS
============正在添加ROS源密钥=================
[-][11.15s] CMD Result:success
[-][0.45s] CMD Result:success
[-][0.33s] CMD Result:success
[-][0.43s] CMD Result:success
[-][0.31s] CMD Result:success
正在挑选最快的密钥服务:['https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc', 'https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc']
https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc 延时:0.33s https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc 超时已自动选择最快密钥服务:https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc
[-][0.38s] CMD Result:success
[-][10.07s] CMD Result:code:2
Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
[-][0.36s] CMD Result:success
[-][0.00s] CMD Result:success
[-][11.62s] CMD Result:success
[-][0.50s] CMD Result:success
colcon build时find_package(OpenMP REQUIRED)报错,显示为:
CMake Error at /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find OpenMP_CXX (missing: OpenMP_CXX_FLAGS OpenMP_CXX_LIB_NAMES)
已经安装了ibomp-dev (1:14.0-55~exp2),编译器版本是g++ 11.4.0,ROS版本是Humble。
E: 无法下载 https://mirrors.ustc.edu.cn/ubuntu/pool/universe/f/freeimage/libfreeimage-dev_3.18.0%2Bds2-6ubuntu5.1_amd64.deb 暂时不能解析域名“mirrors.ustc.edu.cn”
E: 无法下载 https://mirrors.ustc.edu.cn/ubuntu/pool/universe/o/ogre-1.9/libogre-1.9-dev_1.9.0%2Bdfsg1-12.1ubuntu1_amd64.deb 暂时不能解析域名“mirrors.ustc.edu.cn”
E: 无法下载 https://mirrors.ustc.edu.cn/ubuntu/pool/universe/libt/libtar/libtar-dev_1.2.20-8ubuntu0.22.04.1_amd64.deb 暂时不能解析域名“mirrors.ustc.edu.cn”
友友们有使用过第四代控制器版本的睿尔曼机械臂吗,ros1版本控制,在跑官方ros包时出现Rviz中的姿态和真实机械臂姿态不一致的问题,利用rostopic echo /joint_states也没有数据反馈,一直处于待接收状态 ,但是虚拟机和机械臂可以ping通,不知道是什么原因如何解决。
出错截图如下:
编译的时候报错:src/main.cpp:45:5: error: 'set_microros_wifi_transports' was not declared in this scope,set_microros_wifi_transports函数未声明
[-][1.00s] CMD Result:code:2
标题:使用一键安装过程中遇到程序崩溃
Traceback (most recent call last): File "/tmp/fishinstall/install.py", line 134, in <module> main() File "/tmp/fishinstall/install.py", line 123, in main run_tool_file(tools[code]['tool'].replace("/",".")) File "/tmp/fishinstall/tools/base.py", line 1478, in run_tool_file if tool.run()==False: return False File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 94, in run self.install_rosdepc() File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 85, in install_rosdepc PrintUtils.print_warning("安装失败,尝试使用其他方式安装...") AttributeError: type object 'PrintUtils' has no attribute 'print_warning'最后输入ros2 run demo_cpp_pkg cpp_node时报错是什么原因呢,应该怎么解决这种情况?局部截取_20250807_210846.png
[自己用gazebo创建了个环境,用nav2进行导航, 给定目标点后,小车在行走过程中,局部膨胀地图随着激光雷达出现了偏移,将路线给挡住了,导致导航失败]
具体细节和上下文:1,机器人的仿真模型是根据鱼哥的视频一步步走下来的;
2.我的param.yaml对全局和局部的配置如下:
2.1 全局配置:
global_costmap:
global_costmap:
ros__parameters:
update_frequency: 2.0 #1.0
publish_frequency: 1.0
global_frame: map
robot_base_frame: base_footprint
use_sim_time: True
# robot_radius: 0.2
footprint: "[[0.325,-0.275],[0.325,0.275],[-0.325,0.275],[-0.325,-0.275]]"
resolution: 0.05
track_unknown_space: true
obstacle_layer:
enabled: True
observation_sources: scan
scan:
topic: /scan
max_obstacle_height: 2.0
clearing: True
marking: True
data_type: "LaserScan"
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range: 0.0
static_layer:
inflation_layer:
cost_scaling_factor: 6.0 #3.0
inflation_radius: 0.35 #0.15
2.2 局部配置:
local_costmap:
local_costmap:
ros__parameters:
update_frequency: 2.0 #2.0 #5.0
publish_frequency: 0.5 #2.0
global_frame: odom
use_sim_time: True
rolling_window: true
width: 5 #3
height: 5 #3
resolution: 0.02 #0.05
robot_radius: 0.46 #robot_radius: 0.2
inflation_layer:
inflation_radius: 0.45 #0.35 # 0.2 #0.15
obstacle_layer:
enabled: True
scan:
topic: /scan
clearing: True
marking: True
voxel_layer:
enabled: True
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
mark_threshold: 0
scan:
topic: /scan
clearing: True
marking: True
static_layer:
a818fc44-b97e-41dc-8db9-ba8c1c59aa45-image.png 尝试过的解决方法:
我尝试将全局和局部地图的更新频率设置成一样的,但是没有效果。不知道是什么原因,求大佬帮忙分析下。
root@6c45ca8f7aff:/home/yby# sudo mkdir -p /etc/apt/keyrings
curl -fsSL https://mirrors.aliyun.com/docker-ce/linux/ubuntu/gpg |
sudo gpg --dearmor -o /etc/apt/keyrings/docker.asc
root@6c45ca8f7aff:/home/yby# sudo apt update
Get:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy InRelease [4682 B]
Err:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy InRelease
The following signatures were invalid: EXPKEYSIG F42ED6FBAB17C654 Open Robotics info@osrfoundation.org
Hit:2 https://mirrors.ustc.edu.cn/ubuntu jammy InRelease
Hit:3 https://mirrors.ustc.edu.cn/ubuntu jammy-updates InRelease
Hit:4 https://mirrors.ustc.edu.cn/ubuntu jammy-backports InRelease
Get:5 https://mirrors.aliyun.com/docker-ce/linux/ubuntu focal InRelease [57.7 kB]
Hit:6 https://mirrors.ustc.edu.cn/ubuntu jammy-security InRelease
Err:5 https://mirrors.aliyun.com/docker-ce/linux/ubuntu focal InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
Reading package lists... Done
W: http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: GPG error: http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy InRelease: The following signatures were invalid: EXPKEYSIG F42ED6FBAB17C654 Open Robotics info@osrfoundation.org
E: The repository 'http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: https://mirrors.aliyun.com/docker-ce/linux/ubuntu focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
E: The repository 'https://mirrors.aliyun.com/docker-ce/linux/ubuntu focal InRelease' is not signed.
root@6c45ca8f7aff:/home/yby# ^C
按照教程一键安装docker+ros,在sudo apt update时出现问题,显示ros2所用的清华源已经过期。因为不知道如何修改容器里的ros源,所以想着修改docker源,修改后觉得不太对。
尝试过的解决方法:修改 Docker 源为阿里云(Ubuntu 20.04)
编辑 docker.listbash
复制
sudo nano /etc/apt/sources.list.d/docker.list 替换为阿里云 Docker CE 源
把原来的:
deb [arch=amd64 signed-by=/etc/apt/keyrings/docker.asc] https://mirrors.tuna.tsinghua.edu.cn/docker-ce/linux/ubuntu focal stable
改成:
deb [arch=amd64 signed-by=/etc/apt/keyrings/docker.asc] https://mirrors.aliyun.com/docker-ce/linux/ubuntu focal stable
注意:保留 signed-by=/etc/apt/keyrings/docker.asc,确保用的是官方 GPG 密钥。
截图 2025-08-05 18-13-59.png 截图 2025-08-05 18-14-25.png 截图 2025-08-05 18-14-25.png
1、我现在遇到了 在设备上发布ROS2相机话题,本机可以顺畅的收到。局域网里的设备可以收到,但是非常卡顿,丢帧验证的问题。当减小到data大小为115200byte时,局域网也可以顺畅接收
2、发布端关键代码如下:
// 构造函数修改:添加NodeOptions设置DDS参数
CCameraPublisher::CCameraPublisher(std::string name)
: rclcpp::Node(
"Image_publisher_" + sanitizeNodeName(name),
// 配置节点选项,设置DDS参数
rclcpp::NodeOptions options;
// 设置FastDDS最大消息大小(字节),4MB = 4194304
options.append_parameter_override("fastrtps.fragment_size", 1400); // 分片大小 < MTU(如1400,留足IP头空间)
options.append_parameter_override("rmw_fastrtps_max_message_size", 10 * 1024 * 1024); // 大于实际消息大小
// 发布端和订阅端均需添加:
options.append_parameter_override("fastrtps.sendBufferSize", 8 * 1024 * 1024); // 发送缓冲区8MB
options.append_parameter_override("fastrtps.receiveBufferSize", 8 * 1024 * 1024); // 接收缓冲区8MB
options.append_parameter_override("ros_network_receive_buffer_size", 10 * 1024 * 1024); // ROS层缓冲区
// 禁用DDS域名自动发现,避免多播冲突
options.append_parameter_override("rmw_fastrtps_discovery_servers", std::vectorstd::string());
return options;
// QoS配置保持不变,但建议显式设置历史深度
auto qos = rclcpp::SensorDataQoS()
.keep_last(10) // 队列深度
.best_effort() // 尽力而为模式
.durability_volatile() // volatile耐用性(不存储历史数据)
.deadline(rclcpp::Duration(std::chrono::milliseconds(100))); // 使用std::chrono兼容方式.deadline(rclcpp::Duration(std::chrono::milliseconds(100))); // 使用std::chrono兼容方式
bool CCameraPublisher::Publisher(unsigned char *data, int datalen, int64_t tv_sec, int64_t tv_usec)
sensor_msgs::msg::CompressedImage image_msg;
image_msg.header.stamp.sec = static_cast<int32_t>(tv_sec);
image_msg.header.stamp.nanosec = static_cast<uint32_t>(tv_usec);
image_msg.header.frame_id = m_strTopic; // 设置帧ID
image_msg.data.resize(datalen);
image_msg.format = "jpg";
std::memcpy(image_msg.data.data(), (unsigned char *)data, image_msg.data.size()); // 填充压缩后的图像数据
m_Publisher->publish(image_msg);
// 更新帧信息
new_frame_ts_ = TZTEK_GetTime();
diff_time_ = new_frame_ts_ - old_frame_ts_; // 单位
tztek_dbg("%d.%09d, 发布 %s,datalen:%d 间隔: %dms",
image_msg.header.stamp.sec,
image_msg.header.stamp.nanosec,
image_msg.header.frame_id.c_str(),datalen,
diff_time_);
old_frame_ts_ = new_frame_ts_;
return true;
3、订阅端关键代码如下:
CompressedImageSubscriber() :
Node(
"compressed_image_subscriber",
// 配置节点选项,与发布端保持一致的DDS参数
// 设置与发布端相同的最大消息大小(4MB)
// 发布端和订阅端均需添加:
// 禁用自动发现服务器,减少网络干扰
return options;
first_callback_(true)
// 创建订阅者,使用与发布端完全匹配的QoS配置
.keep_last(10) // 队列深度10,与发布端一致
.best_effort() // 尽力而为可靠性,与发布端匹配
.durability_volatile() // 不存储历史数据,减少内存占用
4、这个数据的 Data size: 576000 bytes,这个尺寸会异常丢帧,但是如果我修改
image_msg.data.resize(datalen/5);
std::memcpy(image_msg.data.data(), (unsigned char *)data, image_msg.data.size()/5);
局域网的设备也可以顺畅接收
5、订阅端的回调函数仅仅是打印
6、请主要关注为啥局域网的设备是否顺畅,与data size有关
7、网络带宽为
[ 5] local 192.168.37.96 port 39468 connected to 192.168.37.167 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 12.0 MBytes 101 Mbits/sec 0 206 KBytes
8、发布端发布1路数据,帧率为12.5fps,订阅端仅仅订阅一路
9、局域网的订阅端带宽:
jixufang@jixufang-Latitude-5401:~/ros2_workspace$ ros2 topic bw cam1/compressed
Subscribed to [cam1/compressed]
2.88 MB/s from 4 messages
Message size mean: 0.58 MB min: 0.58 MB max: 0.58 MB
1.28 MB/s from 4 messages
10、本机的订阅端带宽:
root@hobot:/map/ywy/cam_b24cf85b# ros2 topic bw cam1/compressed
5.78 MB/s from 13 messages
Message size mean: 0.44 MB min: 0.44 MB max: 0.44 MB
5.51 MB/s from 25 messages
5.56 MB/s from 38 messages
11、scp测试丢包情况:
root@hobot:/map/ywy/cam_b24cf85b# dd if=/dev/zero of=test.bin bs=576000 count=100
100+0 records in
100+0 records out
57600000 bytes (58 MB, 55 MiB) copied, 0.0404203 s, 1.4 GB/s
root@hobot:/map/ywy/cam_b24cf85b# ls
case_tztek cfg demo init_env.sh J6_Cam_User_Guide_V1.0.pdf test.bin tools tztek_camera.sh version
root@hobot:/map/ywy/cam_b24cf85b# scp test.bin jixufang@192.168.37.96:~/
Warning: Permanently added '192.168.37.96' (ED25519) to the list of known hosts.
jixufang@192.168.37.96's password:
test.bin 没看出来丢包
wzy@DESKTOP-AOGOC7F:~/ws_moveit2$ ros2 launch moveit2_tutorials demo.launch.py
[INFO] [launch]: All log files can be found below /home/wzy/.ros/log/2025-08-02-09-38-00-675071-DESKTOP-AOGOC7F-27823
[INFO] [rviz2-1]: process started with pid [27824]
[INFO] [static_transform_publisher-2]: process started with pid [27826]
[INFO] [robot_state_publisher-3]: process started with pid [27828]
[INFO] [move_group-4]: process started with pid [27830]
[INFO] [ros2_control_node-5]: process started with pid [27832]
[INFO] [spawner-6]: process started with pid [27834]
[INFO] [spawner-7]: process started with pid [27836]
[INFO] [spawner-8]: process started with pid [27838]
[static_transform_publisher-2] [WARN] [1754098680.948028663] []: Old-style arguments are deprecated; see --help for new-style arguments
[static_transform_publisher-2] [INFO] [1754098680.982169551] [static_transform_publisher]: Spinning until stopped - publishing transform
[static_transform_publisher-2] translation: ('0.000000', '0.000000', '0.000000')
[static_transform_publisher-2] from 'world' to 'panda_link0'
[robot_state_publisher-3] [INFO] [1754098681.018522512] [robot_state_publisher]: got segment panda_hand
[robot_state_publisher-3] [INFO] [1754098681.018726372] [robot_state_publisher]: got segment panda_leftfinger
[robot_state_publisher-3] [INFO] [1754098681.018737042] [robot_state_publisher]: got segment panda_link0
[robot_state_publisher-3] [INFO] [1754098681.018742690] [robot_state_publisher]: got segment panda_link1
[robot_state_publisher-3] [INFO] [1754098681.018747510] [robot_state_publisher]: got segment panda_link2
[robot_state_publisher-3] [INFO] [1754098681.018752171] [robot_state_publisher]: got segment panda_link3
[robot_state_publisher-3] [INFO] [1754098681.018757723] [robot_state_publisher]: got segment panda_link4
[robot_state_publisher-3] [INFO] [1754098681.018762458] [robot_state_publisher]: got segment panda_link5
[robot_state_publisher-3] [INFO] [1754098681.018767225] [robot_state_publisher]: got segment panda_link6
[robot_state_publisher-3] [INFO] [1754098681.018771981] [robot_state_publisher]: got segment panda_link7
[robot_state_publisher-3] [INFO] [1754098681.018776685] [robot_state_publisher]: got segment panda_link8
[robot_state_publisher-3] [INFO] [1754098681.018781409] [robot_state_publisher]: got segment panda_rightfinger
[ros2_control_node-5] [WARN] [1754098681.025856905] [controller_manager]: [Deprecated] Passing the robot description parameter directly to the control_manager node is deprecated. Use '~/robot_description' topic from 'robot_state_publisher' instead.
[ros2_control_node-5] [INFO] [1754098681.026141049] [resource_manager]: Loading hardware 'PandaFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027842303] [resource_manager]: Initialize hardware 'PandaFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027915165] [resource_manager]: Successful initialization of hardware 'PandaFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027931621] [resource_manager]: Loading hardware 'PandaHandFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027939477] [resource_manager]: Initialize hardware 'PandaHandFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027947482] [resource_manager]: Successful initialization of hardware 'PandaHandFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027976540] [resource_manager]: 'configure' hardware 'PandaHandFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027981912] [resource_manager]: Successful 'configure' of hardware 'PandaHandFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027985447] [resource_manager]: 'activate' hardware 'PandaHandFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027989407] [resource_manager]: Successful 'activate' of hardware 'PandaHandFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027992411] [resource_manager]: 'configure' hardware 'PandaFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027995490] [resource_manager]: Successful 'configure' of hardware 'PandaFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.027999716] [resource_manager]: 'activate' hardware 'PandaFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.028002784] [resource_manager]: Successful 'activate' of hardware 'PandaFakeSystem'
[ros2_control_node-5] [INFO] [1754098681.034155736] [controller_manager]: update rate is 100 Hz
[ros2_control_node-5] [INFO] [1754098681.034214457] [controller_manager]: Spawning controller_manager RT thread with scheduler priority: 50
[ros2_control_node-5] [WARN] [1754098681.034386819] [controller_manager]: No real-time kernel detected on this system. See [https://control.ros.org/master/doc/ros2_control/controller_manager/doc/userdoc.html] for details on how to enable realtime scheduling.
[move_group-4] [INFO] [1754098681.078095853] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.0255684 seconds
[move_group-4] [INFO] [1754098681.078675744] [moveit_robot_model.robot_model]: Loading robot model 'panda'...
[rviz2-1] QStandardPaths: wrong permissions on runtime directory /run/user/1000/, 0755 instead of 0700
[move_group-4] [INFO] [1754098681.159887565] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Publishing maintained planning scene on 'monitored_planning_scene'
[move_group-4] [INFO] [1754098681.160116226] [moveit.ros_planning_interface.moveit_cpp]: Listening to 'joint_states' for joint states
[move_group-4] [INFO] [1754098681.162039400] [moveit_ros.current_state_monitor]: Listening to joint states on topic 'joint_states'
[move_group-4] [INFO] [1754098681.162783887] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/attached_collision_object' for attached collision objects
[move_group-4] [INFO] [1754098681.162818359] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[move_group-4] [INFO] [1754098681.163241146] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/planning_scene'
[move_group-4] [INFO] [1754098681.163270066] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting world geometry update monitor for collision objects, attached objects, octomap updates.
[move_group-4] [INFO] [1754098681.163695220] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to 'collision_object'
[move_group-4] [INFO] [1754098681.164021427] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to 'planning_scene_world' for planning scene world geometry
[move_group-4] [WARN] [1754098681.167018499] [moveit.ros.occupancy_map_monitor.middleware_handle]: Resolution not specified for Octomap. Assuming resolution = 0.1 instead
[move_group-4] [ERROR] [1754098681.167064034] [moveit.ros.occupancy_map_monitor.middleware_handle]: No 3D sensor plugin(s) defined for octomap updates
[move_group-4] [INFO] [1754098681.168733346] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'ompl'
[move_group-4] [INFO] [1754098681.211638444] [moveit.ros_planning.planning_pipeline]: Using planning interface 'OMPL'
[ros2_control_node-5] [INFO] [1754098681.220138025] [controller_manager]: Loading controller 'joint_state_broadcaster'
[move_group-4] [INFO] [1754098681.220852886] [moveit_ros.add_time_optimal_parameterization]: Param 'ompl.path_tolerance' was not set. Using default value: 0.100000
[move_group-4] [INFO] [1754098681.220880861] [moveit_ros.add_time_optimal_parameterization]: Param 'ompl.resample_dt' was not set. Using default value: 0.100000
[move_group-4] [INFO] [1754098681.220885140] [moveit_ros.add_time_optimal_parameterization]: Param 'ompl.min_angle_change' was not set. Using default value: 0.001000
[move_group-4] [INFO] [1754098681.220908528] [moveit_ros.fix_workspace_bounds]: Param 'ompl.default_workspace_bounds' was not set. Using default value: 10.000000
[move_group-4] [INFO] [1754098681.220917648] [moveit_ros.fix_start_state_bounds]: Param 'ompl.start_state_max_bounds_error' was set to 0.100000
[move_group-4] [INFO] [1754098681.220922362] [moveit_ros.fix_start_state_bounds]: Param 'ompl.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-4] [INFO] [1754098681.220929114] [moveit_ros.fix_start_state_collision]: Param 'ompl.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-4] [INFO] [1754098681.220933191] [moveit_ros.fix_start_state_collision]: Param 'ompl.jiggle_fraction' was not set. Using default value: 0.020000
[move_group-4] [INFO] [1754098681.220944635] [moveit_ros.fix_start_state_collision]: Param 'ompl.max_sampling_attempts' was not set. Using default value: 100
[move_group-4] [INFO] [1754098681.220951632] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Add Time Optimal Parameterization'
[move_group-4] [INFO] [1754098681.220956643] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Resolve constraint frames to robot links'
[move_group-4] [INFO] [1754098681.220959223] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Workspace Bounds'
[move_group-4] [INFO] [1754098681.220961888] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Bounds'
[move_group-4] [INFO] [1754098681.220964287] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State In Collision'
[move_group-4] [INFO] [1754098681.220966792] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Path Constraints'
[move_group-4] [INFO] [1754098681.225317516] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'chomp'
[ros2_control_node-5] [INFO] [1754098681.235021707] [controller_manager]: Loading controller 'panda_arm_controller'
[move_group-4] [INFO] [1754098681.239313157] [moveit.ros_planning.planning_pipeline]: Using planning interface 'CHOMP'
[move_group-4] [INFO] [1754098681.244663501] [moveit_ros.add_time_optimal_parameterization]: Param 'chomp.path_tolerance' was not set. Using default value: 0.100000
[move_group-4] [INFO] [1754098681.244708580] [moveit_ros.add_time_optimal_parameterization]: Param 'chomp.resample_dt' was not set. Using default value: 0.100000
[move_group-4] [INFO] [1754098681.244714472] [moveit_ros.add_time_optimal_parameterization]: Param 'chomp.min_angle_change' was not set. Using default value: 0.001000
[move_group-4] [INFO] [1754098681.244730843] [moveit_ros.fix_workspace_bounds]: Param 'chomp.default_workspace_bounds' was not set. Using default value: 10.000000
[move_group-4] [INFO] [1754098681.244744931] [moveit_ros.fix_start_state_bounds]: Param 'chomp.start_state_max_bounds_error' was set to 0.100000
[move_group-4] [INFO] [1754098681.244750070] [moveit_ros.fix_start_state_bounds]: Param 'chomp.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-4] [INFO] [1754098681.244760039] [moveit_ros.fix_start_state_collision]: Param 'chomp.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-4] [INFO] [1754098681.244765007] [moveit_ros.fix_start_state_collision]: Param 'chomp.jiggle_fraction' was not set. Using default value: 0.020000
[move_group-4] [INFO] [1754098681.244770836] [moveit_ros.fix_start_state_collision]: Param 'chomp.max_sampling_attempts' was not set. Using default value: 100
[move_group-4] [INFO] [1754098681.244780921] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Add Time Optimal Parameterization'
[move_group-4] [INFO] [1754098681.244785540] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Workspace Bounds'
[move_group-4] [INFO] [1754098681.244789277] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Bounds'
[move_group-4] [INFO] [1754098681.244792610] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State In Collision'
[move_group-4] [INFO] [1754098681.244796390] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Path Constraints'
[move_group-4] [INFO] [1754098681.246144820] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'pilz_industrial_motion_planner'
[spawner-6] [INFO] [1754098681.253890689] [spawner_joint_state_broadcaster]: Loaded joint_state_broadcaster
[move_group-4] [INFO] [1754098681.257121138] [moveit.pilz_industrial_motion_planner.joint_limits_aggregator]: Reading limits from namespace robot_description_planning
[move_group-4] [WARN] [1754098681.258871006] [moveit.pilz_industrial_motion_planner.joint_limits_aggregator]: Multi-DOF-Joint 'virtual_joint' not supported.
[move_group-4] [WARN] [1754098681.258911933] [moveit.pilz_industrial_motion_planner.joint_limits_aggregator]: Multi-DOF-Joint 'virtual_joint' not supported.
[ros2_control_node-5] [WARN] [1754098681.259039619] [panda_arm_controller]: [Deprecated]: "allow_nonzero_velocity_at_trajectory_end" is set to true. The default behavior will change to false.
[ros2_control_node-5] [INFO] [1754098681.264976958] [controller_manager]: Loading controller 'panda_hand_controller'
[move_group-4] [INFO] [1754098681.268577785] [moveit.pilz_industrial_motion_planner]: Available plugins: pilz_industrial_motion_planner/PlanningContextLoaderCIRC pilz_industrial_motion_planner/PlanningContextLoaderLIN pilz_industrial_motion_planner/PlanningContextLoaderPTP
[move_group-4] [INFO] [1754098681.268612215] [moveit.pilz_industrial_motion_planner]: About to load: pilz_industrial_motion_planner/PlanningContextLoaderCIRC
[move_group-4] [INFO] [1754098681.272577957] [moveit.pilz_industrial_motion_planner]: Registered Algorithm [CIRC]
[move_group-4] [INFO] [1754098681.272618693] [moveit.pilz_industrial_motion_planner]: About to load: pilz_industrial_motion_planner/PlanningContextLoaderLIN
[move_group-4] [INFO] [1754098681.274551799] [moveit.pilz_industrial_motion_planner]: Registered Algorithm [LIN]
[move_group-4] [INFO] [1754098681.274577013] [moveit.pilz_industrial_motion_planner]: About to load: pilz_industrial_motion_planner/PlanningContextLoaderPTP
[move_group-4] [INFO] [1754098681.276563181] [moveit.pilz_industrial_motion_planner]: Registered Algorithm [PTP]
[move_group-4] [INFO] [1754098681.276630936] [moveit.ros_planning.planning_pipeline]: Using planning interface 'Pilz Industrial Motion Planner'
[spawner-7] [INFO] [1754098681.279872189] [spawner_panda_arm_controller]: Loaded panda_arm_controller
[move_group-4] [INFO] [1754098681.281572348] [moveit_ros.fix_workspace_bounds]: Param 'pilz_industrial_motion_planner.default_workspace_bounds' was not set. Using default value: 10.000000
[move_group-4] [INFO] [1754098681.281615441] [moveit_ros.fix_start_state_bounds]: Param 'pilz_industrial_motion_planner.start_state_max_bounds_error' was not set. Using default value: 0.050000
[move_group-4] [INFO] [1754098681.281641781] [moveit_ros.fix_start_state_bounds]: Param 'pilz_industrial_motion_planner.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-4] [INFO] [1754098681.281656825] [moveit_ros.fix_start_state_collision]: Param 'pilz_industrial_motion_planner.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-4] [INFO] [1754098681.281660870] [moveit_ros.fix_start_state_collision]: Param 'pilz_industrial_motion_planner.jiggle_fraction' was not set. Using default value: 0.020000
[move_group-4] [INFO] [1754098681.281666019] [moveit_ros.fix_start_state_collision]: Param 'pilz_industrial_motion_planner.max_sampling_attempts' was not set. Using default value: 100
[move_group-4] [INFO] [1754098681.281673578] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Workspace Bounds'
[move_group-4] [INFO] [1754098681.281677581] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Bounds'
[move_group-4] [INFO] [1754098681.281680160] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State In Collision'
[move_group-4] [INFO] [1754098681.281682815] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Path Constraints'
[ros2_control_node-5] [INFO] [1754098681.284886675] [controller_manager]: Configuring controller 'joint_state_broadcaster'
[ros2_control_node-5] [INFO] [1754098681.285011676] [joint_state_broadcaster]: 'joints' or 'interfaces' parameter is empty. All available state interfaces will be published
[ros2_control_node-5] [INFO] [1754098681.295113767] [controller_manager]: Configuring controller 'panda_arm_controller'
[ros2_control_node-5] [INFO] [1754098681.295307382] [panda_arm_controller]: No specific joint names are used for command interfaces. Using 'joints' parameter.
[ros2_control_node-5] [INFO] [1754098681.295334232] [panda_arm_controller]: Command interfaces are [position] and state interfaces are [position velocity].
[ros2_control_node-5] [INFO] [1754098681.295371273] [panda_arm_controller]: Using 'splines' interpolation method.
[ros2_control_node-5] [INFO] [1754098681.296666165] [panda_arm_controller]: Controller state will be published at 50.00 Hz.
[ros2_control_node-5] [INFO] [1754098681.299208427] [panda_arm_controller]: Action status changes will be monitored at 20.00 Hz.
[spawner-8] [INFO] [1754098681.302633400] [spawner_panda_hand_controller]: Loaded panda_hand_controller
[ros2_control_node-5] [INFO] [1754098681.314797380] [controller_manager]: Configuring controller 'panda_hand_controller'
[ros2_control_node-5] [INFO] [1754098681.314898344] [panda_hand_controller]: Action status changes will be monitored at 20.000000 Hz.
[move_group-4] [INFO] [1754098681.340365531] [moveit.plugins.moveit_simple_controller_manager]: Added FollowJointTrajectory controller for panda_arm_controller
[move_group-4] [INFO] [1754098681.340436450] [moveit.plugins.moveit_simple_controller_manager]: Max effort set to 0.0
[move_group-4] [INFO] [1754098681.343265394] [moveit.plugins.moveit_simple_controller_manager]: Added GripperCommand controller for panda_hand_controller
[move_group-4] [INFO] [1754098681.343448181] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
[move_group-4] [INFO] [1754098681.343482037] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
[move_group-4] [INFO] [1754098681.344029485] [moveit_ros.trajectory_execution_manager]: Trajectory execution is managing controllers
[move_group-4] [INFO] [1754098681.344054030] [move_group.move_group]: MoveGroup debug mode is ON
[spawner-7] [INFO] [1754098681.345556897] [spawner_panda_arm_controller]: Configured and activated panda_arm_controller
[spawner-8] [INFO] [1754098681.365403658] [spawner_panda_hand_controller]: Configured and activated panda_hand_controller
[move_group-4] [INFO] [1754098681.373568953] [move_group.move_group]:
[move_group-4]
[move_group-4] ********************************************************
[move_group-4] * MoveGroup using:
[move_group-4] * - ApplyPlanningSceneService
[move_group-4] * - ClearOctomapService
[move_group-4] * - CartesianPathService
[move_group-4] * - ExecuteTrajectoryAction
[move_group-4] * - GetPlanningSceneService
[move_group-4] * - KinematicsService
[move_group-4] * - MoveAction
[move_group-4] * - MotionPlanService
[move_group-4] * - QueryPlannersService
[move_group-4] * - StateValidationService
[move_group-4]
[move_group-4] [INFO] [1754098681.373633024] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context using planning plugin ompl_interface/OMPLPlanner
[move_group-4] [INFO] [1754098681.373640361] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context initialization complete
[move_group-4] Loading 'move_group/ApplyPlanningSceneService'...
[move_group-4] Loading 'move_group/ClearOctomapService'...
[move_group-4] Loading 'move_group/MoveGroupCartesianPathService'...
[move_group-4] Loading 'move_group/MoveGroupExecuteTrajectoryAction'...
[move_group-4] Loading 'move_group/MoveGroupGetPlanningSceneService'...
[move_group-4] Loading 'move_group/MoveGroupKinematicsService'...
[move_group-4] Loading 'move_group/MoveGroupMoveAction'...
[move_group-4] Loading 'move_group/MoveGroupPlanService'...
[move_group-4] Loading 'move_group/MoveGroupQueryPlannersService'...
[move_group-4] Loading 'move_group/MoveGroupStateValidationService'...
[move_group-4]
[move_group-4] You can start planning now!
[move_group-4]
[spawner-6] [INFO] [1754098681.395830899] [spawner_joint_state_broadcaster]: Configured and activated joint_state_broadcaster
[INFO] [spawner-7]: process has finished cleanly [pid 27836]
[INFO] [spawner-8]: process has finished cleanly [pid 27838]
[INFO] [spawner-6]: process has finished cleanly [pid 27834]
[rviz2-1] [INFO] [1754098682.876993663] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-1] [INFO] [1754098682.877202779] [rviz2]: OpenGl version: 4.2 (GLSL 4.2)
[rviz2-1] [INFO] [1754098682.939618229] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-1] Warning: class_loader.impl: SEVERE WARNING!!! A namespace collision has occurred with plugin factory for class rviz_default_plugins::displays::InteractiveMarkerDisplay. New factory will OVERWRITE existing one. This situation occurs when libraries containing plugins are directly linked against an executable (the one running right now generating this message). Please separate plugins out into their own library or just don't link against the library and use either class_loader::ClassLoader/MultiLibraryClassLoader to open.
[rviz2-1] at line 253 in /opt/ros/humble/include/class_loader/class_loader/class_loader_core.hpp
[rviz2-1] [ERROR] [1754098684.391233886] [moveit_ros_visualization.motion_planning_frame]: Action server: /recognize_objects not available
[rviz2-1] [INFO] [1754098684.416077505] [moveit_ros_visualization.motion_planning_frame]: MoveGroup namespace changed: / -> . Reloading params.
[rviz2-1] [INFO] [1754098684.439471913] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.019429 seconds
[rviz2-1] [INFO] [1754098684.439552867] [moveit_robot_model.robot_model]: Loading robot model 'panda'...
[rviz2-1] [INFO] [1754098684.924842025] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.0057921 seconds
[rviz2-1] [INFO] [1754098684.924890851] [moveit_robot_model.robot_model]: Loading robot model 'panda'...
[rviz2-1] [INFO] [1754098685.030988045] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[rviz2-1] [INFO] [1754098685.031812303] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/monitored_planning_scene'
[rviz2-1] [INFO] [1754098685.033134825] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[rviz2-1] [INFO] [1754098685.034485947] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/monitored_planning_scene'
[rviz2-1] [INFO] [1754098685.046524906] [interactive_marker_display_109031445708608]: Connected on namespace: /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic
[rviz2-1] [INFO] [1754098685.056351081] [moveit_ros_visualization.motion_planning_frame]: group panda_arm
[rviz2-1] [INFO] [1754098685.056388669] [moveit_ros_visualization.motion_planning_frame]: Constructing new MoveGroup connection for group 'panda_arm' in namespace ''
[rviz2-1] [INFO] [1754098685.068290581] [move_group_interface]: Ready to take commands for planning group panda_arm.
[rviz2-1] [INFO] [1754098685.069730020] [interactive_marker_display_109031445708608]: Sending request for interactive markers
[rviz2-1] [INFO] [1754098685.093844896] [interactive_marker_display_109031445708608]: Service response received for initialization
整个运行信息看着是正常的。有朋友遇到这个问题吗,是怎么解决的
0caaca3f-f361-45bc-91ba-14684f4604cc-image.png c4b71b08-7d03-4dc5-8e2c-63aa1bbdaa28-image.png
问题描述:出现了如图所示的报错
[ERROR] [1753779025.670329548] [rviz2]: Vertex Program:rviz/glsl120/indexed_8bit_image.vert Fragment Program:rviz/glsl120/indexed_8bit_image.frag GLSL link result :
,此后自己在进行仿真建图时,出现的地图如图二所示很杂乱
在准备好gazebo环境,使用命令行ros2 launch slam_box online_async_launch.py use_sim_time:=True
后,再打开rviz2开始map插件,并将topic话题选择/map过后,便出现了如图所示的报错,此后自己在进行仿真建图时,出现的地图如图二所示很杂乱 ,而且地图更新的很慢
自己后来根据ai的解决方案,排除了环境的原因也尝试重新安装rviz2,且采用强制兼容的模式MESA_GL_VERSION_OVERRIDE=3.3,也没能解决
在安装的navigation2中没有nav2_simple_commander这个命令,from nav2_simple_commander.robot_navigator import BasicNavigator输入该行代码时,下面一直有波浪线,下载navigation2也是跟着教程下载的,我的版本是foxy。
具体细节和上下文:这是终端提示的错误:Traceback (most recent call last):
File "/home/ros2/chapt7/chapt7_ws/install/fishbot_application/lib/fishbot_application/init_robot_pose", line 11, in <module>
load_entry_point('fishbot-application==0.0.0', 'console_scripts', 'init_robot_pose')()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 490, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2854, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2445, in load
return self.resolve()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2451, in resolve
module = import(self.module_name, fromlist=['name'], level=0)
File "/home/ros2/chapt7/chapt7_ws/install/fishbot_application/lib/python3.8/site-packages/fishbot_application/init_robot_pose.py", line 2, in <module>
ModuleNotFoundError: No module named 'nav2_simple_commander'
重新克隆nav2包,但还是不行。
版块
1.4k
主题4.9k
帖子 -
460
主题3.0k
帖子 -
68
主题263
帖子 -
1.1k
主题4.3k
帖子 -
1.0k
主题3.7k
帖子 -
5
主题11
帖子 -
358
主题1.6k
帖子
